      02-05-2012, 03:23 PM   #67
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Drives: VO 1M #739/740
Originally Posted by pixelblue View Post
yeah modding the back shield really helps keeping the rotors cooler. here is the link for the ti shims
http://hardbrakes.com/index.php?main...products_id=92
Do these ti shields really work?
      02-05-2012, 07:51 PM   #68
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Originally Posted by IGoFast1589 View Post
In my opinion and experience, the Ferodos's are the best double duty pad. I have seen EBC Yellow's eat rotors like it's their job for street/track driven cars, the Hawk HP+ were horribly loud, offered poor brake release characteristics and ruined the wheels on my old car (but they stopped like hell when hot) and the Cool Carbon's seem mediocre from what I have seen. If the pads are double duty then the best thing you can do is the Ferodos. I wouldn't think twice about it...
Yes, I agree on the Ferodo DS2500 being one of the best double duty pads out there. It is rotor friendly when cold, linear brake torque curve and excellent modulation and release characteristics.
Cool Carbon is more of a street pad than track pad and can't really be compared to the DS2500.
Yes, they are a great thermal barrier to keep heat away form the pistons and reduce the possibility of boiling the brake fluid.
      02-06-2012, 06:36 AM   #69
IGoFast1589
IGoFast1589's Avatar
49
Drives: 08 135i
Yes, unfair of me to compare.
      02-06-2012, 12:20 PM   #70
RedTRex
Digital Cerebrum
Drives: 05 330ci ZHP
2005 BMW 330ci  [0.00]
castrol srf or motul rbf 600 - 660. also get some titanium shims. you could also modify the back shield to allow more air to the rotors
Damn the Castrol is expensive.....
Someone also suggested Pentosin Super Dot4 - but I am looking at their website right now and get the funny feeling that Pentosin DOT4 LV is what we have OEM.
so thoughts?
      02-06-2012, 12:30 PM   #71
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
so thoughts?
Motul RBF 600 and you won't have a problem, my brakes get extremely hot at the track, and I have not had an issue with RBF 600.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
      02-06-2012, 12:48 PM   #72
Focusedintntions
Drives: 2011 135i M-Sport :D
+1 on the motul rbf600...worth it!
      02-06-2012, 01:03 PM   #73
RedTRex
Digital Cerebrum
Okay, that is what I was leaning towards anyway, and I can get it local. Thanks much.
      08-02-2012, 12:44 AM   #74
BMW86
Drives: RS3 Sedan / Macan S
Originally Posted by jlee View Post
just thought I would update the thread, after following this thread I went ahead and have upgraded to BMW Performance rotors all around, Motul fluid, and Ferodo 2500 pads and had brake fade in the first 15 minutes of my first session, I had to end it early.
I could only do 1/2 the normal session all day, I'm definitely upgrading to harder pads...
Jeff
This review seems out of the ordinary. What Motul fluid did you use? I'm interested i the Ferodo 2500 pads but unsure after reading this.
      08-02-2012, 04:57 AM   #75
GaryS
Drives: 2009 135i 6MT
2009 135i  [6.50]
Hawk race pads are good to 1600 degrees. Ferodo 2500 are good to 950 degrees. I exceed 950 on all four tracks I run at. It's hard not to if you're getting above 120 mph. For reference, your rotors glow orange at 1200 degrees. If that happens, you've probably melted the Ferodos.
With any street/track pads, when they do start to fade, just back off on your braking by lifting off the gas way early and coasting a few seconds before you brake - the opposite of late braking, so your top speed becomes 110 instead of 130. You can do that every other lap and be fine.
      08-02-2012, 05:19 AM   #76
BMW86
That's interesting. Do you know what the stock pads are rated up to? Everything I've read so far states that Ferodo is better than Hawk.
      08-02-2012, 06:02 AM   #77
GaryS
2009 135i  [6.50]
Hawk makes a lot of pads. You're probably thinking of HPS, which is for street only, or HP+, which is for autocross. I'm talking about DTC-60 and DTC-70, which are race pads and are generally not used for street except driving to and from the track.
I don't know the specifics of BMW stock pads. They're probably good to around 500 or 600 degrees.
      08-02-2012, 06:25 AM   #78
BMW86
I think so. I need a dual purpose pad for the street and occasional track day. 60 and 70 pads are not suitable for this but great on track.
      08-02-2012, 09:32 AM   #79
GaryS
2009 135i  [6.50]
Ferodo 2500 has an excellent rep for holding up on track compared to other street/track pads. But I guess it can be noisy in some cars.
Hawk DTC-30 is even tougher on track and has a ton of stopping power. It can handle 1200 degrees, which is enough for 3 of the 4 tracks I run at. Reviews say DTC-30 is noisy in most cars, but for some reason, it's quiet in my car, but DTC-60/70 are quiet in my car too - I guess I got lucky somehow.
      08-02-2012, 10:22 AM   #80
HP Autosport
Drives: F80 M3
Depends on which Hawk and Ferodo you are comparing. DS2500 is better than HP+ and full race pads will be similar with Hawk being better overall.
      08-02-2012, 01:52 PM   #81
My135
Drives:
Excllent pad (I had them on my car), except the annoying chunking (which can be fixed with back plates) and squeaking noise.
      08-02-2012, 08:25 PM   #82
Nugget
Nugget's Avatar
650
2011 BMW 135i  [10.00]
Is this referring to the Ferodos?
If so what backing plates should be used with them?
      08-02-2012, 08:46 PM   #83
GaryS
2009 135i  [6.50]
Haha I just answered this in the other thread. Reuse the BMW backing plates with the new pads. If you're doing the work yourself, you'll know what I'm talking about when you see it. If a shop is doing the work, just tell them to reuse the BMW backing plates with the new pads, front and rear.
      10-04-2012, 09:38 PM   #84
Boosted_N54
Boosted_N54's Avatar
180
Drives: 135i N54
how much do these Ferodo DS2500 for the front and rear
      10-04-2012, 09:57 PM   #85
HP Autosport
Drives: F80 M3
Link to more details and prices:
http://www.1addicts.com/forums/showt...ghlight=Ferodo
