      05-23-2011, 10:28 PM   #1
rzm3
Moderator
rzm3's Avatar
307
Drives: E92 M3
Arrow 1M vs. M3 Suspension Comparison
Just a little contribution for the 1M owners. Any mistakes please let me know
      05-23-2011, 10:31 PM   #2
///1M
Drives: On a good day, AW 1M coupe
Ok, I'm impressed.
How did you go about doing this?
      05-23-2011, 10:37 PM   #3
Dan Parker
Drives: 2012 Golf R
This totally explains why the 1M is so great!
Thanks much!
Dan Parker
      05-23-2011, 10:41 PM   #4
MDORPHN
Drives: AW 1M
Dan's photos showed that the rear springs are the same (as also indicated in your diagram), and your diagram shows that the front springs are also the same.
Other reports, however, have suggested that the 1M has different spring rates due to its lighter weight.
Do we now believe that the differences are limited to different shocks and sway bars?
Thanks.
Neil
      05-23-2011, 10:42 PM   #5
MrRoboto
Drives: VO 1M
Well done! Agree with Dan, this is why this thing is so good.
      05-23-2011, 10:43 PM   #6
blacknbean
Drives: e92 335i
parts bin car ftw!
      05-23-2011, 10:46 PM   #7
rzm3
Moderator
rzm3's Avatar
307
Drives: E92 M3
Thanks.
Neil
I have not yet had a chance to compare the springs. From Dan's post, the rear springs appear to be the same.
Keep in mind that for each car, several springs combinations are possible depending on your options. This is why spring part numbers are not listed on online catalogs.
      05-23-2011, 11:28 PM   #8
mPlasticDesign
mPlasticDesign's Avatar
332
Drives: 2011 E90 M3 Comp Pkg Only
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwr'
Awesome!
      05-23-2011, 11:30 PM   #9
DiavelM3
4 Star General -Twilight Zone
DiavelM3's Avatar
Drives: '11 E92 M3 ZCP
Originally Posted by blacknbean View Post
parts bin car ftw!
I take it this is a good thing? Aren't you a parts bin (perhaps they are from two different cultures) from your mommy and daddy?
What better car to have parts from, then the M3??
      05-24-2011, 06:28 AM   #10
elitt13
elitt13's Avatar
France
44
Drives: BMW Serie 1///M Coupe
2011 BMW 1M coup  [0.00]
2007 335i  [0.00]
well done !!!great thanks !!
- Srie 1 ///M BSM -
      05-24-2011, 07:37 AM   #11
Dan Parker
Drives: 2012 Golf R
I'm not sure I follow this statement. What options are you talking about? Do you mean oem or aftermarket? If it's aftermarket I don't expect to see anything out for a little while since the car is just a few weeks since release.
Dan Parker
      05-24-2011, 10:18 AM   #12
rzm3
Moderator
rzm3's Avatar
307
Drives: E92 M3
OEM. From talking to BMW parts guys, springs obviously differ between, say, competition pkg or std suspension. They can also change based on the options you choose, i.e. premium stereo.
      05-24-2011, 11:13 AM   #13
DriveHard
DriveHard's Avatar
Colombia
70
Drives: X1 and R58 JCW
BMW oem spring application are taken from a master list of options to attach to the vehicle. There are lots of different springs to choose from and depending on the options, the spring rate changes..
for instance.. if you pick nav and high end stero on the same car, the springs are a different part Number, meaning they are different in some way.. It has long been discussed that the more options the more spring rate the car needed so if you want high spring rates, pick a spring that has all the options ticked off next to it.
The "M3" marked springs are from an M3, we just dont know which one ( or with which options, or lack there of )
