      06-11-2011, 11:37 AM   #1
M3Sweet
M3Sweet's Avatar
Drives: 2011 VO 1M & 2009 BMW 335iX
Should we "mod" the suspension
I had a Dinan stage 3 suspension on my E46 M3 and thatw as a significant improvement on the road and track.
The reviews I have read have called the 1M stock suspension perfect for road and track
Should this car's suspension be replaced as new?.. opinions please...
2011 1M VO | StopTech Trophy BBK | Eisenmann Performance Exhaust | ESS TUne | 3M Protective Coating | CDV Removal | Front Sway Bar | KW Variant 3 Suspension | Vorshlag Camber Plate | Rogue Engineering Short Throw Shifter
      06-11-2011, 11:42 AM   #2
DiavelM3
4 Star General -Twilight Zone
DiavelM3's Avatar
Drives: '11 E92 M3 ZCP
I think that depends on the owner and your intentions? If you plan on tracking the car, the current suspension may not be right for you. If you use it for a DD, you may find the OEM suspension just perfect.
Plus, from the sounds of it, this car may be quite the collector car some day...
      06-12-2011, 03:13 PM   #3
spiderz17
Not a BMW Insider
spiderz17's Avatar
Drives: E46M
http://www.1addicts.com/forums/showthread.php?t=540565
Here's a good start for you. "Perfect" for the track is probably not exactly correct, but I think the poster in this other thread is probably pushing it quite a bit harder than most other folks would on a track. Bottom line: if the car is a DD with an occasional track day, it's probably good like it is. If it's your track machine, you'll probably want to upgrade the suspension.
      06-12-2011, 08:42 PM   #4
Dan Parker
Drives: 2012 Golf R
It's perfect on the street but feels too soft for serious track use. I don't want to lose the street ride but plan on suspension that is a good compromise.
Dan Parker
      06-12-2011, 09:00 PM   #5
cooler2442
Drives: '11 135 Sport DCT
Send a message via AIM to cooler2442 Send a message via Skype™ to cooler2442
Yes get the full M3 suspension from Harold @ HPAutowerks and it turns into a different car.
      06-12-2011, 10:19 PM   #6
Justin(OKC)
SMYLMKR
Drives: 2011 E90 M3, 1988 M3, 2015 X1
I totally agree on a 135i. But the 1M already has the full M3 suspension. I think good dampers and higher spring rates would still be a big benefit. Also, you can lower the car so it just looks better, too. Everyone's different, though. Stock is by no means a "bad" setup
2011 E90 M3 - Alpine White/Fox Red Extended/Carbon Leather
Premium/Convenience/Cold Weather Package - Competition Package - M-DCT - Sunshades - EPS - BMW Apps - Sat Radio - Ipod/USB
      06-12-2011, 10:28 PM   #7
Dan Parker
Drives: 2012 Golf R
It does have more pitch, dive, and body roll than I expected but it's by no means excessive. To me, the car gets a lot of it's front end grip from the front suspension travel. Initial turn in has so much bite that you begin to think it will not understeer, but it will at a very high limit. The diff works so well that I found I could minimize the understeer with a little abrupt throttle as soon as the front started giving up and the car would turn neutral to oversteer without delay. It really is a very balanced car that acts as if it really likes it's driver.
Dan Parker
