      07-19-2011, 11:09 PM   #1
eboosted
Peru
14
Drives: x6 5.0i xdrive 2009
Upgraded turbos for the 1M?
Are there any turbo kits available for the 1M, are those N54 kits suitables for the 1M?
      07-20-2011, 12:56 AM   #2
flux
flux's Avatar
Drives: E90 M3 LCI
2009 E90 M3  [0.00]
2007 E90 335i  [0.00]
2006 325i  [0.00]
+1
      07-20-2011, 02:13 AM   #3
BMW86
Drives: CLA45 AMG Macan S
RB turbo
      07-20-2011, 03:30 AM   #4
Tony135
Tony135's Avatar
130
Drives: 2012 BMW 135i
Rb turbos are your best bet right now and most guys are easily hitting over 500whp I believe.
      07-20-2011, 09:54 AM   #5
crzy4135i
crzy4135i's Avatar
Drives: 08 135i
I found a dyno with 443.49rwhp but it was 99 degF on the dyno and he was on 100oct. Not bad at all.
http://www.***********.com/showthrea...ot-dyno-reults
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
      07-20-2011, 11:09 AM   #6
Daniel135i
Italy
34
Drives: 2011 135i 6M, AW, CR, MSPORT
2011 135i  [5.00]
2005 SRT-4  [3.50]
Call up Turbonetics direct, im sure they can sort anyone out. And if your willing to hand over your car, im sure you'll get a free kit out of it for the price of their R&D usage.
      07-20-2011, 08:20 PM   #7
Sal@AUTOcouture
Sal@AUTOcouture's Avatar
390
Drives: F85 X5M
I'm a fan of ASR personally
      08-22-2011, 08:25 PM   #8
FazerBoy
Drives: BMW E92 M3
Does anybody know if the turbos in the 1M are the same as those in the 135i?
      08-22-2011, 08:30 PM   #9
Dan Parker
Drives: 2012 Golf R
2011 or 2012?
Dan Parker
      08-22-2011, 08:36 PM   #10
FazerBoy
Drives: BMW E92 M3
I have a 2008 135i. Are the turbos in the 1M the same as mine?
      08-22-2011, 09:05 PM   #11
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
Wow really, common guys use search before posting, it helps a lot.
The N54B30 is unchanged between the 135 and the 1M, they both use the same Mitsubishi TD03 turbos.
Don't buy ASR. They are a highly shady company. Look at the big thread on N54tuning.
RB and RD turbos are the best options right now. You'll be running 500WHP all day.
      08-22-2011, 10:04 PM   #12
MDORPHN
Drives: AW 1M
+1
Neil
      08-23-2011, 12:32 AM   #13
DooBs
DooBs's Avatar
I really have no idea how the twin scroll single turbos work so don't chew me out too much, ... buuuut would it be possible to twin turbo a 1M by using two of those
      08-23-2011, 12:52 AM   #14
bluecarbon
bluecarbon's Avatar
Drives: montego 135i
The N54 in the 1M is a bi turbo
rr catless dps, cp-e midpipe/exhaust, macht schnell drop-in, stett chargepipe with dv's, rr occ, ER Black FMIC, m3 Control arms and sway,
      08-23-2011, 12:57 AM   #15
DooBs
DooBs's Avatar
haha sorry if it came off a bit confusing, but i meant to swap out the stock normal turbos for two twin scoll turbos
      08-23-2011, 01:26 AM   #16
Nater
Nater's Avatar
Drives: a Lot
Wait, what?
      08-23-2011, 01:27 AM   #17
S.hasan546
Drives: 1M, Exige, S2k, C250, Pilot
you guys are just cruel. Time to whip out the Boosting excel sheet i had for my s2000... time to budget a upgraded turbo build for the 1M
      08-23-2011, 01:38 AM   #18
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
no you dont. Two Twinscroll turbos would effictively be a quad turbo.
and 6 does not go into 4
No it isnt. Its a twin turbo...theres a difference
Then youd have some massive issues
Originally Posted by Nater View Post
Wait, what?
Exactly. Lots of misinformation on this thread.
Dont post things as "fact" if they arent.
      08-23-2011, 05:16 AM   #19
marcel b
marcel b's Avatar
91
Drives: F31 340i
and the difference between a bi-turbo and a twin turbo is what exactly?
      08-23-2011, 08:08 AM   #20
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [5.00]
Send a message via Yahoo to adrean8j
^^^In American english a bi-turbo would be sequential instead of parallel or "twin" turbos.....kinda like Siamese twins versus actual separate identical twins (in that Siamese twins share some "piping"...LOL)
SGM was God's color and has been recalled to heaven.
      08-23-2011, 11:05 AM   #21
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
A biturbo arraignment has two different sized turbos (usually a small one for low engine speed and a large one for the upper range) that share the same exhaust piping so they are known as sequential, because the large one is downstream of the small one (several BMW diesels are bi turbos)
This is similar to the idea of a twin scroll turbo like on the N55, but bot quite as both the small and large turbo impellers share the same housing in a twinscroll. Think of a twinscroll as a tightly packaged Bi Turbo
A twin turbo has two identical turbos that get fed off of two different headers. Twin turbos on a 6 are two banks of 3 cylinders, twins on an 8 pot are two banks of 4 cylinders, etc...
And you can't simply swap turbos on the N54. The turbo housings are cast into the header. So you Either need a custom header made or the second, easier option, which is to put a more efficient turbo possible into the stock housing (this is what ASR and RB do)
But again do not give money to ASR! They are thieves!
      08-23-2011, 01:55 PM   #22
Papethova
Drives: '08 135/ '11 1M
So why couldnt you have one twin scroll on each bank of 3? twinbiturbo?
