      09-04-2011, 03:58 AM   #67
Drace1
Drace1's Avatar
15
Drives: 2011 AW 1M
Disco thanks for the pics, it helps a lot.
I think they look very good on the VO. I'll probably end up getting them for my AW 1M after a bit of running on stock sides.
      09-22-2011, 07:17 PM   #68
Nate@IND
Nate@IND's Avatar
1617
Drives: BMW
We now have the gloss sides back in stock
IND DISTRIBUTION | 866-963-4520 • FACEBOOK • INSTAGRAM • FLICKR
      09-22-2011, 11:30 PM   #69
v1k0d3n
v1k0d3n's Avatar
Drives: GLA45 AMG
Finally got mine! Was starting to worry. JK So glad to get them...that's guys...they look great!!!
      09-23-2011, 10:09 AM   #70
diegorst
Peru
Drives: 1M
My two week old BSM 1M has the Performance Kidney Grills in gloss black and the side gills in black with no tint and the car looks amazing! I will post some high-res pics as soon as I have them.....great work from IND and amazing service + delivery!
Diego RdS - Lima, Perϊ
2011 /// 1M Coupe - BSM
      09-23-2011, 10:40 AM   #71
Drillslinger
Drives: BSM 1M / R53 / E91
What's the word on the CF pieces?
Vorsprung durch Gas Geben!!
172 of 740
      09-23-2011, 11:25 AM   #72
Aussie_in_London
Aussie_in_London's Avatar
Drives: 1M, i3 & track built Astra OPC
Mine grew legs and walked
      09-24-2011, 04:03 AM   #73
scaramanga
Drives: The one and only 1M
Originally Posted by diegorst View Post
My two week old BSM 1M has the Performance Kidney Grills in gloss black and the side gills in black with no tint and the car looks amazing! I will post some high-res pics as soon as I have them.....great work from IND and amazing service delivery!
Look forward to the pictures. I have a BSM car with the black grilles and really interested in the black side markers
      09-24-2011, 05:15 AM   #74
Jezzer
Drives: Series 1 m coupe
Ordered the cosmetic pack(grilles and side indicators) for mine yesterday. Went for the clear lenses, just need a car to fit them to now
      09-24-2011, 08:08 AM   #75
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
Nate, finally received my side and front grills (look awesome) ....... how about an update on your "germany trip" with some pics ...... assuming you had a great time!
      09-28-2011, 04:14 PM   #76
b33g33
Give '///M' Hell!
b33g33's Avatar
Drives: Einser Rex
So, both the side markers and the grills just snap in?
Also, any update on the CF version?
The 1 series M is the most badass, coolest, sickest BMW to debut since the 1988 M3. The E30 M3 finally has a successor. Please welcome the stupidly fast, wickedly tempered, awkwardly named, possibly perfect little son of a benchmark - Automobile Magazine, August 2011
      09-28-2011, 11:33 PM   #77
silvs
Drives: 1M VO
Just put one of mine in today. Took a lot longer than I anticipated. It takes quite a bit of grip strength and patience to get them out and then back in. I actually had to strip off the paint layer on the tabs for them to fit back in.
Got one side in though, with no damage. (Tabs, plastic, wiring, etc) Just need to do the other.
      09-29-2011, 12:41 AM   #78
yemski
yemski's Avatar
Drives: 2011 1M
2011 1M Coupe  [0.00]
Hey Silvs I just got my side gills, any chance you could share some tips on how to get them out/put them in? I'd really appreciate it! Thanks
      09-29-2011, 01:05 AM   #79
silvs
Drives: 1M VO
I think there are a few posts on how to do it. On your new ones, you should see 4 tabs on top, and 4 on the bottom. Those are essentially what hold the indicator in. Then there is a lip on the very leading front edge.
What you want to do is start near the rear, and compress the tabs, pulling out. The back end will start to come free a bit. Then need to start working on the tabs closer to the front. The piece will then slip back and out.
There is a wire connection held in place by a small clip. Using something small, gently pull the clip up while trying to remove the connection. You don't have to move the clip much to free it. It seems like it is easy to break, be careful.
Reverse the process to get them back in.
      09-29-2011, 07:02 AM   #80
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
Guys, I found it hard to squeeze the sides (without worrying about busting them) so I came up with another method. I used 5 popsicle sticks and wedged them in between the tabs (look at your replacements to see where to put popsicle sticks in between) starting with the upper forward and then working towards the rear .... that creates space and then you should be able to easily squeeze/lever the popsicle stick and release the tabs for removal.
Good luck ....
      09-29-2011, 12:30 PM   #81
Nate@IND
Nate@IND's Avatar
1617
Drives: BMW
We are making a DIY today for the 1M gloss black side grilles
Here is the photos from the trip! I would love to move to Germany.
http://www.m3post.com/forums/showthread.php?t=590632
      09-29-2011, 12:51 PM   #82
D-MAK
D-MAK's Avatar
Drives: 2001 Carbon Black M3 'Vert
Wow these look incredible! Any pics of the matte black option on a black 1M?
/// 2001 Carbon Black M3 'Vert
      09-29-2011, 03:43 PM   #83
silvs
Drives: 1M VO
Curious if anyone else has had this. I only did one side (see above) last night.
Today I noticed that the indicator does not sit 100% flush with the side. It's just spaced enough that I can get a finger nail between the indicator and the panel.
I did check the other side, and it seemed to also have the same issue. A very small gap.
Does anyone have a similar issue that they are aware of? Anyone know if I should be concerned about water or something? I can't imagine those are 100% water proof stock.
      09-29-2011, 04:38 PM   #84
Jezzer
Isn't there a seal between the indicator and the wing?
      09-29-2011, 05:41 PM   #85
///M1
///M1's Avatar
Drives: Many
I got a set of these, 1 in matte and 1 in gloss. Quality is great!
If in doubt, order the matte IMO, though both version look amazing, but especially if you are planning to do dark rims in matte, it's makes for a better pairing (though the gloss matches perfectly the door trim and BMW Performance grills, so a bit if a tossup what you care more about).
Now if only I can get my car! LOL
2016 Porsche 981 GT4: Guards Red, LWBS, SC, full leather
      09-29-2011, 05:42 PM   #86
scaramanga
Anyone able to post some pics of the black gloss side grilles on a BSM car ?
      09-29-2011, 07:26 PM   #87
Nate@IND
Nate@IND's Avatar
1617
Drives: BMW
E82 1M iND Gloss black DIY
      09-29-2011, 07:43 PM   #88
TunedM2
TunedM2's Avatar
Drives: 2016 LBB M2
^ Well now I have to get these. How many coats of paint are on them?
