      08-06-2011, 10:31 PM   #1
MDORPHN
Drives: AW 1M
Charge Pipe: Lousy Design
Just back from first day on track with my 1M.
Took it easy first session learning the car, but began pushing second session.
Coming onto the bridge straight (at Summit Point's Shenandoah Circuit), "pop." Reduced power and check engine light.
Immediately suspected the charge pipe, and -- after getting back into paddock -- I checked. Sure enough, charge pipe had come off throttle body.
10 minutes later, it is back together (with the circlip loudly snapping into place). Go back out next session, and in exact same place, "pop" (again). Same deal. Was able to repair it in 5 minutes this time.
I'm aware of several other 1Ms that have had this problem and figure that this will be (or is) a common problem with 1Ms that are tracked.
Perhaps the overboost feature and the stresses of track use puts a marginal design over the edge.
Neil
      08-06-2011, 10:38 PM   #2
Franklin Joseph
Drives: X5 - MCS - M2
i havent had this happen to me YET...but i know it'll come up sooner or later.
Other than that, how was the track day?
      08-06-2011, 10:50 PM   #3
MDORPHN
Drives: AW 1M
Pretty terrific. Wonderful brakes, steering. A bit too much understeer upon turn-in so I'll explore options for more negative camber in front. Power oversteer was almost always available and easily controlled. And, so long as I kept revs above 4,000 rpm, turbo lag a non-issue.
Also spent some time on the skidpad and car was a hoot.
Other than charge pipe (about which BMW and its Motorsport division should be embarrassed), I'm very pleased.
Neil
      08-07-2011, 12:14 AM   #4
Dan Parker
Drives: 2012 Golf R
Sounds like a job for zip ties!
Dan Parker
      08-07-2011, 12:16 AM   #5
1978.530i
Drives: BSM 1M
How does one fix this, and how much will it cost?
      08-07-2011, 10:12 AM   #6
MDORPHN
Drives: AW 1M
Perhaps, but couldn't really figure out how to fit either zip ties and a hose clamp (both of which I had with me) to reinforce the attachment.
Neil
      08-07-2011, 10:14 AM   #7
MDORPHN
Drives: AW 1M
Known problem and lots of aftermarket charge pipes available (Stett, AR, Vishnu, etc.). I'll be looking into them!
Neil
      08-07-2011, 11:34 AM   #8
Jet Mech
Jet Mech's Avatar
59
Drives: 2011 1M Coupe VO
Can someone post a pic of what this charge pipe looks like and where it comes off at. This would be great so i know what to fix once i get mine.
Thanks.
      08-07-2011, 12:02 PM   #9
MDORPHN
Drives: AW 1M
Look at part no. 5 (charge air induction tract):
http://www.realoem.com/bmw/showparts...85&hg=13&fg=20
It connects to the throttle body attached to the intake manifold.
Neil
      08-07-2011, 12:24 PM   #10
Jet Mech
Jet Mech's Avatar
59
Thanks for the info, i appreciate it. This will be the first fix i do once i get my baby in the garage.
      08-07-2011, 02:30 PM   #11
BerkTechnology
BerkTechnology's Avatar
125
Drives: Fast
Make sure that the clip is properly seated. The clip positively locks the hose in place and it would be very difficult to get the hose to slide past the metal clip.
What is the overboost psi on these cars?
      08-07-2011, 03:05 PM   #12
Z4Mr
Drives: 1M ETA JAN 2012
Surely BMW will do a recall to replace what is on-the-face-of-it quite a poorly designed part no??
      08-07-2011, 03:21 PM   #13
HP Autosport
Drives: F80 M3
Neil
Evolution Racewerks makes a nice CNC machined alum. charge pipe that is a lot more secure. It also has the optional meth bungs if you ever decide to add meth inj. to your car.
      08-07-2011, 04:14 PM   #14
Aussie_in_London
Aussie_in_London's Avatar
Drives: 1M, i3 & track built Astra OPC
Neil
A bit off the thread topic, but have you looked at your tyre pressures and tried changing hot inflation pressures by small amounts which can be used to fine tune handling?
      08-07-2011, 04:26 PM   #15
135IS
Drives: 09 LMB 135I / AW 1M
2009 135i  [3.50]
this is definately not a 1M problem because it happened to me multiple times until i went aftermarket and i havent had any problems since
LMB 135i: Gone
AW 1M: Current #211 of 220
      08-07-2011, 05:12 PM   #16
MDORPHN
Drives: AW 1M
Yes. I was checking hot temps as soon as I came off track and was even checking tread temp with a pryometer so I could be even more scientific!
I'm convinced that a bit more camber would go a long way.
Neil
      08-07-2011, 05:25 PM   #17
l888apex
l888apex's Avatar
Drives: #30/740 BSM 1M
good to hear she runs well out of the box on Shenandoah...it is a pretty technical track without much runoff. any video? if not could you post some more impressions on specific areas and the track and front/back straightaway speeds I'd appreciate it.
      08-07-2011, 05:26 PM   #18
elitt13
elitt13's Avatar
France
45
Drives: BMW Serie 1///M Coupe
2011 BMW 1M coupé  [0.00]
2007 335i  [0.00]
there are many probléme in France too
a friend has his charge pipe who have explosed after two lap tour on a track!!!
BMW must react!!!
- Série 1 ///M BSM -
      08-11-2011, 11:56 PM   #19
SamChas
ON TRACK !
SamChas's Avatar
Drives: BMW 1 series M coupé
This is the exact problem that I report maybe 3week ago ! The only way is to change it .
There is what happen
Actualy I was looking to change it for the active autowerk.
060 / 220 CA || BMW 1 series M Coupé || Alpine White||
MODZ:BMW Performance Steering, Matte Black Kidnney Grill, Vishnu Pro-ceed, Matte Black ///M Badge, Tinted Windows, Black Side Marker with Clear Tint. AFE Intake, ActiveAutowerke Downpipe, ActiveAutowerke Charge pipe With BOV kit, Black Exhaust tip, PowderCoated Wheels||
      08-21-2011, 10:12 PM   #20
TUNEDM3
Stay Ripping
13
Drives: 1M
I just got back from my first track outing with the 1m. My chargepipe actually broke, not just popped off the throttle body. In the market for a solution.
THE GOBBLER- S.O.H
      08-22-2011, 10:21 PM   #21
MDORPHN
Drives: AW 1M
Stett, AR, Vishnu, ER, Active Autowerks... Lot's of choices.
Neil
      08-22-2011, 10:52 PM   #22
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
-39
Drives: 08 AW 135i
2008 135i  [4.33]
That's crazy! I don't know why that happens to you guys and not to us non-m guys. I'm sure that we have been running higher boost!?
Perhaps the way the overboost comes on? Too abruptly?
2008 AW 135i, Whats a mod?
