      08-18-2011, 02:33 PM   #23
Sal@AUTOcouture
Sal@AUTOcouture's Avatar
564
Drives: F85 X5M
Great DIY. Going to be doing mine this week
      08-18-2011, 02:39 PM   #24
richb811
richb811's Avatar
315
Drives: 2011 E92 JZB M3, 2000 750iL
Musclez, no coding required for this?
Looks like a snappy little mod
      08-18-2011, 02:53 PM   #25
MusclezMarinara
Drives: VALNCYA
oh indeed bud!
easy peezy you know the rest
      08-18-2011, 09:26 PM   #26
hollysmac
Drives: 2011 VO 1M(1st Us car) 1of740
Originally Posted by tkbr0wn View Post
I think Ill just keep my garage remote on the little shelf in the door side storage. That's where it sat in my 135 and worked fine. I would love to do this, but I would rather spend $300-$500 on a mid pipe.
I agree. I thought I'd miss the Homelink that was in my e46 M3 but I find I have adjusted quite well. I'm more interested in getting a hitch so I can tow my tire/tool trailer. I am going down to Greensboro to get my track wheels & tires. I am not looking forward to wrestling them out of the back seat.
      08-18-2011, 11:20 PM   #27
v1k0d3n
v1k0d3n's Avatar
Drives: GLA45 AMG
think i'm going to do the homelink/passport install myself: http://www.1addicts.com/forums/showthread.php?t=433758
I really want the homelink, but with nav...I could care less about the directional indicator in the mirror.
      08-19-2011, 02:57 AM   #28
eeghie
Kind of a big deal
188
Originally Posted by analogue View Post
From my research, you need 51169192321 if you have the convenience package. This part has the 315MHz remote which is necessary for the factory alarm.
If you did not get ZCV with the alarm, I believe you can use 51169192335. This is the same (auto dim, alarm led, homelink, compass) but does not have the 315MHz remote.
These are the current part numbers with the newer low profile alarm LED. The older parts with the "clown nose" style LED should still work if you don't mind that look.
@MusclezMarinara: Thx for making retrofits look as easy as they should be!
@analogue: Thx for the research. Did anybody do an OEM alarm retrofit yet? Do tell!
Can anyone with convenience package post a picture that shows the "low profile" alarm LED?
      08-19-2011, 09:02 AM   #29
analogue
Drives: 1M, X4 M40i
The mirror MusclezMarinara installed and the part numbers I referenced have the newer low profile alarm LED. The older ones are more round, stick out further, and are lighter in color (see attached image). The old mirrors should still work, but they are not the current part for 2011 models.
      08-19-2011, 09:03 AM   #30
MusclezMarinara
Drives: VALNCYA
i think the older style clown nose is from the e46 they SHOULD all still work....mine is the 2009+ style flatter bottom nose.
      08-19-2011, 11:02 AM   #31
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
Send a message via Skype™ to Alekshop
Great job OP ...
Can you actually verify that HomeLink works ?
Also, it looks like it's a 10 pin connector according to you picture
      08-19-2011, 11:07 AM   #32
MusclezMarinara
Drives: VALNCYA
Originally Posted by Alekshop View Post
Great job OP ...
i corrected it sorry was a late night DIY
Homelink is WORKING yes
Last night it looked like my compass was not changing directions i will look into this it may just need a recalibrate.
Compass and entire mirror working well !
      08-19-2011, 09:23 PM   #33
Papethova
Drives: '08 135/ '11 1M
So how about for guys with stripped cars? Anyone gonna try this? Im curious if its plug and play also.
      08-19-2011, 09:29 PM   #34
MusclezMarinara
Drives: VALNCYA
Depends on the harness I'm assuming ZPP probably has this connector in we need someone to post a pic of his stripped harness
      08-19-2011, 09:32 PM   #35
Papethova
Somebody please!! Anyone? Bueller?
      08-20-2011, 10:57 AM   #36
Alekshop
Alekshop's Avatar
So you were able to program your Homelink with the garage door and it works ?
      08-21-2011, 05:09 PM   #37
MusclezMarinara
Drives: VALNCYA
carried my settings from my other homelink
      08-22-2011, 12:01 PM   #38
Alekshop
Alekshop's Avatar
      08-22-2011, 02:03 PM   #39
FLEX///M
Drives: 1M
2011 BMW 1M  [3.67]
Very nice! I'll be doing this shortly! I need that compass!
      08-23-2011, 10:57 AM   #40
MusclezMarinara
Drives: VALNCYA
Heres the replacement mirror for my 335 working yes
      09-01-2011, 04:59 AM   #41
ayao
Thread killer
292
Drives: 1M
Just bumping this thread to see if anyone with stripped cars have found a preexisting harness or not when retrofitting the Homelink.
      09-01-2011, 09:38 AM   #42
MusclezMarinara
Drives: VALNCYA
Id say you would need at least the harness.
      09-01-2011, 11:48 AM   #43
nola1m
Drives: 458S
I just did this this weekend to my stripped 1M and it came out perfectly. Don't freak out (like I did) when you see the retrofit harness is just a bundle of 5 wires and some connectors -- follow the steps below, take your time and it will work perfectly. There are a few threads to follow through all of this and I will try to include the links (make sure you read through everything once before you start -- it really helped me be ready):
1. You need the retrofit harness: P/N 61120434330 (this has the wires A2-A5 in the pdf in step 3 as well as the brown ground)
2. Follow these directions: http://www.e90post.com/forums/showthread.php?t=450516
3. This link (p. 11 on) tells you where to tap into the overhead console wiring: http://www.keepandshare.com/doc/4229...m-1-3-meg?da=y
4. I found this picture (from e90 post) helpful in putting the wires in the mirror plug (14292; I don't think the stripped 1M has the wires for pins 8 and 9 on this diagram): http://www.e90post.com/forums/attach...1&d=1308780520
5. Plug in, turn on and go! (You may need to start and stop the car a couple of times to get everything working)
Recap (from another post that I lost the link to):
1. Remove the old mirror and the switch unit.
2. Feed the wires of the new cable through the hole.
3. Plug the wires into X14292.
4. Plug all but the brown wire into X14288 (unplug it from the switch unit and disassemble it first).
5. Take the wire knife connector, feed an existing ground wire and the new ground wire through it, close the connector (I used a T-splice from Radioshack).
7. Install the new mirror, connect X14292 to it.
8. Replace the switch unit and plastic mirror trim.
      09-01-2011, 03:32 PM   #44
Papethova
+1million
Thanks I guess that confirms it, anyone can do this upgrade
Just wondering, did you use the clown nose mirror or the new one?
diy homelink mirror
