      08-18-2011, 08:33 PM   #1
YVES1M
Drives: 1m aw (kwv3) meisterschaf
How low should i go? Kw v3
Getting my kw v3 kit next week! I saw another member went 1" lower all over, what do you guys suggest? I think 1" in the back and 1.25" in the front...
Thanks
      08-18-2011, 09:04 PM   #2
Franklin Joseph
Drives: X5 - MCS - M2
I went with 1" lower all around (have a curb on my driveway), else i would have gone lower in the front.
Take a look at Dan P's car (with motons). I like the way his car stance looks (1.5" front)
      08-18-2011, 09:10 PM   #3
YVES1M
Thanks, are you happy with your suspension.. Drive and setup.
      08-18-2011, 09:23 PM   #4
Franklin Joseph
yup happy with the suspension. drives great on the street/highway. It gets abit bumpy on rough surfaces. I'm running with the preset settings.
I will play around with settings on my next track day.
      08-19-2011, 01:26 AM   #5
HP Autosport
Drives: F80 M3
Thanks
1" is really the max you should go unless you have short body struts and damper allowing more compression travel. KW's are standard, not short body.
KW's are also very soft and with more than 1" lowering the spring will have a tough time keeping itself off the bump cushion/secondary spring.
      08-19-2011, 12:31 PM   #6
1speedbike
1speedbike's Avatar
149
Drives: 2008 BMW 135i
I have STs (same as KWs but not stainless) and my front specs are L/R: 22 1/8" / 22" and I have about 3 inches of ground clearance up front with the 135i aero bumper. Assuming the 1M bumper gives similar stock ground clearance (a little less than the stock 135i m sport bumper), that's the lowest I'd go.. I already can barely make it into my own garage and I have to be careful on the street. It's not obnoxiously low, but I don't want to have to watch for every single little bump and expansion joint..
Year 1 of the 1
