      11-25-2011, 07:32 PM   #67
HP Autosport
Drives: F80 M3
Originally Posted by bklounge View Post
I've been doing some reading on the ets intercooler and it sounds like a really solid unit:
http://www.extremeturbosystems.com/E...tercooler.html
Michael from ETS mentioned that it doesn't require any cutting/trimming of the bumper.
No, the ETS unit does not require any trimming or cutting for the 135i 335i or 1M.
      11-27-2011, 02:04 PM   #68
z3lai
Drives: M2, Speciale, C63 BS
As for the downpipe, i'm considering between Akra and AR, which one do you guys prefer?
thanks
      11-27-2011, 03:41 PM   #69
bklounge
bklounge's Avatar
Drives: VO 1M
thanks
I've read a lot of positive things about the AR dp - as already discussed, it's available in catted and catless guise.
There doesn't seem to be detailed info on the akra dp anywhere, aside from the fact that it's available as catless only.
      11-27-2011, 05:43 PM   #70
sparoz
sparoz's Avatar
Drives: VO 1///M; Macan Turbo
I think I am leaning towards a catted option, and I have emailed AR the spec of the cat. I am thinking of getting them to possibly do on with HJS 100 cel cat. That would make it much more expensive though. Otherwise, from the fitment photos from the akra exhaust, I couldn't see any reason why the akra dp will be less perfect.
Macan Turbo - White
1///M - Valencia Orange
      11-27-2011, 06:43 PM   #71
HP Autosport
Drives: F80 M3
thanks
AR makes one of the best DP's out there right now. Zero fitment issues so far.
Akrapovic is still limited on its info.
      11-28-2011, 01:17 AM   #72
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
Send a message via Skype™ to Alekshop
We just installed Ahrapovic DPs and they are fantastic!
Very well made, 5.5lbs lighter than stock DPs (due to no cats), very easy to install, perfect fitment too
Aleks.
      11-28-2011, 01:55 AM   #73
Those DP's look pretty sweet! I think those are the first DP's that I have seen with expansion bellows too. Quality.
      11-28-2011, 05:37 AM   #74
z3lai
is there any CEL issue with Akrapovic dps?
is it compatible to the stock muffler?
      11-28-2011, 06:10 AM   #75
BMW86
Drives: CLA45 AMG Macan S
The Akra gear looks mint! What diameter are the Akra dp's?
      11-28-2011, 09:58 AM   #76
MDORPHN
Drives: AW 1M
I'm unfamiliar with the role of the expansion belows. What do they do?
Thanks.
Neil
      11-28-2011, 10:06 AM   #77
Thanks.
Neil
The "acordian belows" allow the exhaust system to grow, when it heats up. I would think DP's without them could have some leaks as the exhaust heats up or cools down. Most exhaust systems grow as they heat up. Typically about 25mm or more. Btw... I have only seen Porsche use these "acordian belows" before on their headers.
      11-28-2011, 11:25 AM   #78
MDORPHN
Drives: AW 1M
Makes sense. Thanks.
Neil
      11-28-2011, 12:10 PM   #79
ADVANT123
Drives: 2018 M3 ZCP
How much for the Akrapovic downpipes??
2018 BMW M3 ZCP
1999 BMW Z3 M Coupe Turbo
2017 Ram Rebel
2015 Porsche Cayman S
      11-28-2011, 01:08 PM   #80
HP Autosport
Drives: F80 M3
Yes, as the primary cats are removed and the secondary O2 sensors will trigger the CEL.
As Alekshop stated, the fitment is perfect so it is compatible with all oem and aftermarket exhausts.
$799
      11-28-2011, 01:41 PM   #81
Die ///M Rakete
Die ///M Rakete's Avatar
Drives: 2016 F80 ZCP 6MT
$799
GROUP BUY!!!!
      11-28-2011, 04:08 PM   #82
ADVANT123
Drives: 2018 M3 ZCP
$799
Drool.... I hope Cobb releases their accessport for the 1M soon so we can eliminate the CEL!
2018 BMW M3 ZCP
2017 Ram Rebel
      11-29-2011, 04:05 AM   #83
Alekshop
Alekshop's Avatar
No need to wait for something to come out ! Get ESS DirectFlash tune and it will take care of CEL as well as will give you a noticeable bump in hp/tq
Aleks.
      11-29-2011, 04:08 AM   #84
Alekshop
Alekshop's Avatar
Originally Posted by EIN M View Post
GROUP BUY!!!!
There won't be a GB on Akrapovic products unfortunately ...
We have down pipes in stock ready to be shipped.
Aleks.
      11-29-2011, 09:55 AM   #85
Schaffer
Drives: Various BMWs
Would be very interested to know if the Akrapovic DPs will fit on the 135. Anyone that could confirm or should fit them within the next week or so?
      11-29-2011, 12:19 PM   #86
HP Autosport
Drives: F80 M3
Yes, it is the same DP for all N54.
      11-30-2011, 01:31 AM   #87
M1one1M
Drives: nothing
Aleks.
Are you able to check with Akrapovic HQ whether these fit RHD vehicles?
Thanks
      11-30-2011, 01:54 AM   #88
HP Autosport
Drives: F80 M3
Thanks
Yes, they do fit RHD cars.
