Reply
      10-31-2011, 11:22 AM   #1
MusclezMarinara
Drives: VALNCYA
Cool DIY: BMW Performance Steering Wheel Version II FLAT BOTTOM !
Here is DIY on how to install BMW Performance Steering Wheel Version II Flat Bottom.
INSTALL PDF ATTACHED !
I BORROWED SOME PICS FROM THIS USERS DIY
It is not very difficult you just need to take your time and pay attention to what you are doing, and TAKE YOUR TIME!
Tools:
1. Not very big Flathead Screwdriver
2. 16mm socket with wrench and extensions
3. T15 torx socket ( i think it is T15 but I might be wrong)
4. Very small flathead screwdriver or Small Pik
5. 10mm socket
6. Plastic Pry Tools (RECOMMENDED)
This DIY is for you just to look/read and get an idea on how it can be done. I am not encouraging you to do this installation unless you are technically inclined to do so.
I will not be responsible for anything that might happen to you, your vehicle, or anybody who might be helping you, or anything else.
Before you start taking everything apart you need to read PDF Instructions (there not included but will try to attached on here) and get familiar with it.
- Make sure you understand what goes where. After you did that, I would recommend to label supplied BMW harness with A1,A2,A3,A4,A5,A6, and A7 tags. It will be easier to figure out what goes where.
NOW LETS BEGIN
1. Make sure you have your trunk open and I would recommend also lowering your windows and leave your key away from the car (if comfort access equipped)
2. Disconnect your Battery and make sure your (-) Negative terminal will not touch the battery, I kept a micro-fiber under neath to avoid contact
3. Next remove all trim work on both sides of the footwells, use caution as the trims and clips are fragile if not taken into account for your own strength.
4. The hood release has a phillips screw and then underneath the hood latch is another phillips screw.
5. Use caution when removing the trim work as there are MANY connectors and modules in this footwell panel
6. Next remove the driver footwell covering ( 3 T20 screws or T15s I forget)
7. Then completely remove the driver footwell panel (USE CAUTION PULLING CONNECTORS OFF)
8. Next remove the passenger side foot well and side kick plate (CAREFUL there are 2 plastic tabs that hold it into place use your plastic pry tools to remove.)
9. You will then see 2 Sets of connectors BLUE & BLACK, unplug the BLUE connector
10. Next remove the connector from the sleeve.
11. Connect the 2 BLUE & RED Wires
12. Read PDF installation and remove Blue/Red wire from Pin1 and Red from Pin2. Insert A3 into Pin1 and A4 into Pin2. Now install wires that you removed from Pin1 and Pin2 into Connector E - Pulling out wires from Pin1 and Pin2
13. Connector Labeled E removing and installing the loop back loom.
14. Connecting the new harness
15. Install the control module B
16. Install the Black connector into Blue connector and then reinstall Blue connector. I used zip-tie to get all those wires together. Gotta keep it neat !
17. Next feed the longer of the 3 cables into the glove box (this cable is for the track side module small 2 PIN Round Connector)
18. Now feed the remaining 2 connectors thru the console and have them out the driver side
19. Next remove the Air Bag Module using a flat blade screw driver to reach the release tabs. Next disconnect the connectors using a small flat blade screwdriver to remove the connector security tabs.
20. Disconnect the connectors on the steering wheel.
21. Next is to remove the wheel. 16MM Bolt
22. Now we need to remove upper/lower steering column trim. Pull the upper part first. Pull it up and do one side at a time. You can use your plastic pry tools again and push it up from the inside, but be very careful and take your time.
23. Removing the Coil spring cartridge with T15 torx. Unplug Black & White small connectors on the RT side.
24.Make sure not to pull the whole assembly out of the column. Very Important. Unclip all the clips and remove just the Coil spring cartridge and nothing else. These are the clips that are holding it on the side, so make sure to unclip them
25. Bring the white connector up the steering column.
Read PDF instruction and remove wires from the Black connector (it has 6 wires in it) and insert them into A7 white connector. They are numbered 1-6 and you need to insert them the same way ... #1 from Black connector goes to #1 in A7 White connector and so on ...
26. Connect this connector and the smaller connector to the new Coil Spring.
Re-Install the Coil Spring
27. Pull the open brown and green wires to the OBDII PORT
Wires are BROWN TO BROWN
GREEN TO GREEN YELLOW
Test first before tapping!
28. Next transfer over your controls and trim to the new Performance Wheel V2
29. Re-Install Wheel - Transfer everything from your old wheel to your new PSW and install everything back. Read the PDF file. Connect black connector from the new Coil spring cartridge to the Green connector on you new PSW. The rest is the same. In PDF file it says to connect Black connector to Black but it is actually Green and not Black. Just FIY.
30. COMPLETED Simply test and re install all trim work after you have verified working.
ENJOY !!!
MusclezMarinara is offline   United_States
      10-31-2011, 12:07 PM   #2
duvinclunk
Drives: 02 M3
Great write up. I am only in the market for a 135 at the moment but I almost bought this wheel yesterday as I knew it'd be one of the first things I'd do.
duvinclunk is offline   Reply With Quote
      10-31-2011, 02:53 PM   #3
Groundpilot
Groundpilot's Avatar
Drives: 135I DCT , e92 M3 DCT,535 I
Send a message via ICQ to Groundpilot
Nice write up. How long did it take you to do this?
I had an alcantara steering wheel trim on my e46 m3. It looks and feels great, only problem is, it wears off pretty quickly.
David
Groundpilot is offline   United_States
      10-31-2011, 02:57 PM   #4
duvinclunk
Drives: 02 M3
I always wondering as well why they changed to the 'Version 2' with the large plastic cover on the top. I like the suede but the times I hold the wheel up top it'd feel awkward to be holding on to that thing.
      10-31-2011, 03:16 PM   #5
MusclezMarinara
Drives: VALNCYA
Love the wheel nice solid sturdy wheel can't wait to try the track module!
After toying with it I'd say an 1.5 hrs not a big install at all
I've done wheel removal so much I can have one off in 3 minutes haha.
The plastic at the top not sure how it will feel keep ya posted
      10-31-2011, 09:43 PM   #6
Nexus_One
Nexus_One's Avatar
Drives: 2008 135i
Is this M/T only? Because some of your pictures showed the DCT paddles behind the wheel and I was under the impression that this steering wheel only fit M/T models.
2008 135i/Navigation/iDrive/Logic7 Hifi/Premium/Cold Weather/M Sport/Auto/Lux White Angel Eyes/Cyba Matte Black Grilles
Nexus_One is offline   Reply With Quote
      10-31-2011, 09:50 PM   #7
MusclezMarinara
Drives: VALNCYA
As stated I borrowed some pics from another member yes this is 6MT
      11-02-2011, 04:02 PM   #8
Mr Kleen
teh porcupine
Mr Kleen's Avatar
Drives: 2012 135i "Nina"
Great write-up.
To install the non-electronic performance wheel would it be just steps 19, 20, 21, 28, 29?
Mr Kleen is offline   Germany
      11-02-2011, 04:28 PM   #9
MusclezMarinara
Drives: VALNCYA
Originally Posted by Mr Kleen View Post
Great write-up.
Add number 1 also anytime an airbag is removed you must disconnect the battery .
      11-04-2011, 06:59 AM   #10
Mr Kleen
teh porcupine
Mr Kleen's Avatar
any time you work on the car...
My wheel just arrived today so I have a weekend project. Thanks again for the great write up.
      11-04-2011, 07:43 AM   #11
MusclezMarinara
Drives: VALNCYA
glad i could assist !
      11-04-2011, 12:04 PM   #12
duvinclunk
Drives: 02 M3
How's it working now that you've got a few days of gripping it?
      11-04-2011, 01:08 PM   #13
MusclezMarinara
Drives: VALNCYA
Its glorious ! should be a standard OP on the ///Ms!
      11-05-2011, 02:27 PM   #14
tvl1219
Drives: white E92 m3
Anyone have an issue with the psw2 resetting every time you turn on and off the car? I have it install in an 08 e92 m3!!
tvl1219 is offline   Reply With Quote
      08-30-2012, 06:42 AM   #15
youngsyr
Drives: M3 E90 (2008)
Thanks for the great write up and sorry for the thread bump, but per the installation manual, the Performance steering wheel version II requires coding if you do not have a sports steering wheel installed, I'm confused as to what exactly is a "sports steering wheel".
Does my standard E90 M3 (2008) have a sports steering wheel or not (it's the M wheel with the four sets of buttons on either side).
youngsyr is offline   United Kingdom
      08-30-2012, 03:39 PM   #16
MaDoNiOn
MaDoNiOn's Avatar
Drives: Polo Tdi 1.9
Bootifull Nice work!
Wishlist...
Bmw 135i Convertable White...
MaDoNiOn is offline   South Africa
      09-02-2012, 05:04 AM   #17
32rulz
thanks
32rulz is offline   Reply With Quote
      11-19-2012, 02:25 AM   #18
TwinT1addict
TwinT1addict's Avatar
Drives: 2008 135i
2008 135i  [3.50]
Send a message via AIM to TwinT1addict
Hey where did you get those m guage face for The cluster panel. Looks so freaking good. Thanks in advance.
TwinT1addict is offline   United_States
      11-25-2012, 01:08 PM   #19
donsaxena
Drives: BMW 135i
I think the car is a 1M
BMW 135i Jet Black AT. Hpf intercooler, Hpf exhaust, injen intake, ER competition oil coolers, ER charge pipe, Tial BOV, AR catless DP,BMS OCC, VMR 718s 19s, BMW performance spoiler, agency power rear diffuser, slek lip (on highway somewhere), FXomar abs lip, Ohlins Suspension, All M3 bits, Cobb protuned, turner 3 clutch LSD, Escort 9500ci
donsaxena is offline   Reply With Quote
      04-13-2013, 11:16 AM   #20
Ruhel
Drives: E82
I currently have the electronic v2 wheel in my car its a dct and want to swap it into a manual will this be possible ? Or will I need to buy the wheel specific to the manual
and any tips on how I'd go about reversing the process and installing the wheel again in the manual car (I didn't originally install the wheel)
Ruhel is offline   Scotland
      04-16-2013, 08:28 AM   #21
1&done
1&done's Avatar
Drives: 2008 135i Montego Blue 6mt
2008 135i  [5.00]
2008 Mini Cooper S  [0.00]
Send a message via AIM to 1&done
My v2 wheel is for a DCT, and I have it in a manual so I can tell it works. You just need to fab some ABS plastic or something to cover the rear holes where the paddles would be...if you want, I forgot they were even there
/// AST Coilovers w Swift springs / Vorshlag camber plates / M3 suspension conversion/ VM adj. toe links / Maddad Whisper exhaust, BERK mids /P3 gauge/ Cobb AP Stage zwei + / AR catted DPs / HPF OCC / BMWP-SSK / AA BOV & CP/ Spearco FMIC / Breyton GTS-R Race + APEX ARC-8s / Wavetrac LSD/ BMWP Elec. Wheel V2
1&done is offline   United_States
Reply
performance steering wheel v2
Forum Jump
