      03-24-2012, 02:57 PM   #45
Papethova
Drives: '08 135/ '11 1M
You snip them from above and pull them out.
The hole in the center is to install them not remove them.
Once you remove them they are trash, this is not a reusable part
      03-24-2012, 08:23 PM   #46
discoboy1
discoboy1's Avatar
Drives: E82 1M VO/F30 328D
Ok thanks a lot!
2011 E82 1M VO
      04-03-2012, 01:36 AM   #47
yemski
yemski's Avatar
Drives: 2011 1M
2011 1M Coupe  [0.00]
So I have one of these diffuser's coming. Do I need to buy some of these black clips you speak of to install the diffuser? I thought they were screws?
      04-03-2012, 09:59 AM   #48
discoboy1
discoboy1's Avatar
You will need 2 clips, 1 for each side, and also I had to use 4 half inch screws that I painted black to hold the diffuser and bottom panel together.
I will post pictures later.
These clips are like pop rivets, you need a special tool to install them, or you can try using some pliers, I ended up breaking one on installation, so I suggest you buy a few extra. they are only 60 cents each
BTW the easiest way to remove those clips is to drill the center.
2011 E82 1M VO
      04-03-2012, 10:06 AM   #49
discoboy1
discoboy1's Avatar
Here are some pictures
I also had the exhaust tips powder coated black
2011 E82 1M VO
      04-03-2012, 10:59 AM   #50
Drillslinger
Drives: BSM 1M / R53 / E91
Gotta say, the more I see this, the more I like it
Vorsprung durch Gas Geben!!
172 of 740
      04-03-2012, 11:00 AM   #51
JohnCena
Drives: VO
I think your tips will fade powder coating reacts to heat and once up to operating temperature they will fade.
      04-03-2012, 11:06 AM   #52
discoboy1
discoboy1's Avatar
Time will tell... but I don't think they will be that hot, they are held by 4 metal spring clips on the exhaust tubes, there is an air gap between tips and tubes...
The guy who did the job also does motor bike exhausts, it does not seem to be a problem...
2011 E82 1M VO
      04-03-2012, 12:34 PM   #53
///M1
///M1's Avatar
Drives: Many
Diffuser looks great! Will likely go that route and I like the fins and 'open' design, will likely cure my Akrapovic fitment issue as it doesn't look like it is coming that close that to the exhaust tips.
2016 Porsche 981 GT4: Guards Red, LWBS, SC, full leather
      04-03-2012, 09:18 PM   #54
carlosii
Puerto Rico
14
Drives: 2011 BMW 1M
I have a Revozport Diffuser that I haven't installed yet. Didn't know about those clips.
Where do you ordered them? Do you have the part # for those clips?
Thanks in advance...
      04-03-2012, 11:58 PM   #55
Papethova
You can get them from your dealership's parts dept. I believe the part number is 51-11-1-944-537
      04-04-2012, 12:50 AM   #56
yemski
yemski's Avatar
Drives: 2011 1M
thanks disco I really appreciate the info and pics, IND made no mention of these clips and said to simply use the OEM screws. They said they would get me instructions from revozport but that never happened.
I take it you need those extra screws to secure the diffuser to the undertray piece. Also do you need to remove the muffler section of the exhaust to get the oem diffuser off/ revozport diffuser on?
thanks again
      04-04-2012, 12:51 AM   #57
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
Send a message via AIM to EINSER M Send a message via MSN to EINSER M Send a message via Yahoo to EINSER M
and how much are those paps?
      04-04-2012, 10:57 AM   #58
discoboy1
discoboy1's Avatar
thanks again
You do not need to remove the muffler, I only drilled out the 6 oem clips, difficult part is to remove the oem diffuser, the tabs are really tight in the bumper slots, take your time so you don't damage anything, you might want to put painter's tape on both pieces and use some plastic trim removal tool to get the tabs ot of the holes (there are 10-12 tabs total if I recall)
2011 E82 1M VO
      04-04-2012, 01:14 PM   #59
Papethova
Should be in the 20 cent range if your dealer is legit.
If you wanna get screwed check Nick Alexander in Downtown LA they will charge you about $2.50+ EACH!!! I will never get a car, parts, or service at Alexander BMW ever and I was there to buy a Mini and even discussed a new M5. Needless to say I wont be going back!!
      04-04-2012, 07:10 PM   #60
RaptorKTM
RaptorKTM's Avatar
Drives: 1 M Coupe
2011 BMW 1 M  [0.00]
Could I get a quote on the Revo diffuser + Ground Effect Panel. Also does the Revo Logo on the back of diffuser come off, or does it even come mounted. Id prefer not to have a revo logo on it.
      04-04-2012, 10:51 PM   #61
-Z-
Drives: Black Pyrat
discoboy, thanks for the pictures. It looks good on a VO, but I will not be doing black tips on BSM.
      04-05-2012, 10:26 PM   #62
yemski
yemski's Avatar
Drives: 2011 1M
thanks! that's what I was hoping
      04-08-2012, 12:05 AM   #63
wkndwrrr
wkndwrrr's Avatar
Drives: 1M
Does the hood require custom hinges? Or will it work with no modifications?
      04-08-2012, 04:13 AM   #64
Mdawood
Mdawood's Avatar
-11
Drives: vo 1m
Logo comes off- its a thick sticker. U can peel it off by hand. Then just use an adhesive remover for the remaining glue. (goo gone etc)
      04-14-2012, 02:12 AM   #65
jfly77
jfly77's Avatar
Drives: 2011 BSM 1M
Where else to price compare and buy?
Anybody found any other US dealers carrying the full revo raze line or is IND the only game?
I think the splitter price is decent while the roof spoiler seems too high.
Link to official site http://1m-raze.revozport.com/1mfront_splitter.html
Found 2012 msrp sheet has most of the raze full line http://www.revozport.com/fullpricelist.htm
BSM 1M, HK upgrade, angel eyes blue,
AFE dual CAI.
SemperFi
      04-19-2012, 02:30 AM   #66
DeeboSTI
Drives: 1M
PLease PM price for rear diffuser & lower panel shipped to England - U.K
