      01-04-2012, 02:56 AM   #1
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
Send a message via Skype™ to Alekshop
✪ Alekshop | 1M Adjustable Camber Plates
Adjust it how you like it !
Now you can adjust Camber and Caster while keeping the stock suspension setup.
Ground Control has developed a very high quality product that allows you to set your car for the track in just a few minutes.
BMW 1M Camber / Caster plates feature over 26mm of total camber adjustment with the ability to make corrective caster changes to equalize side-to-side caster in the stock position.
Unlike the other camber plates on the market, Ground Control develoved a street version that offers replaceable waterproof German axial load bearings, more durable urethane bushings, less deflection, and a smooth silent ride on stock or stock sized aftermarket springs.
Ground Control camber plates are also engraved with the markings which can be used to locate the plate in the stock position for easy, repeatable, adjustment from street to track and back. All components are anodized or zinc plated for corrosion resistance.
It will be a great addition to KW V3 kit if you didn't get a ClubSport version.
You can place your order on our website here - 1M Ground Control Camber Plates
If you have any questions please feel free to contact me directly.
Aleks
✆ 925.609.4559
info@alekshop.com
@ www.alekshop.com
      01-06-2012, 03:08 AM   #2
Alekshop
Alekshop's Avatar
Here is a set of 1M Ground Control Street camber plates being installed on 1M with stock suspension.
We have them in stock, ready to be shipped.
      01-09-2012, 02:28 AM   #3
Alekshop
Alekshop's Avatar
Here is a set of GC Street camber plates installed with KW V3 coilovers.
We have both GC Camber Plates and KW V3 kits in stock, ready to be shipped!
Please feel free to contact us.
Aleks.
      01-09-2012, 07:30 PM   #4
dean_g
dean_g's Avatar
Drives: MW F80 M3
Pardon my noobness, what exactly does this do? Lowers the car?
      01-10-2012, 12:36 AM   #5
Alekshop
Alekshop's Avatar
Adjust camber and caster settings.
      05-09-2012, 06:31 PM   #6
Blue55
Blue55's Avatar
32
Drives: 1M
What's the most negative camber one might expect on a stock suspension setup? Is it relatively easy to adjust when I'm not on the track?
      06-02-2012, 11:44 AM   #7
Alekshop
Alekshop's Avatar
The CG plates go to -2.5 . You can adjust it anytime ut you would need to re-align it as well like with any other adjustable camber plates. You can mark your stock and track settings and get it really close but alignment is suggested.
