      09-25-2012, 09:34 AM   #133
T1T2GRE
CW2
T1T2GRE's Avatar
Drives: 1SMC - traded away
2011 BMW 1M  [3.00]
Originally Posted by 1Marc View Post
Hi all,
I live in Houston and find the Parked Car vent one of the coolest hidden gems. It circulates the air in the car for 30 mins to help keep the interior cooler. This might be on other models, not sure as this is my first Bimmer. Here is a quick reference on how to get to it and set it with the manual page numbers.
Menu
Settings
Climate
Set the time you estimate being back at the car and cheek the box
Check activate parked car vent
Pages 109-110 in US manual.
Marc
Just checking back in on this thread. I like seeing what things other folks have discovered.
Re: the vent. Is this just if you have Nav to control? Not sure where I would be able to select this.
Good-bye, ol' Paint...
      10-11-2012, 09:44 AM   #134
Artemis
Moderator
Artemis's Avatar
Belgium
7651
Drives: BMW M2 (MG 6MT)
Check for these under the passenger seats...
Size:  32.3 KBName:  AirsicknessBag_1.jpg
“For ’tis the mind that makes the body rich” (W. Shakespeare, The Taming of the Shrew, Act 4, Scene 3)
      10-17-2012, 05:32 PM   #135
Artemis
Moderator
Artemis's Avatar
Belgium
7651
This one was discovered by forum fellow Tom303 (http://www.1addicts.com/forums/showpost.php?p=12850245): a hidden storage area under the trunk felt pad above the battery compartment.
Forum fellow Derek8819 pointed out that, on former 1ers, this space was used for installation of add-on modules (such as SATNAV and Bluetooth). In the 1M these devices, if chosen as option, are installed in the head unit. Hence, consider it as the fringe benefit of a secret pocket (which is eventually related to the 'drone sound' syndrome).
      10-17-2012, 05:47 PM   #136
Zuzu
Zuzu's Avatar
Drives: LBB LCI M2
Interesting... great find.. Will fill it with some sound deadening packing.
      01-01-2013, 07:18 PM   #137
Artemis
Moderator
Artemis's Avatar
Belgium
7651
Thought that the "Satellite images" feature was not operational in my SatNav version. Tried it the first days after haven taken delivery but noticed no map layout change.
However, found out that that feature is definitely operational on our SatNavs: you got to set the map scale to at least 2km/1mile.
Nice look and feel and more pleasant during drives in the dark.
When navigation map is showing:
  • click the "OPTION" button under the iDrive controller
  • select "Settings"
  • select "Satellite images"
  • click "NAV" button on the iDrive controller
  • set the scale to at least 2km/1mile
Hm, I should have read the 2012 manual (BMW 128i/135i Owner's Manual 2012 (USA), page 137 - http://www.1addicts.com/forums/showp...82&postcount=1):
"Satellite images"
Depending on the availability and resolution, satellite images are displayed in scales of approx. 1 mile to 600 miles / 2 km to 1,000 km.
      10-09-2013, 06:14 PM   #138
Artemis
Moderator
Artemis's Avatar
Belgium
7651
Would have been nice if BMW had equipped also the 1M with a boot lid opening button.
      10-09-2013, 06:29 PM   #139
ayao
Thread killer
283
Drives: 1M
Attachment 924221
US spec cars have this.
      10-09-2013, 07:19 PM   #140
Artemis
Moderator
Artemis's Avatar
Belgium
7651
No 1M only hidden gem, but those with the BMW SATNAV might not be aware of this feature: the SATNAV contains several pre-programmed journeys, called "Guided Tour".
Just select the tour you like and you're ready to go.
http://www.1addicts.com/forums/showthread.php?t=899333
Size:  17.8 KBName:  GuidedTour_10.jpg
Size:  19.3 KBName:  GuidedTour_32.jpg
Size:  19.5 KBName:  GuidedTour_22.jpg
      12-09-2013, 06:25 PM   #141
cmcgonag
Drives: 1995 325i - 2011 1M
Ok. So anyone notice (NA Cars) that when you turn the turn signal on it also lights up the city light on the interior headlight (of which the turn signal is on) for about 5 seconds and then it turns off? I never noticed it until about two weeks ago....
Also do your trunk lid buttons work on your remotes? Cause mine don't...maybe I have the valet switch off in the glove box?
      12-15-2013, 09:13 PM   #142
serial`
Drives: BMW 1M
Have you tried pressing it for about a second instead of just clicking it once? First day i got mine, I also thought my remote didnt work for exactly that reason.
edit: on the car not stalling in first: this is due to there not being a lot of torque required to keep the car moving.
As has been aptly noted, each time you select a higher gear to try this with, it gets tougher.
The minimum required amount of torque at idle rpm keeps growing for each subsequent gear you pick.
Car can't deliver that torque = you stall.
If your car doesnt do this, it will also be a pain to simply get moving from a standstill, which is exactly what 1st gear is for and why it does it so well
Not trying to have a last word here but instead give a tiny bit of insight on the actual mechanics behind it
      12-15-2013, 11:15 PM   #143
Artemis
Moderator
Artemis's Avatar
Belgium
7651
Thanks & welcome, fellow countryman.
Check whether your 1M features already in this list:
http://www.1addicts.com/forums/showp...&postcount=259
And feel free to let me know the color of your 1M, so that I can add you to this list:
http://www.1addicts.com/forums/showp...&postcount=263
      12-16-2013, 09:25 AM   #144
serial`
Drives: BMW 1M
Thanks for the welcome, my fellow BB member!
As mine is a German import and still awaiting it's new Belgian plates, I doubt it.
Though this of course means we have shifted the balance of ownership per capita a tad more in favour of Belgium again
Colour is BSM, will post in appropriate threads asap
      08-20-2014, 09:19 AM   #145
Artemis
Moderator
Artemis's Avatar
Belgium
7651
In 1Ms featuring CIC (Car Infotainment Computer) the glovebox features a USB port too, to be distinguished from the USB port under the armrest between the front seats:
  • USB port inside the glovebox: SATNAV map updates, sound import to HDD and route/itinerary import;
  • USB port under the armrest between the front seats: direct sound playback only.
Inside my car:
Location (picture of a US spec 135i glovebox, but same location on a 1M):
      08-20-2014, 09:53 AM   #146
IEDEI
Drives: L'Orange
2011 BMW 1M  [4.62]
Inside my car:
Attachment 1078624
Attachment 1078616
how do you do a route import? I've never done that but would like to. Maybe I should read the manual? lol
      08-20-2014, 10:00 AM   #147
Artemis
Moderator
Artemis's Avatar
Belgium
7651
Forum fellow "Mr Kleen" knows how to code itineraries, because he made the ones I imported into my SATNAV and they work. See: http://www.1addicts.com/forums/showp...5&postcount=24
As indicated earlier, some "Guided Tours" are pre-programmed by BMW into the SATNAV: http://www.1addicts.com/forums/showthread.php?t=899333
      09-15-2014, 01:34 PM   #148
eeghie
Kind of a big deal
187
the possibility to retrofit all kinds of factory options: Front PDC
Original link
      12-02-2015, 09:21 AM   #149
eeghie
Kind of a big deal
187
Is this one of you serious track guys, gauging the engine oil with your tongue? Or am I missing something?
Original link
      12-02-2015, 11:50 AM   #150
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Attachment 1326770
Original link
Boost gauge, though that's a pretty sloppy way of doing it. There's a grommet through the firewall to route internally.
U WOT M8?
      12-08-2015, 03:33 AM   #151
Lauting
Drives: Searching for 1M
Didn't realise there was a card holder in the centre console
      12-08-2015, 07:50 AM   #152
Artemis
Moderator
Artemis's Avatar
Belgium
7651
Yup.
      09-10-2017, 05:08 AM   #153
JP-1M
JP-1M's Avatar
Japan
82
Drives: Alpine White 1M
[...] apparently the engine is programmed to constantly keep up the revs at a minimum level of 700rpm in 1st gear during movement and maintain the constant cruising speed of 5mph or 9kph, as long as you don't interfere the movement by touching any pedal. [...]
Here's the constant speed indicated by the OBC during cruising without using pedals:
  • 1st gear cruising = 5mph or 9kph (appropriate speed for slow queuing in rush hour traffic);
  • 2nd gear cruising = 9mph or 15kph (appropriate speed for checking out available parking spots);
  • 3nd gear cruising = 13mph or 21kph (do mind that the engine does not like this);
  • 4th-5th-6th gear cruising = nah, won't try that.
And to negotiate a sharp corner during the cruising, don't brake but just push the clutch + release after the corner to let the cruising automatically resume (+ some acceleration if things go to slow to your liking).
Thanks so much for your original and follow-up posts on the subject if in-gear coasting. I have extensively used the feature in 6 months of Japan driving and the inevitable traffic. It is a clutch and knee saver I never would have known about otherwise. The last manual cars I owned were an '80s rabbit and a '71 240z. They definitely did not have this feature.
      09-11-2017, 09:26 AM   #154
JP-1M
JP-1M's Avatar
Japan
82
Suggestion for mods: this thread should be a sticky
