      02-02-2012, 11:50 PM   #1
///MbmC
Singapore
Drives: 1 series M coupe Alpine White
Akrapovic Slip-On with Wireless kit, N55 midpipes
Recorded this clip just this morning, and thought I'd post it on here since there aren't many clips of the sound of the Akrapovic Slip-On. I've had the N55 midpipes on since before, and this is running with JB4 Map 2 as well.
Stationary pulls to 3, 4, 5k rpms with valve closed and then open.
      02-03-2012, 12:08 AM   #2
///M1
///M1's Avatar
Drives: Many
Sounds great, I have a similar setup (Slip On + MadDad) and sounds just about the same. The crackle and pop (in valves open mode) is intoxicating, you captured it well here! Enjoy!
PS: Did you do before and after dynoes? I did and will post results soon
2016 Porsche 981 GT4: Guards Red, LWBS, SC, full leather
      02-03-2012, 02:00 AM   #3
bklounge
bklounge's Avatar
Drives: VO 1M
Sounds amazing man! Everyone has been raving about the open valves rarrrr, so I skipped the wireless kit purchase and went with the evolution - planning on filing off the plug when I install. Can't wait!!
      02-03-2012, 02:51 AM   #4
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
Send a message via AIM to EINSER M Send a message via MSN to EINSER M Send a message via Yahoo to EINSER M
nasty nasty nasty. awesome!
      02-03-2012, 04:14 AM   #5
e///M
Singapore
Drives: 1 Series M Coupe
Poisonous... you'll make me broke!
The backfiring really suits this car's character.
      02-03-2012, 04:38 AM   #6
Win
Win's Avatar
Drives: AW 1M
Thanks for that - been wanting a clip just like it.
      02-03-2012, 04:42 AM   #7
///MbmC
Singapore
///M1, unfortunately, I didn't do any pre and post dyno runs. The butt likes it anyhow.
It really does sound great. And I've been told it sounds even better on a drive by! I drive with the valves open mostly, except when I'm pulling into my neighbourhood at night.
      02-03-2012, 01:46 PM   #8
///M1
///M1's Avatar
Drives: Many
Yeah, if you don't have the valve control you definitely want to modify your blocking plate. It should be simply to remove the block, it is welded in a couple of spots so perhaps you can bust it right off. That was the one souvenir I was left with at hand after the install (it becomes an extra piece rendered useless as the valves replace it), quality is so good that in no way I am throwing that 'trophy'
      02-03-2012, 01:48 PM   #9
///M1
///M1's Avatar
Drives: Many
If my results are any indication, you picked up about 10whp / 8wtq. And these results were dynoing the car straight off the lift, without any adaptation, so it is perhaps higher (with the valves closed it was still a gain, but about 2-3whp/wtq less than with the valves open). I'll play with the Dynojet WinPep software and post a graph shortly showing the true delta
      02-03-2012, 03:20 PM   #10
JimPastell
JimPastell's Avatar
Sweden
17
Drives: Black 328i M-Sport F31
This is the exact same setup that I have ordered for my upcoming 1M! This video made my day. So much win!
If you're able to record a drive by clip I would be even happier
      02-03-2012, 04:57 PM   #11
Vrumpkin
Seymour J. Vrumpkin
Vrumpkin's Avatar
Drives: BMW 1M
Wow perfect!
      02-03-2012, 06:47 PM   #12
Fundahl
Drives: VO 1M, 300zx TT
Simply awesome man. Stock down-pipes? Let's hear it under some load at 6KRPM!
      02-03-2012, 06:51 PM   #13
nicoz
Drives: 1M
How did you find the N55 midpipes before installing the Akra slip-on? Are the N55 midpipes worth it?
      02-03-2012, 07:25 PM   #14
///MbmC
Singapore
I'm trying to get a HD recording done of a drive by with a friend. Will post that up once we have it!
The N55 mids definitely made the stock exhaust sound louder and more raw, some amount of crackling. Felt like the throttle response was improved somewhat.
      02-13-2012, 01:46 PM   #15
Trutchy
Drives: F80 M3
omg i was going to settle for a cheaper exhaust but after hearing that i am going to have to cancel the birds valentine present..
      02-19-2012, 04:28 PM   #16
superchargedman
Drives: The ///Mbulance: 1M AW
The price of the slip on seems to be much higher now?! Before, I saw $2k, but now 3500?! Thats pushing it just for an axle back.
      02-20-2012, 10:31 PM   #17
///M1
///M1's Avatar
Drives: Many
It was never $2K, you probably never counted the tips, which are listed separate (yet you cannot buy them as a standalone option, nor can you buy the exhaust without the tips). Always been pricey, it's the DPs that doubled in price.
      02-20-2012, 11:02 PM   #18
superchargedman
I saw it in the estimated prices I believe Harold posted. You're right, it doesn't account for the tips. Looks like borla is very likely if their prices are decent.
      02-21-2012, 07:11 AM   #19
JimPastell
JimPastell's Avatar
Sweden
17
It is actually possible to buy the slip-on without tips, I know that because thats what I did Saved me 800 euros!
Ordered N55 pipes, Akra slip-on and wireless valve. The tips will be custom made. The only thng missing is the car that will arrive in 1,5 months...
EDIT: Link to correct article numbers:
http://www.akrapovic.com/typo3conf/e..._generated.pdf
      02-21-2012, 11:47 AM   #20
Papethova
Drives: '08 135/ '11 1M
Ive tried that and been told no. Can you tell me who sold to you without tips?
      02-21-2012, 12:27 PM   #21
///M1
///M1's Avatar
Drives: Many
+2, in the US there was never a vendor that could get these split up. Akra's response was that even though there is a different part number for the tips, they use that for cataloguing purposes and you can't order just the tips, nor can you order just the exhaust as a standalone. Perhaps in other parts of the world its different?
      02-21-2012, 12:38 PM   #22
-Z-
Drives: Black Pyrat
Akra slip-on with-out tips? What tips are you guys thinking of ? I know Magnaflow tips should be good, but... if I did it, I would probably got it with the tips to match the system.
