04-01-2012, 01:55 AM | #1 |
Rep 4,995
OEM fire extinguisher and mount
Has anyone got this on their car?
http://www.realoem.com/bmw/showparts...99&hg=52&fg=95 Note that is for lhd, need to find the RHD version. Just thought it could be one of those just in case item... |
04-01-2012, 06:54 AM | #6 |
Rep 839
Raihax: I got a piece of aluminium and put it between the two front bolts under the front seat. Then attached the bracket to the aluminium and a 1kg extinguisher fits in there nicely.
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec |
04-01-2012, 07:01 AM | #7 | |||
Rep 4,995
It mounts to under the passenger seat and supposedly it doesn't get in the way of the passenger's leg. I figure having one in the cabin is a lot better then the trunk as I would be able to access it faster. I am going to get one, with meth and all better safe then sorry! Seems like the OEM one is cheap enough |
04-01-2012, 07:10 AM | #8 |
Rep 4,848
So the LHD version just punts it on the driver's seat? I thought the extinguisher needs to be reached by the driver seating down?
Macan Turbo - White 1///M - Valencia Orange |
04-01-2012, 07:13 AM | #9 | |
Rep 4,995
I was reading on the M3 forum that it seems it gets mounted on the passenger side but then I saw on another forum that it gets mounted on the driver seat. so not sure which one is correct! |
04-01-2012, 08:05 AM | #10 |
Rep 1,792
Raihax, if you are getting one let me know as well please and I'll get in on it too.
Mine is held together with cable ties when in situ! Track day special! |
04-01-2012, 09:56 AM | #14 | |
Rep 22,992
I've only seen it mounted on the passenger side. Thats mostly on MB models for some reason. I think the reason why you want it on the passenger side is JUST incase it were to come off its mounting - you don't want to loose control of your car. On my German spec e39 535i it came with a first aid kit under/infront of the passenger seat. Btw... Amazon.de sells a FEUERLOESCHER The one you want is the 2nd one called: Gloria http://www.amazon.de/s/?ie=UTF8&keyw...l_70oblz5tgt_b |
04-01-2012, 05:32 PM | #20 |
Rep 4,093
04-01-2012, 05:32 PM | #21 |
Rep 2,695
You want it on the driver's seat.
Check out the 1Addicts Drag Racing Standings and Drag Racing 101. |
04-01-2012, 05:47 PM | #22 |
Rep 4,093
I think these are ridiculously big, passengers freak I am sure when they open the door and see it, ladies sit ..... well ....... lets just say that they can't keep their knees together.
