Reply
      04-19-2012, 08:03 PM   #1
bavarianstig
Calling all TUNED N54 135i MT who track their cars...
I tracked the 135i for the first time last year with BMW CCA at VIR and let me say, I became immediately addicted. I've come a long way as a driver since then, and added some helpful track upgrades like Nitto NT-01 Rcomps, full race exhaust, vorshlag camber plates, Schroth harnesses, and Stoptech brakes with carbotech pads (the brakes are SO much better).
I have, however, stayed away from tunes because of people with STOCK cars getting the dreaded "limp mode". From what I understand, these plague the 335i more than the 135i, and the autos more than the manuals (due to the cooling design of the trans). I'm in the advanced groups and drive the 135 pretty hard every time I go out, often at 9 or 10/10 (full course VIR lap times around 2:17), yet have NEVER come close to limp mode. Highest oil temp I've seen using Mobil 1 0W-40 or Castrol 5W-30 is 260 or maybe 270.
I am looking to get a Cobb Accessport, but am hesitant bc of the fear the car won't be able to handle it without the additional installation of a second/larger oil cooler, upgraded FMIC etc.
Those who have tunes (mainly JB4 or Cobb), what has your experience been on the track? Limp modes? I also welcome any opinions on which of the tunes is best suited for those using them in road course environments (do some tend to do better job of cooling due to water pump remapping etc?) If you did have cooling issues, what helped to fix it?
bavarianstig is offline
      04-19-2012, 08:17 PM   #2
pixelblue
pixelblue's Avatar
Drives: the silver bullet
2010 135i  [4.37]
that's a very good time. nice job! any video by any chance?
pixelblue is offline   Reply With Quote
      04-19-2012, 08:31 PM   #3
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
Send a message via AIM to yandy Send a message via MSN to yandy Send a message via Skype™ to yandy
I have Cobb and run either stg2+sport or stg2+agg; Was out a Sebring a couple of weeks ago on a pretty hot two day weekend 80-88 degrees morning to afternoon. Sebring's a pretty brutal track, 3.7 miles long and hard on everything in the car. The highest temp I saw was 280 on the second day, after a longer than normal session. However I do have upgraded FMIC with stock oil cooler, 50/50 coolant/water mix with one bottle of Redline water wetter.
On tracks > 3 miles, the highest temp I see are 270 even on hot days. I have yet to limp on the track, and I run pretty aggressive out there.
How do you like your carbotech pads? I just ordered a pair of 16/12 for fronts/rears? Do you mind sharing which Schroth harnesses you're using? On stock seats?
Thanks
|| 2009 e92 M3 || Melbourne Red || DCT || CF Roof || My Youtube Channel ||
|| ESS Tuned || ACM Test Pipes || Stoptech SS Brake Lines || K&N Filter ||
yandy is offline   United_States
      04-19-2012, 08:57 PM   #4
bavarianstig
Love the Carbotech pads. I currently run XP12 in the front and XP10 in the rear, on advice from Ken KNS Brakes in NC (great brake expert, specializes in Subarus).
Fronts just finished up after about 9 hard track days, and have worked excellent. Once the rears go I'll probably do XP12 front and back. The XP16 are a bit more rotor aggressive, and I haven't had any problems with the XP12s so I figure I'll save my Stoptech aerorotors since the fronts go for $500 a set haha
bavarianstig is offline   Reply With Quote
      04-20-2012, 05:26 AM   #5
GaryS
Drives: 2009 135i 6MT
2009 135i  [3.25]
Sorry to hijack, but I want to know about your tires and harness. In return, I'll tell you about my CP-E intercooler/oil cooler and Dinan tune.
With stock coolant, I've never seen oil temps higher than 255 or water temps higher than 215 even on track days with ambient temps over 100f. This year, I'm using 70/30 water plus Water Wetter just in case.
I still do get an occasional 1 minute limp mode from the stupid "brakes overheating" thing. It happens about one out of every four track days. When it does happen, I just have to pull into the paddock, shut down and restart for it to go away.
My tune is Dinan stage 2, which supposedly has the water pump remapping, but it's also a moderate tune, like running other tunes on their map 1. I usually mix in about one-fourth or one-third race gas especially on hot days because Dinan makes a big deal about recommending it.
So what size NT01? Is it 275/35 on ARC-8s in back? That's what I'm considering. But I've seen posts about them rubbing against the chassis at the front of the wheel well.
Also, which Schroth harness and how is it installed? Thanks.
GaryS is offline   Reply With Quote
      04-20-2012, 10:27 PM   #6
1&done
1&done's Avatar
Drives: 2008 135i Montego Blue 6mt
2008 135i  [5.00]
2008 Mini Cooper S  [0.00]
Send a message via AIM to 1&done
I am running a COBB as well, I have never run it on the track past stage 1. I have also never had an issue with over heating...I do pull the cowl off though. I would recommend the COBB AP and a good FMIC.
Funny I am heading to Sebring tomorrow ^
I run carbotechs w/ titanium shims to protect the weak brembo non SS pistons. Haven't decided if I am going to upgrade the OEM brakes or swap to BBK.
GL
/// AST Coilovers w Swift springs / Vorshlag camber plates / M3 suspension conversion/ VM adj. toe links / Maddad Whisper exhaust, BERK mids /P3 gauge/ Cobb AP Stage zwei + / AR catted DPs / HPF OCC / BMWP-SSK / AA BOV & CP/ Spearco FMIC / Breyton GTS-R Race + APEX ARC-8s / Wavetrac LSD/ BMWP Elec. Wheel V2
1&done is offline   United_States
      04-20-2012, 10:56 PM   #7
int2str
int2str's Avatar
Drives: 2008 135i
Cobb here.
Had the car go into limp mode at the last track event after only 1 1/2 sessions. BUT, the car was not over-heating at all. Apparently I got a "DSC is preventing the brakes from potentially overheating" error or something along those lines.
Couldn't fix this at the track, had to abort the weekend and see the dealer next day...
int2str is online now   Germany
      04-21-2012, 09:46 AM   #8
1&done
1&done's Avatar
2008 135i  [5.00]
Originally Posted by int2str
Cobb here.
What pads where you running? Any cooling mods?
      04-22-2012, 09:24 PM   #9
1&done
1&done's Avatar
2008 135i  [5.00]
Ran Sebring today with Stage 2+ Weather was in the upper 70's/ low 80's no problems at all...which is why I run this tune.
      04-22-2012, 10:00 PM   #10
int2str
int2str's Avatar
Drives: 2008 135i
Ferodo 2500, no cooling yet (just got my F30 backing plates - not installed yet).
It's not a brake issue though. The car has no sensors to measure brake temperature. It's just the DSC not liking the additional work...
      04-23-2012, 09:53 AM   #11
Groundpilot
Groundpilot's Avatar
Drives: 135I DCT , e92 M3 DCT,535 I
Send a message via ICQ to Groundpilot
Where did you get F30 backing plates from?
David
Groundpilot is offline   United_States
      04-23-2012, 09:54 AM   #12
int2str
int2str's Avatar
Drives: 2008 135i
My local BMW dealer.
      04-24-2012, 11:28 AM   #13
Sauce
Sauce's Avatar
Drives: Montego 135
I run a JB4, had the car go into limp mode after a couple of laps in my first session last weekend (over 100 degrees in Las Vegas). Next couple of sessions I turned on the maxcool feature on the JB4 and put the heat on full blast (was at least 120 degrees in the cabin and I have a closed face helmet lol). Didn't go into limp mode again until my 4th and 5th sessions. Both of which came after about 30 min. on track (everyone left), definitely annoying to say the least, however my oil temps looked to be at about 270. Do you think this could have been the brake safety thing? I've never heard of it.
KW V3's, Sparco Pro2000's, Vorshlag CP's, JB4, Heat Wrapped Raceland DP's, aFe stg. 2 Sealed Intake, Miro 111's, Hankook RS3's 225/245 (for now), Seibon M3 CF Hood, Turner Motorsports Alum. Radiator, Big Tom IC, BMW Performance bumper.
Sauce is offline   Reply With Quote
      04-24-2012, 12:55 PM   #14
Wings0fRed
Newb
Wings0fRed's Avatar
Drives: 2008 135i
GL
I ran Sebring on Saturday the 21st as well! I had the Silver 135i (Green, novice group) - what group were you running in?
I currently am using the OEM tune (BMW Perf. Power Kit) and Cool Carbon pads w/ stock rotors and didn't have any issues with overheating anything.
Wings
Wings0fRed is offline   United_States
      04-25-2012, 09:30 PM   #15
1&done
1&done's Avatar
2008 135i  [5.00]
I came in early Sunday morning and ran just for the day. It ended up being a beautiful day. I run green as well. Let me know when you are heading back.
I am running carbotech pads w/ titanium backing pates (0.5mm) I have some slight discoloration in the rotors but as expected for the amount of heat they were taking.
For those having issues w/ over heating due to a tune, have you opened up the exhaust fully? And or upgraded to a bigger FMIC? So far the COBB has been good to me.
      04-26-2012, 03:05 PM   #16
Wings0fRed
Newb
Wings0fRed's Avatar
Drives: 2008 135i
Will do. Carbotech pads are a dedicated track pad or an aggressive street pad?
Wings
      04-27-2012, 08:23 AM   #17
bavarianstig
Cobb here.
Do you track with dynamic traction control on (DTC)? I always turn everything off bc the system is too intrusive and won't allow proper rotation during trail braking and hard cornering.
      04-27-2012, 08:24 AM   #18
bavarianstig
The Carbotech XP12/16 are dedicated race pads similar to PFC 01 or 06. They are NOT to be used on the street.
Also, what are you referring to when you mentioned removing "the cowl"? The black tray under the hood adjacent to the windshield? And how does removing it help?
      04-30-2012, 09:41 PM   #19
1&done
1&done's Avatar
2008 135i  [5.00]
^yes dedicated track pads, I'm using the 10s and 8s
I removed the air filter/ cowl when I installed my m3 strut bar awhile back and just left if off. Works like a vented hood...it's easy to take off an on. It's really hot in FL so anything to get rid of heat. Draw back is that water can easy get in so I only remove it now when I'm at the track.
"It's science" =)
      04-30-2012, 10:30 PM   #20
bavarianstig
I guess my concern is whether or not to upgrade my FMIC before I go out to the track next time (May 18-20 at VIR with PCA). I would be considering the cp-e intercooler with the additional oil cooler attachment
I want to know if I can avoid overheating while running a Cobb Stage 1 upgrade at the track with only other mods being a secondary cat delete and muffler delete (berk race exhaust, stock downpipes).
Optimally, I'd like to see how it does without the FMIC before spending $1000+ on a FMIC and install. At the same time, I don't want to have to use my stock tune all weekend after finding that after a few laps I would hit my first ever limp mode...have to show all the Porsches that 135is mean business!
      05-01-2012, 06:24 PM   #21
1&done
1&done's Avatar
2008 135i  [5.00]
I think you will be ok. I ran a stock FMIC at my first track event and was fine on stage 1 however I did have a full Berk exhaust. You can always flash it back to stock if you see the temp. raising. Check w/ Harold at HP, he recommend upgrading the radiator before the oil cooler. BMW makes smaller secondary unit along w/ a larger fan. You need wire in a bigger relay. I looked into that because I read about people over heating...I have had no issues so I am not too worried. Make sure you have had a recent oil change or check the level..I think you will be ok, like I said jk Id worry more about learning the lines vs the heat...if you're new there.
As far as FMIC, go w/ a big one that fits, and one you can get a deal on. I have a Spearco and there was some cutting involved, not so if you have a 335. Wasn't crazy but many 135 owners would shy away form it. Still, it's a great FMIC.
Report back, jealous you get to run at VIR, that's a sweet track! Enjoy!
      07-31-2012, 11:05 AM   #22
omar14711
Drives: 2008 white 135i
I us a custom tune provided by PAW in Miami. Car never limps, and with the Steet oil cooler upgrade I never see oil temps over 300 on track days. Car tuned to 403 on 93 oct. and420hp with 97 AT THE WHEEL.
omar14711 is offline   Reply With Quote
Reply
cobb, jb4, limp mode, track, tune
Forum Jump
