Reply
      04-28-2012, 09:15 AM   #1
Ky1M
Ky1M's Avatar
Drives: Black Z3-M///Coupe ,AW1M
Dinan stage 2
Hey everyone , thinking of doing the stage 2 Dinan for the extra 50 or so horses. Is it worth the 1800?
Ky1M is offline   United_States
      04-28-2012, 01:29 PM   #2
Ky1M
Ky1M's Avatar
What , nobody has the Dinan
      04-28-2012, 02:29 PM   #3
Hangtime
Drives: 2008 135i
Based on my experience with my 135i/N54 Stage 2 software, I would look elsewhere. At full throttle, my engine oscillates/surges violently making the car frustrating to drive. Dinan is aware of the problem, but have no plans to fix it per my dealer. I would guess the 1M version of the software has the same problem. If you do a google search, you will find multiple forum discussions regarding this issue.
Hangtime is offline   Reply With Quote
      04-28-2012, 02:34 PM   #4
RnmEvo9
Drives: 2008 135i
Its a good tune if you like pissing away money.
RnmEvo9 is offline   Reply With Quote
      04-28-2012, 02:48 PM   #5
tunedone
Auto Enthusiast
Drives: 2011 1M AW
I have had the Dinan Stage 2 since the day it was made available. My 1M is my everyday driver and I have tracked it 4 times since its installation. It is fantastic. I had the same tune in my 335I. I recently installed the Maddad mid pipe and the car has even more hp and torque and the response is amazing. I have had zero issues with the tune. I don't see how you can beat Steve Dinan's experience with tuning and the fact that Dinan matches the 4 year warranty. I actually needed to use the Dinan warranty support on my 335i when the fuel pump was the issue and the dealer said it was the tune. Dinan set me up with a dealership (Crevier Bmw) and they took care of replacing the fuel pump and reinstalling the Dinan II software which they are also a distributor of.
tunedone is offline   United_States
      04-28-2012, 05:10 PM   #6
BimmerMat135
Drives: 15bhp Sleeper
Real upgrade?
I'm not 100% sure on that one but the dinan stage 2 without intercooler upgrade give you 378hp and 415ft-lbs at the crank. Stock 1M have been dynoed to 331rwhp and 362rwtq so basicly the same as the stage 2 at the crank. I don't think it worth 1995$
BimmerMat135 is offline   Canada
      04-28-2012, 06:15 PM   #7
tunedone
Auto Enthusiast
Drives: 2011 1M AW
The numbers on the 1M stock has over boost temporarily. The 1M stock is equivalent to a Dinan stage 1 tune. The stage 2 changes fuel pump, oil cooler, boost, water pump ect and then lowers the boost at high revs to perserve the engine. There is no over boost because their is no time limit on the duration of increased power. I had the stock, and I drive the Stage 2 and I can tell you from my experience and 4 track days so far with 5 hours on the track each time there is a major difference between stock and Dinan 2.
      04-28-2012, 08:04 PM   #8
m3kerry
SCCA STU
m3kerry's Avatar
Drives: 335i Dinan stage 2 / 1 M
I have the stage 2 on my 335i and it has some delay if you are not brake boosting. Now, my 335i is much straight line faster than my 1M.
I have no plans to change the boost on the 1M. I can't get all the power to the ground with 295 Hoosiers, so adding more power is just not this car's issue.
Thanks to: Hixson BMW, Race-Keeper, Koni, BimmerHaus, & Hoosier
2012 SUMMER NATIONALS SCCA PRO-SOLO BONUS CHALLENGE WINNER
2012 SUMMER NATIONALS SCCA PRO-SOLO A STOCK CHAMPION
2012 SCCA DIXIE A STOCK CHAMPION
www.facebook.com/thatsrightracing
m3kerry is offline   United_States
      04-28-2012, 08:45 PM   #9
JohnCena
Drives: VO
gheyyyyy
JohnCena is offline   Reply With Quote
      04-28-2012, 11:06 PM   #10
Mr.Metak2you
Mr.Metak2you's Avatar
Drives: LEXUS LS(DailyDriver)
Originally Posted by JohnCena
gheyyyyy
? L0L, what are you trying to tell us?
Mr.Metak2you is online now   Reply With Quote
      04-29-2012, 12:34 PM   #11
Ky1M
Ky1M's Avatar
Thanks for all the help and comments. Luckily I will be able to drive a 1M with the dinan stage 2 before I purchase for my self.
      04-29-2012, 12:40 PM   #12
RnmEvo9
Drives: 2008 135i
Make sure you don't drive another 1M with a different tune as you will start to regret that decision.
      04-29-2012, 04:20 PM   #13
css008
Drives: bmw 1m
there's not a lot of love for dinan, so what tune do you guys recommend?
css008 is offline   United_States
      04-29-2012, 04:32 PM   #14
m3kerry
SCCA STU
m3kerry's Avatar
There is nothing wrong with Dinan. I have gotten great service out of them but my 335 had the software already loaded on it when I bought it. I don't know that I would have paid the money for it.
They do stand behind their product. I have seen them pay for whole engines at my local dealership, if needed.
I still don't think these cars need more power. They can;t put what they have down to the ground with r-comps on corner exit without a slow roll of the throttle. I would spend the money on some coilovers and camber adjustment before added move power. Even from a roll the fat ole Cameros are going to pull you after you up the boost. They will not out brake you or out turn you....
      04-29-2012, 04:39 PM   #15
Ian///M
Ian///M's Avatar
Drives: 1M E82
+1 to that
Ian///M is offline   Australia
      04-29-2012, 04:47 PM   #16
MDORPHN
Drives: AW 1M
Much better bang for your buck with Cobb, Vishnu Tuning Procede, or Burger Tuning JB4. Were I to go to an aftermarket tune, I'd probably go with Cobb, but all three are good.
Lot's of info on http://www.e90post.com/forums/forumdisplay.php?f=58
Neil
MDORPHN is offline   Reply With Quote
      05-02-2012, 01:43 AM   #17
///M1
///M1's Avatar
Drives: Many
+1, much better options for aftermarket tunes than Dinan IMO. Recently had work done at a former Dinan rep/shop that dropped Dinan products altogether as they could never substantiate the claimed results, and their clients were left very unhappy.
Steve knows well how to milk the 'warranty' trump card, but read some more on the E90 (and other) boards and you will see how that veil is easily pierced. Many a Dinan customers have been left stranded on the warranty claim...
2011 BMW E82 1///M: AW, ZPP, ZCV, HK, Sirius, Apps; Akra CF+Valve control, MadDad mids, K&N, Forge FMIC, P3gauge, EuroTails, Tint, CF Mirrors+Spoiler+Roof Wrap, 10mm H&Rs, IND grills+gills, xCDV, LUX AE
2008 Audi B7 RS 4: Sprint Blue, Exclusive Euro Recaro Interior, Premium+Titanium Package, EPL Tune, Stasis Ohlins MS coilovers, Milltek valved exhaust+DownPipes, Stoptech SS lines, Tint, ADR V1, Lidatek, Lamin-X, Rotiform SNA 19x10" wheels, 275/30/19 PSSs, Euro flat-bottom steering wheel, JHM SSK
///M1 is offline   United_States
      05-02-2012, 02:06 AM   #18
EINSER M
EINSER M's Avatar
Drives: 2011 E82 1M
Send a message via AIM to EINSER M Send a message via MSN to EINSER M Send a message via Yahoo to EINSER M
+2 i once pay a boatload of $$$ for a Dinan S3 package on my X5 and i will not do that again...
EINSER M is offline   United_States
      06-21-2012, 11:54 PM   #19
Triple M
Doc Rebel!
Drives: Fire Orange M3, X5M, Blk 135
For some of us stuck with the Dinan flash for now (pending warranty expiration), any idea if the tune will work with a meth kit since my new ER charge pipe comes with the bung?
Triple M is offline   United_States
      06-22-2012, 07:04 AM   #20
lcrain
Drives: BSM 1M
I am no expert, but from what I have read around here the car responds much better to meth when the car in question is running a specific meth tune. Dinan does not give you the option to switch maps at all so I don't think you will notice the typical gains of say jb4 with a meth map + meth.
That said it is essentially upping the octane so I would assume it would give you some sort of gain. I would recommend against it though. Ask over in the N54/5 engine forum, they will be better able to answer your question.
lcrain is offline   Reply With Quote
      06-23-2012, 03:59 PM   #21
RaptorKTM
RaptorKTM's Avatar
Drives: 1 M Coupe
2011 BMW 1 M  [0.00]
If you want to play it safe and have the cash, id get the dinan. However for great gains and a solid tune id get the GIAC.
RaptorKTM is offline   United_States
      10-28-2012, 11:26 PM   #22
nachob
Drives: 2011 1M Coupe
Ky1M, can you give us a followup? did you drive the car with Stage 2? How was it? Did you end up getting it?
Thanks
nachob is offline   United_States
Reply
Forum Jump
