      05-16-2012, 07:37 PM   #1
pavo335
pavo335's Avatar
-34
Drives: 3.5 wheeler
JB4135 has a stack
Edwin any word on your stack
      05-16-2012, 07:59 PM   #2
RaihaX
RaihaX's Avatar
Drives: 08' 135i
I forgot to send him some shit last night so maybe not
Sorry Edwin!
      05-16-2012, 09:05 PM   #3
woosh
woosh's Avatar
Drives: WTB n55 135i 6mt sub25k
'Stack' as on he hit the wall due to the insane amount of uncontrollable torque?
Haha hope everything is ok Edwin!
      05-16-2012, 09:08 PM   #4
luster
Drives: e90, e88
Tune stacking, something I mentioned ages ago and everybody shut down!
      05-16-2012, 09:09 PM   #5
RaihaX
RaihaX's Avatar
Drives: 08' 135i
Or stacking as in stacking pre-workout and interwork out supplements ?
      05-16-2012, 09:19 PM   #6
JB4-335
Drives: E92 BSM & E70 AW
Nothing to report as yet boys. Need my ECU version to be programmed into the firmware to allow the Flash to install. Ray forgot about me last night and COBB still haven't sent me anything.
      05-16-2012, 09:48 PM   #7
dontask
Drives: White BMW 135i
I also had issues with my Cobb/JB4 stack.
Firstly, I had troubles with the flash install because the JB4 firmware wasn't updated. It works fine once you update the JB4 to the latest March 12 firmware.
You need to ensure that the JB4 Map is Map 0 (pass through) when doing an install or map update.
Then, I also had the unrecognised rom issue. After emailing Cobb, they told me that I need update my Cobb AP to the latest BETA firmware. To do so, open your Cobb AP manager, go to updates, make sure that "Check for beta firmware" is ticked. Your ROM won't be recognised if you use the Alpha firmware.
Then you should update to the latest firmware to support your BMW.
Then you should be able to test the Cobb maps.
FTW!
Modded 135i
RHD Bumblebee
      05-16-2012, 10:22 PM   #8
woosh
woosh's Avatar
Ahhhhhhhh haha thanks luster!
Edwin, I never thought you'd run anything other than the JB... to see you adding COBB is pretty interesting lol
      05-16-2012, 10:25 PM   #9
RaihaX
RaihaX's Avatar
Drives: 08' 135i
He has seen the light ? haha jk
      05-16-2012, 10:47 PM   #10
JB4-335
LOL! I'm willing to give "MOST" things a try.
Haha Ray. Just want the COBB's back end fuel mapping so less heavy lifting on the fuel side for the JB (which is where all the magic happens) not to mention monitoring each cyclinder for advance/timing is always a bonus when pushing the car a little hard.
      05-18-2012, 07:18 AM   #11
JB4-335
Loaded up the most aggressive COBB map v401 and ran a quick log and it's running around 18-19psi on pump no meth. Way too boost happy. I'll try a more conservative map tomorrow.
      05-18-2012, 08:30 AM   #12
Tit
Tit's Avatar
Drives: 135i // R56JCW
Hey Edwin, clear your inbox!
      05-18-2012, 08:33 AM   #13
BMW86
Drives: CLA45 AMG Macan S
Sounds perfect to me Edwin. What are you trying to conserve? Those turbos love it
      05-18-2012, 09:15 PM   #14
JB4-335
      05-18-2012, 09:36 PM   #15
JB4-335
Here's two logs from COBB alone without the JB4. I think the aggressive maps are way too strong to run without meth. Boost peaks around 18.5 psi and tapers to around 14. The Sport however is a lot better timing and AFR wise (still strong IMO). Boost peaks around 16psi and tapers to just under 12. I'll have more time soon to do more thorough testing. I think it's a good tune. Nice and easy to use. Love my JB4 even more now.
      05-18-2012, 11:41 PM   #16
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
532
Drives: a black car
      05-20-2012, 07:22 PM   #17
dontask
Are you going to drop back to Cobb Stage 1 when you start stacking JB4 with meth?
Modded 135i
RHD Bumblebee
      05-20-2012, 08:56 PM   #18
JB4-335
Definitely. While I do really enjoy how quick she powers up at such low rpm on the aggressive map, it's just strange how they can do it while running 2-4 degrees of advance up top. I'm so use to piggy backs so the load, targets, boost and timing of this flash is very intriguing.
      05-20-2012, 09:30 PM   #19
pavo335
pavo335's Avatar
-34
Drives: 3.5 wheeler
did you get the meth integration bit working? any benefit of stacking iyo
      05-21-2012, 01:29 AM   #20
JB4-335
Not yet Pav. My meth setup is currently under construction.
      05-21-2012, 01:39 AM   #21
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Drives: a sleeper
Sweet jesus. Subscribed.
E82 135i M-sport: SGM/6MT/Black
      05-23-2012, 03:56 AM   #22
JB4-335
Setup the meth with the COBB and all looks good in the logs. I haven't run it aggressive as yet but will do. Currently running a Stg1 Sport map on the COBB which yields peak boost around 13.5psi tapered to around 10. Then add another 2psi on top through the JB4 and boost hits close to 16psi. Timing, fuel and targets are all perfect. Now I just need to increase the boost to around 18psi and see how it shapes up.
