FORUMS
- 5
| 05-30-2012, 11:18 AM | #1 |
![]() Drives: Black 08 135I M Sport Join Date: Apr 2012
First Suspension Upgrade
I just bought a 2008 135I with sport suspension. The car has only 20k miles on it. I would like to upgrade the suspension but I dont want to spend a lot of money. I will do the upgrades in phases. I won't be tracting this car but I do like great handling. My former car include 06 Evo MR, 08 STI. I would love some input.
THANK YOU! Steve |
| 05-30-2012, 11:22 AM | #2 | |
| 05-30-2012, 01:10 PM | #3 |
Ive had a lot of suspension setups, and most of them did not meet my expectations or needs in one way or another.
The single worst mistake to make with a suspension system (if you like stock ride comfort and bounce levels) is to install springs without new shocks, or springs with shocks designed for stock HEIGHT springs. Most people on these forums always talk about matching shock rates with spring rates, which is one consideration. The problem is, these shocks are designed for OEM height springs. Therefore, when used with aftermarket lowered springs, they are already compressed much more than stock / they are designed for because the springs are shorter. This comprimises the handling and is not ideal whatsoever. The best option for a comfortable setup that looks and rides great is a system like the eibach pro system kit which includes springs and matched dampers from eibach. These are designed specifically to match rates and height. The kit costs about 675 bucks, and rides IDENTICAL to stock in terms of ride comfort, but has slightly less bounce in it and also corners a bit flatter. Match this with a good front sway like an M3 sway bar, and you will have a very good setup for a good price. This kit isnt competition worthy, but will make your car look great, ride great, and handle a little better. This is the kit my friend had on his 135i, and what I will be putting on my new 135i. |
| 05-30-2012, 05:24 PM | #4 |
![]() Drives: a slow 2009 e90 335i Join Date: Jun 2011
It really depends on how much you want to spend. I've spent close to $4K on suspension parts and it was well worth it. I would recommend coilovers to start, then or at the same time, sway bars as already suggested. That said, a great mod is the M3 rear subframe bushings so if you are adding the rear sway bar you may as well add the bushings. GL...I wasnt going to spend much either but after each mod I found myself searching for other mods to improve the suspension.
![]() BMWCCA member |
| 05-30-2012, 05:42 PM | #5 |
If you are looking for an inexpensive suspension mod for the street, ST coilovers work well and are priced reasonable.
Here is a setup we installed at our shop ![]() ![]()
Kevin | european auto source (eas)
email: kevin@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x31 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter |
| 05-30-2012, 05:45 PM | #6 |
Moderator
Drives: 135i Silber mit/Rot 6MT N54 Join Date: Feb 2010
I think one of the best mods is installing the M3 rear subframe bushings. It not only firms up the rear end but also seems to make the front suspension work better. This will get rid of that rubber band effect when you turn the car hard into a corner. No more jiggle or wander from the rear end under power or cornering G's.
Have you thought about BMW's Performance Suspension Kit? For the 135i it comes with shocks, springs, and a front sway bar(I think?) plus all the mounting hardware. I think its priced around $1,100 for the kit. Lots of guys install the M3 front sway bar. But I think that can only increase understeer at the limit. The reason why everyone seems to like this mod is bc they get no where near the limit on the street - and the stiffer bar really cuts down on front end sway and makes the steering feel more direct. One of the Best mods for the suspension is getting rid of the RFT and going with a top tier tire like Michelin PS3's or PSS's. That was one of my best mods to date along with the M3 rear axle bushings. Dackel |
| 05-30-2012, 06:35 PM | #7 | |
N55 Commando
I am plaaning to get the BMW Performance Suspension Kit plus replacing the four subframe bushing with the M3 ones. Is this a good setup for daily driving?
PPK-Stage 2 | BMW 313 Wheels | BMW CF Spoiler | BMW CF Mirror Caps | BMW Y-Pipe | BMW CF Diffuser | Black LCI Tailights | K&N Drop-In | iCarbon CF Front Lip | LUX V3 | PIVOT-Raizin Voltage Stabilizer |
| 05-30-2012, 06:46 PM | #9 | |
1. more aggressive alignment with alignment pins pulled 2. E92 M3 front swaybar (I disagree with Dackelone's analysis above [edit: just the part about understeer at the limit]) 3. HD front control arm bushing upgrade (HPA Shop) You should do all of those for sure. But I think the biggest problem with the stock suspension is the shocks. You should upgrade them the first chance you get. If you want shorter or firmer springs at the same time, there are lots of choices. I'll add that the stock springs are already pretty stiff for street. The next biggest improvement is M3 rear subframe bushings. All that should keep you busy for a while. Last edited by GaryS; 05-30-2012 at 06:59 PM. |
| 05-30-2012, 08:09 PM | #10 |
Here's what I'm doing personally. Currently only executing stage one.
1. More aggresive alignment with Ground Control Camber Plates 2. Front control arm and Rear subframe bushing upgrade 3. Shocks or Coilover I doubt i'll ever get to 3, as my next upgrade would be on the brakes department before I'll revisit suspension. I do track the car, otherwise I would've left everything stock and save some time and $.
Ground Control Camber Plates w/ PSS. Ferrodo D2500 w/ Slotted Rotors on RBF600 Fluids.
| 05-31-2012, 08:48 PM | #14 |
On my 2011 I have:
M3 subframe bushings M3 front control arms M3 front and rear sways Alignment pins pulled for max camber (M3 arms give a bit more too) 1/8th toe out in front Replaced runflats with Star Specs = night and day difference over stock for all-around handling. With these mods the stock springs & shocks are actually pretty good for a sporty road setup - as hard as that is to believe (not sure if my opinion would be the same for the progressive springs on the 2008-10 models). Subframe bushings are not cheap (because of labour to install) but I wouldn't advise anyone to upgrade the shocks/springs before doing the bushings. The soft stockers will always compromise even the best suspension setup. |
| 05-31-2012, 11:22 PM | #15 |
Based on my experience modding a 335 and a 135 I have found this:
Street Driving and not in any order - Matched shocks / springs or coil overs - biggest bang for the buck. Now some serious time and research went into your stock suspension. Don't go with some half-assed makeshift combo like HR springs and PS shocks. There is so much more to suspension then that. Get a professionally matched set up or a good set of coil overs. - Camber Plates, really improve handling and will let you fit bigger rubber up front. Worth every penny. - Proper size sway bar links. Do this before you buy aftermarket sway bars - Aftermarket sway bar bushings. A good alternative to new sway bars (I'm not a fan of huge sway bars) - M3 Tensioner/Wishbone. Increase camber but most importantly really improve steering feel. No more steering slop. - Rear Subframe bushings. On the street not a big deal. On the track or Auto-X sloppy bushings are the cause of more spin outs then people realize. Top notch Coil Overs are wasted without them. - Sway bars - too hyped. There is a distinct difference between real mechanical grip and less sway. Only AFTER you have dialed in the rest of your suspension should you experiment with this. - Rear M3 bits. Less deflection, but not worth it unless you are really going high end everywhere else. - LSD. By far my favorite mod.
| 06-02-2012, 06:56 PM | #16 | |
![]() Drives: 2011 SG/FR E90 M3 DCT Join Date: Dec 2010
| 06-03-2012, 05:01 PM | #17 |
Freude am Fahren
After 62k miles on the stock 135i suspension (except front M3 sway), I just this weekend added the ///M front/rear control arms, bushings, rear sway, and some adjustable Koni Sport shocks. What an amazing transformation! Without the bounce/slop, the ride is greatly improved. It's just about perfect for me.
![]() -2012 VW MKVI GTI Autobahn w/ DSG (New!) -2008 E82 N54 135i Coupé 6MT -2001 E46 M3 Coupé 6MT (Retired) |
| 06-04-2012, 07:46 AM | #18 | |
2009 BMW LeMans Blue 135i/Dinan Stage 2 software upgrade/Alufelgen SF-71s/M3 suspension pieces/Koni Sport adjustable dampers/ETS FMIC
| 06-06-2012, 11:17 PM | #19 |
![]() Drives: Alpine White 2012 BMW 135i Join Date: Feb 2012
I was planning on keeping my run-flats, but just could not live with the punishment when hitting any kind of road imperfection. I have since switched to Michelin Pilot Sport A/S Plus tires and that was an improvement, but still the car sometimes feels like a bowl of jello. It is just so soft. If I drive over a speed bump, it feels like it's gonna bottom out in the rear. I really don't want to screw up the "BMW ride" I paid for, but the car feels a little scary on undulating roads. I call it "porpoising" for want of a better word. It rocks back and forth like a rocking chair. What do I need to do to fix this, without reinventing the entire suspension?
| 06-08-2012, 08:46 AM | #22 | |
if you add new front sway and some stiffer sway bushings, it could be the answer you are looking for |
| Bookmarks |
