      10-02-2012, 04:22 AM   #67
biglare
Bulldog
biglare's Avatar
Drives: BMW & Porsche
Nom Nom Nom!!!
Need confirmation that these will fit the KW V3's please!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      10-02-2012, 05:34 PM   #68
HP Autosport
Drives: F80 M3
Originally Posted by biglare View Post
Nom Nom Nom!!!
Yes, these will!
      10-02-2012, 09:02 PM   #69
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Group buy?????
_______________________
1991 E30 M3/Brilliantrot
2011 1 Series M Coupe/VO/Fully Loaded/Bloated/Stoptech ST-40 Trophy Street
      10-02-2012, 09:31 PM   #70
Blue55
Blue55's Avatar
32
Drives: 1M
I have the first (I think) production set of these. They are extremely well manufactured, make no noise and are FAR higher quality than the Ground Control units that failed on my car.
      10-03-2012, 01:06 PM   #71
HP Autosport
Drives: F80 M3
Good to hear positive feedback on the Vorshlag plates!
      10-25-2012, 02:40 AM   #72
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
Order placed. Looking forward to install next week and then three day HPDE at Thunderhill in CA. Anxious to feel the diff. Any recommendations on settings? Look through other threads but wanted to see if there were other thought here.
      11-04-2012, 11:47 AM   #73
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
Install new camber plates on This past Friday. So far love the added negative camber's improved turn in. Definitely no increased harshness or noise. This weekend is a 3 day HPDE at Thunderhill in CA. Anxious to feel the difference..
Only disapointment is that the pieces are so beautifully fabricated its a shame they are completely invisible after they're installed. LOL
      11-04-2012, 12:32 PM   #74
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
What tire and wheel setup will you be using?
      11-05-2012, 03:05 PM   #75
HP Autosport
Drives: F80 M3
Some installed photos would be great to share here!
      11-08-2012, 03:58 AM   #76
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
I will be running Toyo 888's on ARC-8's 9.5"x 18" w/ 265-35-18 front & 10.5" x 18" w/ 285-30-18 rear.
The stick with the stock camber was great so I'm anxious to see how much improvement with the new setup.
      11-08-2012, 04:43 PM   #77
M3 Adjuster
M3 Adjuster's Avatar
aint that the truth!
Lone Star BMW CCA Chapter Ex-president (retired 2017) , Chief Driving Instructor - LIFETIME Member # 119366
If you don't STAND for something.. you'll FALL for anything
Past: 1991 BMW E30 M3 street car ; 1988 BMW E30 M3 track car
      11-08-2012, 11:30 PM   #78
modernbeat
Motorsports Engineer
modernbeat's Avatar
Drives: Caged
Sorry I've missed this, I've been at SEMA and then had my truck stolen at an elk hunt in New Mexico on the way home.
We've been setting the front at 2.5 degrees. You can go more, but with the soft stock springs we've found that the 2.5 is appropriate and gives good tire wear.
Jason McDaniel at Vorshlag
      11-13-2012, 03:35 AM   #79
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
Track sessions at Thunderhill were great. Had several sessions between my students. Understeer gone. Outside edge wear evened out. Feel and turn in excellent.
Very very happy with the transformation even with stock springs felt very controlled.
      11-13-2012, 10:41 AM   #80
ozinaldo
ozinaldo's Avatar
Portugal
80
Drives: 1M
What other mods your car have?
      11-13-2012, 12:55 PM   #81
Mahlzeit
Drives: 1M
What camber values are you running on 'street' mode and 'track' mode?
      11-15-2012, 02:05 AM   #82
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
ARC-8's w/Toyo 888 and Maddad mid pipe. That's it so far.
      11-16-2012, 02:14 AM   #83
schnite
Drives: E82 1M
i want to buy!!!!!!!!!how can get it?
      11-16-2012, 09:08 AM   #84
ozinaldo
ozinaldo's Avatar
Portugal
80
Drives: 1M
For instance, check the web site of HP Autowerks. Their online shop should be listing it. If not, contact Harold from HP via this Forum.
      11-16-2012, 09:08 AM   #85
ozinaldo
ozinaldo's Avatar
Portugal
80
Drives: 1M
Interested to hear this as well.
      11-16-2012, 04:05 PM   #86
Blue55
Blue55's Avatar
32
Drives: 1M
I run -3.0. For daily use probably -2.5 is as much as you'd want to go.
      11-16-2012, 05:29 PM   #87
robertm
Drives: BSM 1M
Depends on the track, tire choice, suspension settings, ambient conditions and driver. All these variables factor into the ideal setting. The proper way to do it is to take measurements using a pyrometer and pressure gauge. If you're going for maximum tire life and optimal adhesion for your entire driving stint, you really do need to take the measurements.
Short of that if the outside of the tire is not wearing more quickly than the rest of the tire then your camber is sufficient. If the inside is wearing quicker than the rest of the tire you have too much camber. A good baseline to start would be -3 deg. You are going to need a camber gauge to figure out where that measurement is unless the camber plates have some type of delineation scribed onto them.
For the street around -1.5 to -2 deg is usually about right. Street driving style plays a big part in that though. I believe factory is about -1.2 (right?) so if you drive like a pussy-cat on the street then you’ll end up wearing out the insides first with too much camber.
The short answer is there is no ‘right’ answer for camber setting for street or track. Every car and every driver is slightly different. Even with all constants the same (car,driver, susp, tires, track) the variables like track and ambient temp can require camber adjustments.
I’m probably getting way too detailed for the occasional DE style setup. For most buyers it will be a set it and forget it setting for track and street driving. Even doing this will GREATLY improve your tire life on track. The ability to get way more precise is there though and it’s a fun challenge to master for those so inclined
      11-16-2012, 06:09 PM   #88
Blue55
Blue55's Avatar
32
Drives: 1M
What he said! ^
