Reply
      06-22-2012, 09:32 AM   #1
sean96gsr
Bimmer Fanatic
Drives: SGM '08 135i Sport
135i w/ 2a87 and 3100 Codes - MIL, Reduced Power
I posted this over on bimmerforums, but I figured that I'd post it here as well as it gets more traffic. FYI:
I wanted to post up my information as a counterpoint to lots of what I found when searching here, Bimmerfest, and e90post. It's often said that people never come to the forums to post good news, and that as a result they cause hysteria. I'm here to do the opposite. Hopefully this indicates that the cam bearing ledge issue isn't as widespread as it seems.
My car threw a check engine/reduced power light while driving down the highway. I limped it home and had my friend who owns a local BMW shop meet me to check it out. He used his scan tool and we pulled 2 codes, 3100 and 2a87.
Per SIB 11 02 08 for the n54 motor, BMW advised to check for abnormal wear to the cam bearing ledge which would cause reduced oil pressure, a jammed VANOS, and these codes. My friend advised me to call BMW Roadside Assistance to pick up the car and bring it to my dealership.
At this point I was pretty upset, because the info that he gave me combined with everything I read on the forums led me to believe that the car had serious engine problems. Because the forums make it sound like this problem is very widespread, I was afraid that even if they replaced the parts it would happen again eventually.
The car was ready yesterday, and it turns out they removed both the camshafts and the ledges and found NO ABNORMAL WEAR. They replaced both VANOS solenoids because they may have been gummed up with oil particles (Defect code 1113937600). After this the issue went away and hasn't returned. The car has almost 45k miles on it and I drive it spiritedly on a daily basis. Here's the writeup:
UPDATE:
The car has another 4k miles on it since this service and hasn't shown any signs of returning - in fact, it seems to pull a bit harder throughout the RPM range according to the old butt dyno.
sean96gsr is offline   United_States
      07-12-2012, 08:52 PM   #2
Bdh821
Drives: 08 Montego 135i, 06 330xi
Send a message via AIM to Bdh821
good to know cuz my car is throwing 2A87 and was told to replace my VANOS solenoid.. Thanks for the write up
Bdh821 is offline   Reply With Quote
      07-12-2012, 09:04 PM   #3
RaihaX
RaihaX's Avatar
Drives: 08' 135i
yeah 2A87 is usually due to vanos solenoid, you can try cleaning it first, the sometimes fixes it.
If not buy new ones.
RaihaX is offline   Australia
      09-01-2012, 01:02 AM   #4
kb135
kb135's Avatar
Drives: 135i Alpine white
2008 BMW 135i  [4.00]
Anyone know which parts are needed for the job? I see the list in the OP, but out of them all, which ones? Obviously the solenoid valve, but what about the gasket, collar screw and ring? Any ideas? I just got my 2a87 code and would rather just replace...
kb135 is offline   Australia
      09-06-2012, 06:29 PM   #5
sean96gsr
Bimmer Fanatic
I think just the solenoids. Apparently they get gummed up with sludgy oil particles. The other stuff was because the valve cover gasket and camshafts were removed. I'm surprised that mine got gummed up though because I change my oil every 7500 miles.
I found a thread here where someone said to just replace them with the spark plugs every 50k miles or so.
      01-28-2013, 06:26 PM   #6
Rockstar1487
Rockstar1487's Avatar
Drives: '08 135i Coupe
OEM PART NUMBER #11367585425
get both in the intake and the exhaust. on getbmwparts.com its priced at 107 bucks not a big deal.
Was ist die fragen?
Rockstar1487 is offline   United_States
Reply
Forum Jump
