      06-26-2012, 09:03 PM   #1
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
285's in the Rear
Is anyone running 285/30-18's on Apex Arc-8 wheels in the rear?
I'm currently at 275/35-18 with PSS's and have had zero rubbing issues. It looks like I can fit 1mm extra of tire in there, but don't want to go in blind. If anyone has experience or thoughts, let me know.
      06-26-2012, 09:18 PM   #2
Clovef
Drives: 2011 135i DCT
I read about someone running that size r3 and got it on by loading the suspension and compressing the spring during instal. I think he rubbed.
2011 BMW 135i DCT M Sport, black sapphire metallic,Coral red tint, black line tail lights, back grils, BMW Performance spoiler, Apex ARC8, 235/265 Dunlop ZIIs, Ohlins coilovers w/ Swift springs, M3 front bits, Whiteline rear sub frame bushings, Vorshlag camber plates, Stoptech pads, custom exhaust, stud conversion, spacers, bms jb4, custom down pipe, bms intake
      06-26-2012, 10:11 PM   #3
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
I don't understand this. There won't be any install issue with the car jacked up to get the tire on. The question is how bad I will rub on the outside and if there is enough room.
      06-26-2012, 10:51 PM   #4
Clovef
Here is the thread.
http://www.1addicts.com/forums/showt...ght=Arc8+tires
      06-27-2012, 11:16 AM   #5
GaryS
Drives: 2009 135i 6MT
2009 135i  [3.25]
Here's a thread about 275 NT01 rear rubbing on the chassis and requiring a 5mm spacer. I also know another person who uses a 5mm spacer to keep those tires from rubbing.
http://www.1addicts.com/forums/showthread.php?p=9496900
Ignore the stuff about rubbing in front in that thread because they're talking about et38.
      06-28-2012, 02:30 AM   #6
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
Thanks for the link. Unfortunately, I'm an idiot and am going to make this work... because racecar!
After talking to Evolution Racewerks today, they confirmed that the ADVAN's 285/30-18 fit in the rear without modification if you get the offsets right. I may need 3mm spacers, and a fender roll... but we'll see!
      06-29-2012, 12:09 AM   #7
Clovef
Please post it up when you do it. Sexy sexy.
      06-29-2012, 02:27 AM   #8
Mybad135
Mybad135's Avatar
74
Drives: 2012 montego blue 135
i have 285 555rs on my apexs
1m body,helixIC,JB4 ,Seibonhood, ICarbon trunk,meth, billstein coil overs,ONE Eighty Lights,Sparta Evolution Brakes,Gintani DCT pan,VAC LSD &diff cover,PURE TURBO STAGE 2 BBS Fi R's Coming soon click on pic for build thread
      06-29-2012, 11:01 PM   #9
1&done
1&done's Avatar
Drives: 2011 VO 1M
2005 Ariel Atom 2  [0.00]
2011 BMW 1M  [5.00]
2015 T4R TRD-Pro  [0.00]
2008 135i SOLD  [5.00]
Send a message via AIM to 1&done
FYI if the tire is too big for the wheel, (which most 285s are, for a 9.5in wheel) than you would lose performance...ie turn in if you are tracking.
///1M #643 of #740
      07-03-2012, 01:24 AM   #10
cpt97m3
AutoXer
25
Drives: 2009 135i
Let me know when you try it. I was thinking of doing the same thing.
      07-03-2012, 04:02 AM   #11
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
Tires are getting mounted this Friday. Will post pics it it works.
      07-03-2012, 05:34 AM   #12
flinchy
Drives: 130i
everywhere i can find says 285 definitely fits on a 9.5... when a 305 fits on a 10.
      07-03-2012, 05:30 PM   #13
1&done
1&done's Avatar
Drives: 2011 VO 1M
2011 BMW 1M  [5.00]
Fitment is one thing, performance is another.
I am shopping for r-comps and my performance shop wants me to drop down in size for proper fitment and overall performance. I was under the impression the wider the tire the better the traction. Post pics when you get them mounted. GL
///1M #643 of #740
      07-05-2012, 07:36 AM   #14
flinchy
Drives: 130i
lip size is 1" above wheel width, then you can go 1" above that again with minimal bowing (sidewall not mushy yet)
      07-05-2012, 10:58 AM   #15
ptack
ptack's Avatar
2008 135i  [3.25]
Tires are designed for specific wheel widths. If you mismatch a tire and rim you will not get the optimal performance from the tire. Most people may not notice, but if you're competing on a track you will notice and if you're prettry far out of spec you may even manage to unseat the bead.
      07-05-2012, 12:02 PM   #16
Freon
Drives: 2009 135i
http://www.tirerack.com/tires/tirete...jsp?techid=198
http://www.tirerack.com/tires/tirete...jsp?techid=199
Tirerack lists the one Measured rim width, and a range (usually 0.5" under to 1.0" over measured).
Tirerack lists the 285/35/18 PSS as 9.5" to 11", with measured of 10".
      07-10-2012, 03:03 AM   #17
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
So rarely do I get to use this but...
Boom Shaka Laka!
285/35-18 Yokohama ADVAN NEOVA's on Apex ARC-8's
Clearance inside:
To Outside... I can't get a good image because it's very tight.
Rubber!
Conclusion:
They work, but I haven't maxed out the suspension or pulled the springs to check clearance all the way up. If there's going to be any issue, it's going to be on the outside, which can most likely be remedied with a fender roll. To keep the clearances where they're at, I'm going to replace the links with M3 variants so that there's no bushing play and check clearances while the suspension is apart in the next few weeks.
So far... slam dunk! And they ride soooo much better than the PSS's
      07-10-2012, 05:57 PM   #18
funseries
Wow nice work , I always wondered how much space is back there with the Apex's. Seems like quite a bit of room between the wheel and the strut too.. so why do I see people saying they need to add spacers and stuff to fit 265 or 275s?? Maybe it's a ride height issue.
      07-10-2012, 08:34 PM   #19
cpt97m3
AutoXer
25
Drives: 2009 135i
That looks great! Did you end up using a 3mm spacer? I have those same wheels with 275/35 Dunlops, and they fit fine with no spacer, so I was wondering if I could clear the 285 Yoks. I may try that when the Dunlops are worn down, which is coming up soon.
      07-10-2012, 09:16 PM   #20
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
No Spacer. The wheels are just bolted on.
With any kind of spacer and this setup, you will rub on the outside. It's tight.
      07-10-2012, 11:04 PM   #21
1&done
1&done's Avatar
Drives: 2011 VO 1M
2011 BMW 1M  [5.00]
Nice work! I had to run a 3mm spacer w/ my Dunlop 275/35s. I actually did a fender roll and now use a 5mm and I feel more comfortable. I noticed some rubbing on the plastic inner fender. You likey more than the PSS eh? I am kinda low and about -2.5 camber in the rear.
///1M #643 of #740
      07-11-2012, 01:09 AM   #22
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
Right now, the pics are with dinan springs, which are over an inch lower than stock, but the camber is only at -1.5 deg. It's pretty clear from the pictures I can go a bit further negative now, which I plan to do next alignment.
The nice thing about the yokos is the 30 aspect ratio rather than the 35 on the pss. I did have some minor wear on the inner liner with the 275's and -2deg camber, but now with less height on the tire, I don't expect that to be an issue.
And I'll let you know how the comparison is with the PSS next month after autox on the yokos. The PSS are great once they warm up on the track, but not great cold. The yokos are expected to be a bit better cold based on lower tread wear. Also, they are MUCH quieter as the PSS sound like hollow r-comps.
