      07-15-2012, 11:40 PM   #23
1&done
1&done's Avatar
Drives: 2011 VO 1M
2005 Ariel Atom 2  [0.00]
2011 BMW 1M  [5.00]
2015 T4R TRD-Pro  [0.00]
2008 135i SOLD  [5.00]
Send a message via AIM to 1&done
What size are you running up front 255/35?
///1M #643 of #740
      07-16-2012, 12:25 PM   #24
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
Yeah, I'm at 255/35 in the front, but don't use this as a great reference point.
I have the ER widebody kit on my car and can fit up to 285/30-18 on the front now, I just don't have the correct offset wheels to do so. Ideally, without modifying the body you can fit 255/35-18's on the front without m3 control arms (hd bushings ok) and you can get 285's in the back with no fit issues.
      07-17-2012, 02:37 PM   #25
1&done
1&done's Avatar
Drives: 2011 VO 1M
2011 BMW 1M  [5.00]
IC. I like the wide body kit. Was considering it but wasn't sure about the rear not matching the vendors 100%. Would love to see more pics
///1M #643 of #740
      01-23-2017, 05:03 PM   #26
aroonkl
At the end, all work out, anything rubbed?
Did you need to roll fenders?
Originally Posted by fboutlaw View Post
So rarely do I get to use this but...
Boom Shaka Laka!
285/35-18 Yokohama ADVAN NEOVA's on Apex ARC-8's
Clearance inside:
To Outside... I can't get a good image because it's very tight.
Rubber!
Conclusion:
They work, but I haven't maxed out the suspension or pulled the springs to check clearance all the way up. If there's going to be any issue, it's going to be on the outside, which can most likely be remedied with a fender roll. To keep the clearances where they're at, I'm going to replace the links with M3 variants so that there's no bushing play and check clearances while the suspension is apart in the next few weeks.
So far... slam dunk! And they ride soooo much better than the PSS's
