Reply
      06-29-2012, 12:48 PM   #1
tchelo_rp
Drives: 1M Black - 11/12
Clutch delay valve - HP Autowerks
Guys,
I don't know if this topic was already posted, but...
I was seeing about clutch delay valve, does anybody here have this installed??What's it for?Worth it?Difficult to install??
Thanks...
tchelo_rp is offline
      06-29-2012, 02:54 PM   #2
sluflyer06
Drives: 2008 135i MT
Have it.
It makes the control of the clutch feel more connected with pedal movement so you eliminate that sloppy feeling of the clutch engagement as your nearing what should be full engagement. You don't get that momentary feeling like the clutch isn't grabbing when your foot has already left the clutch pedal.
Completely worth it.
Took me about 10-15 minutes on ramps including bleeding with a couple basic tools.
08' 135i MT || Cobb Stage 1 'Aggressive' 4.01 Map | BMS DCI | Berk Mid Pipes | Maddad Eurosport Axleback | E93 FSB | M-Sport Black on Black | CDV Delete ||
sluflyer06 is online now   United_States
      06-29-2012, 11:49 PM   #3
CarJunkie
Drives: Valencia Orange 1-Series M
Great info in this thread . . . You can modify your own CDV.
http://www.1addicts.com/forums/showthread.php?t=558362
CarJunkie is offline   Reply With Quote
      06-29-2012, 11:55 PM   #4
Moderator
Drives: 135i Silber mit/Rot 6MT N54
Arrow cdv delete DIY...
CDV Delete/Replacement DIY
http://www.1addicts.com/forums/showt...cdv+delete+diy
Dackelone is offline   Germany
      06-30-2012, 01:24 AM   #5
CarJunkie
Wow, even better.
Thanks!
      06-30-2012, 01:27 AM   #6
Pave Dew
Drives: E91 LCI 335i 6MT
Send a message via Skype™ to Pave Dew
CDV
Guys,
Be careful here as CDV upgrade on non M cars is definitely worth doing. However, on M3 at least the CDV is full bore. Assuming 1M is the same then CDV swap out would yield little or no benefit.
I upgrade to an M3 CDV on my e91 335i and difference in clutch feel was night and day.
However, clutch pedal stop mod is worth doing to reduce the clutch travel.
I fitted the BMS one and it's good as its got packers so as you can adjust to best suit yourself and make sure there's no dragging of the clutch.
Just my 2 cents worth.
Cheers,
Dave
Pave Dew is offline   United Kingdom
      06-30-2012, 07:20 AM   #7
SDD
SDD's Avatar
Drives: BMW 1M
It does make a difference. Smoother shifts, better launches and rev matching.
Good enough for me!
VO
SDD is offline   Reply With Quote
      06-30-2012, 08:37 AM   #8
CarJunkie
There are lots of testimonials regarding benefit on 1M. I have driven manuals for 22 years and never had one make me feel like a retard until now. (first BMW)
In the DIY thread above, there is a nice photo through the heart of the CDV, and there is definitely a restriction, possibly 1mm or so.
      06-30-2012, 10:40 AM   #9
Moderator
Originally Posted by Pave Dew View Post
Guys,
Cheers,
Dave
I have seen some post on the M3 forum where the early e9x M3 did not have a CDV restriction inside the adapter/valve. While later cars DID! I know M cars in the e/36, e46 and e39 M5's had a cdv. So... I think we need to see some testimonials first. But I suspect bmw puts these crappy CDV's on all their cars - including M cars. And including the 1M.
This is such a worthwhile must have mod that its worth having a look! You can not tell until you get it all apart though. Even so... its worth the effort.
      06-30-2012, 11:20 AM   #10
clived
clived's Avatar
Drives: Evolved 1M
Surely a "full bore" clutch delay valve is an oxymoron? No restrection = no delay. Assuming the 1M doesn't have a CDV is somewhat at odds with the photographic and in-person evidence of many here ;-)|
2011+: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Comfort Access, Auto−Dim, Elec Seats + Memory, Lumbar & Heating, PDC F+R, Xenons + Adaptive, Cruise, Nav Pro + Assist & Online, Voice Control, Bluetooth, DAB,6 Disc, Prof Hi−Fi (L7), USB/audio interface, BMW Performance Carbon Fibre interior, Evolve OBD remap - 390bhp. Also in the family: Land Rover Defender 50th Anniversary 4.0 V8, 11 Mercedes E Class Cabriolet Sport.
clived is offline   United Kingdom
      06-30-2012, 04:38 PM   #11
Pave Dew
My suggestion fella is view the parts side by side, as I did when I did the swap out.
Further, I have driven a friends 135i with the CDV deleted.
Clutch felt the same as mine with M3 CDV installed.
If in doubt just delete the CDV. I kept CDV as my car is still under warranty.
      06-30-2012, 05:04 PM   #12
ozinaldo
ozinaldo's Avatar
Drives: 1M
In fact, I really don't have much issue with the way 1M clutch operates (maybe because I did not experience the other way) but I could always use shorter clutch travel with that BSM clutch pedal stop unit. How easy is it to install, any downsides?
ozinaldo is offline   Chile
      06-30-2012, 05:20 PM   #13
Pave Dew
Clutch stop on e91 took 5 mins to install including removal to adjust the packers.
Simple and effective
      07-01-2012, 12:18 AM   #14
Papethova
Papethova's Avatar
Drives: '08 135/ '11 1M
Ive personally tapped out the restriction in the CDV of the 1M. Its identical to the CDV in a 135.
FYI I have tapped out more than one 1M CDV so it isnt a lone data point in my experience.
Papethova is offline   Reply With Quote
      07-01-2012, 01:30 AM   #15
Pave Dew
From reading the post above, seems like 1M CDV is more akin to non-M CDV than the one fitted to an M3.
      07-01-2012, 08:58 PM   #16
///M1
///M1's Avatar
Drives: Many
+1, did tap out the CDV on my 135i and 1M, they are identical.
OP, if you don't want to do this yourself (even though it is 1 on the 10 scale of difficulty), you can "trade-in' yours here for a 'free' one:
http://www.zeckhausen.com/cdv.htm
2011 BMW E82 1///M: AW, ZPP, ZCV, HK, Sirius, Apps; Akra CF+Valve control, MadDad mids, K&N, Forge FMIC, P3gauge, EuroTails, Tint, CF Mirrors+Spoiler+Roof Wrap, 10mm H&Rs, IND grills+gills, xCDV, LUX AE
2008 Audi B7 RS 4: Sprint Blue, Exclusive Euro Recaro Interior, Premium+Titanium Package, EPL Tune, Stasis Ohlins MS coilovers, Milltek valved exhaust+DownPipes, Stoptech SS lines, Tint, ADR V1, Lidatek, Lamin-X, Rotiform SNA 19x10" wheels, 275/30/19 PSSs, Euro flat-bottom steering wheel, JHM SSK
///M1 is offline   United_States
      07-01-2012, 09:34 PM   #17
CarJunkie
Just did this today, what a difference!! I coupled the lines together and intended to leave the who CDV out. Ocne I had it out, the valve tapped out of the housing easily, so I put the gutted valve back in the keep the unmodified look.
FYI, the 1M clutch bleeder is an 11mm. The DIY called for a 10mm wrench. Those who have incomplete sets of tools (like me) will want to know that before starting. Fortunately I had an 11mm. There is definitely NOT enough room in there to use a monkey wrench.
      07-03-2012, 12:36 AM   #18
HP Autowerks
HP Autowerks's Avatar
Drives: 2011 135i DCT & 2011 1M
Location: Santa Barbara, AST, Brembo, Eibach, H&R, GIAC, Koni, Quaife, Stoptech, Vorshlag,
FWIW, a 7/16 can often be used in place of the 11mm in a low toque situation.
HP Autowerks is offline   United_States
Reply
clutch, delay, valve
Forum Jump
