Reply
      07-04-2012, 12:01 PM   #23
BrokenVert
Extremist Opinion Fighter
BrokenVert's Avatar
Drives: Topless Electric Boogaloo
Originally Posted by Pig Farmer View Post
Do they do anything about the size of the opening where the snorkel meets the scoops in the front of the engine bay? I have to imagine this is where the air flow is restricted. The two openings are about 1"x3", and the air needs to make a 90* turn before it enters the snorkel. Would love to know if they found a solution. Thanks.
Shelby came up with the perfect solution in 1968.
Yes I'm serious and if it didn't look so ridiculous on a BMW I'd do it. Maybe a set of NASA induction scoops are in order
BrokenVert is offline   United_States
      07-04-2012, 12:30 PM   #24
Pig Farmer
Drives: 2009 BMW 135i
I'd be lying if I said that thought hadn't crossed my mind. Even thought of installing a scoop on the bottom of the plastic belly pan. Just can't figure out a way to route the plumbing up to the intake.
Pig Farmer is offline   Reply With Quote
      07-05-2012, 01:06 AM   #25
BJ1M
BJ1M's Avatar
Drives: 1M coupe AW
i tried to get more picture there to let you guys know about the structure. I think the the GrurppeM CIA is under certain premise to compare with OEM one. the key benefits are larger flow of air and won't suck heat from engine bay. I am living the city the temp will increase to 40'C at summer. So cool air is very important. If i back to Toronto, i'd go for AFE2 CIA. However, after the change i notice clear increase on power and torque. Althought it may not be very significent but clear response is good enough to me.
1 M Coupe AW,
AK evolution, AK DP, AFE Stage2 CAI, ER CP, Cobb Stage2+FMIC, ETS FMIC, JRZ RS1, Stoptech BBK,
BJ1M is offline   Reply With Quote
      07-05-2012, 08:45 AM   #26
BrokenVert
BrokenVert's Avatar
Was that on a dyno or was it something you simply felt? Forgive me for never trusting butt dynos when I'm spending 2 grand
      07-05-2012, 09:55 AM   #27
BJ1M
BJ1M's Avatar
Drives: 1M coupe AW
u know why i bought 1M here? all car is 2 times more expensive than US. my 1M cost more than 100grand here. but it is the most close priced to US market. Similiar to 1M, a X5 costs 150grand here. so 2grand is a OK match for 1M.
they stopped the quota policy which can bring one car from NA without extra tax last year.
1 M Coupe AW,
      07-05-2012, 03:01 PM   #28
sparoz
sparoz's Avatar
Drives: VO 1///M; AW X3 30d
In theory a CAI will have a little more impact on a car that has a FMIC compare to a dual cone. I am certainly looking at the GruppeM as well, but I am not convinced it is better than the aFe2. It certainly looks better and it might flow better, but the question is how the K&N filter stacks up to the aFe's? Most people rate aFe's filter better than the K&N. I would seriously think about the GruppeM if it could use the aFe filter.
After all, CAI only gives about 8 degree difference, so you are looking at <3% of performance gain max over a dual cone without calculating insufficiencies. GruppeM is like Akra, there are options which cost 1/4 of it that do almost the same job. You are just paying for bling. I would most likely do the Akra plus Gruppe. Just like China, the 1M is 115k in Australia, 2k is small in comparison.
1///M - Valencia Orange
X3 30d - Alpine White
Under Six Seconds http://www.under6s.com
sparoz is offline   Australia
      07-05-2012, 10:59 PM   #29
ESC OFF
ESC OFF's Avatar
Drives: 1M (AW) & CaymanS
Get a drop in filter and remove the seal at the back of the engine bay that seals against the hood, the increased airflow will drop underhood temperatures and its free....IMHO
ESC OFF is offline   United_States
      07-05-2012, 11:16 PM   #30
CarJunkie
Drives: Valencia Orange 1-Series M
How is the grouppe m intake bette than OEM though?
Engine bay art....
Not to cheapen any aspect of the piece, but holy crap it is beautiful!!
CarJunkie is offline   Reply With Quote
      07-23-2012, 03:49 AM   #31
E36325is
Drives: 1M coupe
Just got mine installed.... loving the effect, much sharper throttle response from idle and emits a deep rumble at 3k rpm and up. and at least a 10C drop in intake air temp according to the P3 gauge is not bad.
E36325is is offline   Hong Kong
      07-23-2012, 04:27 AM   #32
sparoz
sparoz's Avatar
Irresistible !
      07-23-2012, 05:33 AM   #33
luial
Drives: 1///M, e46 M3, e30 320is ///M3
How much does it cost in HK and where to get it?
luial is offline   Reply With Quote
      10-25-2012, 12:47 PM   #34
ozinaldo
ozinaldo's Avatar
Drives: 1M
I am going to install a aFe Pro Dry S air filter together with ER charge pipe very soon and will experiment sometime if the filter will do anything good and/or noticeable. Was checking threads on relevant subjects and just noticed your quoted comment. Before I go under the hood, could you tell me (even better if you could show me) which seal you were talking about and if it has any function that will be missed or not? Thanks.
2011 BMW 1M: Euro spec, w/out Nav, manual seats. Evolve Race+N55 mid, Michelin PSS, ER charge pipe, aFe ProDryS drop-in filter, CDVx, BMW-IND trunk spoiler matt cf/VO stripe, BMW blacklines, BMW black grills, IND side gills&rear M logo, silver turn indicator bulbs, anthrazit overlays on side creases and on air curtains, MPerformance steering wheel w/VO ring, BMW steel pedals, custom mats, color matched MPower e-brake.
ozinaldo is offline   Chile
      02-13-2013, 01:38 PM   #35
T1T2GRE
CW2
Drives: VO 1SMC
2011 BMW 1M  [0.00]
Send a message via Yahoo to T1T2GRE
Anyone do ol' fashioned K&N? Just plug 'n' play into the stock box? Does no one do this anymore? Heckuva lot cheaper if flow is the issue and not so much temps.
You will have goosepimples.
T1T2GRE is offline   United_States
      02-13-2013, 04:02 PM   #36
zayzay
Drives: bmw 1M
purchased the afe dual cone cai. notice a difference in sound and performance at higher speeds
zayzay is offline   Reply With Quote
      02-13-2013, 04:46 PM   #37
gibbo21
Drives: 1M Coupè
I think that a hood like that could help a lot with an open DCI
gibbo21 is offline   Reply With Quote
      02-13-2013, 06:11 PM   #38
EINSER M
EINSER M's Avatar
Drives: 2011 E82 1M
Send a message via AIM to EINSER M Send a message via MSN to EINSER M Send a message via Yahoo to EINSER M
Originally Posted by 1'M Blue View Post
I have an AFE Stage II dual cone open style CAI. fits perfectley.
+1
EINSER M is offline   United_States
      02-18-2013, 02:39 AM   #39
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
I know that many on this forum are not fond of DINAN's products but their CAI is the only one I've sen that dramatically increases air volume and flow and gets air from outside the engine bay. Its beautiful too. Its not cheap but see a lot of folks here spending some serious money on a particular exhaust system that has no better performance than many less expensive alternatives. Unfortunately it requires FMIC and increased oil cooler to off set elimination of secondary radiator and even though they told me directly that it was due out some time ago, still does not seem available.
4thM3 is offline   United_States
      02-18-2013, 10:18 AM   #40
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Why promote something that may not even make it to market? Dinan has made some great intakes, but I don't see many 1M owners willing to modify their stock cooling system in order to install the Dinan unless there were proven significant gains with the intake alone. Also, the purpose of a CAI is to reduce IAT, so why would an upgraded FMIC be required?
_______________________
2011 1 Series M Coupe/VO/Convenience Pkg/Premium Pkg/Harman Kardon/AFE Scoops/Berk Midpipes/P3 V2/BMS Catch Can/CF Rear Deck Spoiler/3M Clear Bra/3M Crystalline/Homelink/M Performance Steering Wheel
bdaddylo is offline   United_States
      02-19-2013, 01:29 AM   #41
4thM3
4thM3's Avatar
Drives: 2011 AW 1M
I'm not promoting just adding to the dialogue. Do the research then ask me again. It's actually very well conceived but is part of an overall concept.
Reply
Forum Jump
