Reply
      09-11-2012, 01:33 AM   #45
Andrew517
Drives: BMW135
Originally Posted by trashcan
I was told by my dealership this problem was caused by my wheel bearings. Turns out it was actually my front tires needed to be replaced. :-/
Does the problem really solved after changed the front tyres?
Andrew517 is offline   Reply With Quote
      09-13-2012, 07:48 PM   #46
vantagesc
vantagesc's Avatar
Drives: 2011 135i DCT
For me, the clicking sound would go increasingly faster with higher speeds. And it required somewhat of a cornering load to replicate. The dealer replace the wheel bearing.
vantagesc is offline   Reply With Quote
      09-13-2012, 11:43 PM   #47
Andrew517
Drives: BMW135
If you still using the factory run flat tyres, I think it will happen again.
      09-14-2012, 05:30 AM   #48
katsooba
katsooba's Avatar
Drives: bmw 135i
Hi
you might want to read this thread
i own a 135i yet my solution in the end of the thread cured my problem
http://www.1addicts.com/forums/showthread.php?t=704094
135i N55 / custom charge pipe / M3\M1 Bushings
katsooba is offline   Reply With Quote
      09-14-2012, 05:43 PM   #49
vantagesc
vantagesc's Avatar
Why is that?
      09-25-2012, 02:39 AM   #50
hyphy1
Drives: 2010 135i
Originally Posted by MikeNeo View Post
and its a common problem
how'd that happen?
2010 135i
Black on Black
Premium Package
Sports Package
hyphy1 is offline   United_States
      09-26-2012, 05:14 AM   #51
Andrew517
Drives: BMW135
Why is that?
Probably the tyre bead was too hard. Therefore if change new rims with the old tyre after few years of usage. The copper wire inside the tyre bead might have some issue and generate a clicking noise
      09-26-2012, 05:21 AM   #52
Andrew517
Drives: BMW135
Why is that?
The bead wire might be too hard, so when change a new rims with the tyre has been used for more than a year. The structure inside the tyre bead might have an issue and turns out a clicking noise.
Reply
Forum Jump
