FORUMS
- 5
| 09-28-2012, 07:48 PM | #25 | |
I'm buying a JRZ suspension for my 335i but I do not decided yet if I go with fixed sport springs or race springs (custom rate springs). I will drive most time in the street and about 6-7 times year on track but with slick tires (the sport springs will be soft with slicks). Which spring ratio are using in coilover set? How much improvement did got with race springs? How the car feels now in the street? By the way your video is awsome Thanks Sadak And thanks for all Harold support |
| 10-11-2012, 04:27 AM | #26 |
![]() ![]() ![]() ![]() Drives: Black 1M & White 1M Trackcar Join Date: Apr 2006
if you use slick tires you need harder springs.
I believe i have 50kg springs front but that s for slicks on track to soft. For semi and good streettires it s enough. You could even go for 70kg front. But any harder is a no go for the road. I find 50kg springs already hard for road use. I use my 1M car mostly for track now. I found the eibach RS1 kit the best compromise. It was lovely for the street and hard enough for track. The only thing i missed was hight adjustable that s why i went for race spring setup. |
| 10-11-2012, 08:58 PM | #27 |
![]() ![]() ![]() Drives: 2011 135i DCT & 2011 1M Join Date: Mar 2007
Location: Santa Barbara, AST, Brembo, Eibach, H&R, GIAC, Koni, Quaife, Stoptech, Vorshlag,
Both 6 and 7 KG front springs give ride quality that is better than OE with the RS1 dampers. With R-comp and slicks you will likely go up to 8 to 9 KG.
| 10-12-2012, 06:07 PM | #31 |
Will these be made available via your site anytime soon.
| 11-13-2012, 05:42 PM | #32 |
JRZ RS1 going to a happy 335i customer! 1M struts are the same with the additional adaptors.
Look at the new reinforced anti roll bar mount! All future shipments should be like these. |
| 12-13-2012, 05:39 PM | #34 |
JRZ RS1
Look what awaits my arrival this morning on top of my tool box!
Full assembly and going to a happy 1M/M3 home for Xmas soon! |
| 01-08-2013, 02:59 PM | #37 |
| 04-08-2013, 10:34 PM | #39 | |
Since i'm not luck i didn't had the chance to drive with slicks due to rain. The rs1 are amazing good. I'm thinking in change the camber plates to stock shock mount to get some confort. Thanks |
| 04-12-2013, 11:03 PM | #40 | |
| 04-20-2013, 02:41 PM | #41 |
I am having the RS Pro installed on my 1M later this month at the JRZ HQ in the Netherlands. They suggested 40 N/mm for the front springs and 100 N/mm for the rears and 20N/mm helpers for the dual, street/track use. If I understand correctly that translates into 4kg for the front and 10kg for the rear. That appears way softer than most unless the values for the main springs and helpers should add up, in which case I am exactly at 6 and 12 kilos. I will wait and see how this works out for me.
| 04-22-2013, 06:59 PM | #42 | |
4kg front and 10kg rear do seem soft. Be on the lookout for spring bind on the front with such low rates. For reference you are about 1.5kg higher than OE on both front and the rear. |
| Bookmarks |
