      07-22-2012, 07:05 PM   #1
joeo
Drives: 2009 Crimson Red 135i
2009 BMM 135i  [4.75]
DIY Video on front brake pads
Finished up a DIY video on how to remove and replace the front pads on a 2009 BMW 135i.
Hope someone finds it useful and enjoyable!
-Joe
      07-22-2012, 09:54 PM   #2
New21er
Drives: 2011 135i
Nice vid. Should you have had your rotors "turned" also?
      07-23-2012, 12:24 AM   #3
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
Send a message via AIM to Greenkirby21
wow very good video! I always wondered how it was done
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      07-23-2012, 01:22 AM   #4
woosh
woosh's Avatar
Drives: MT09, ZN6
Sticky this!
      07-23-2012, 02:54 AM   #5
Delta Goose
Drives: '09 AW 135i
That was a well done video, thank you! Now how about the rear pads?
      07-23-2012, 04:35 AM   #6
Nce DIY video!
Only thing I would do different would be to bleed(& flush) the brake fluid after installing new brake pads. I would have also used a 3M scuff pad on the rotor surface. Using a one man pressure bleeder like the Motive unit - makes easy work of bleeding brakes. Also... perhaps its time for you to invest in some Allen (impulse) sockets instead of those L-shaped Hex keys! lol
And using a can of CRC Brake Kleen (bc its non flammable) instead of compressed air is the way to go. You don't want all that brake dust floating around your garage.
Great DIY!
Dackel
      07-23-2012, 12:35 PM   #7
joeo
It wasn't necessary to turn the rotors. I would have them turned if they were warped - or just replace them. If there is a lip on the outer edge, then they might be out of spec and need to be replaced. It's a good idea to measure the thickness.
Good suggestion on the brake cleaner - I typically use lots of brake clean! Should have added that to the video. I do use compressed air on the caliper itself - some brake clean can be harsh on rubber - like the dust boots.
Thanks for all the comments!
-Joe
      07-23-2012, 04:52 PM   #8
erabmw135
erabmw135's Avatar
Great post!!
2008 BMW 135i Jet Black AT - AK Downpipes, Berk Mid Pipe, BMS intake, AA Sport FMIC, AA Chargepipe & BOV, COBB AP, Alufelgen Sf-71 19s, Escort 9500ix
      07-23-2012, 05:03 PM   #9
AchtungF80
AchtungF80's Avatar
Philippines
138
Drives: '16 f80, '87 e30, '00 BB6
2008 135is  [4.75]
2010 Cooper S  [5.00]
1991 318is  [5.00]
Send a message via AIM to AchtungF80
Great video! Thanks for sharing!!!
ig: achtungf80
      09-02-2012, 11:10 AM   #10
sharkatron
Drives: `09 135i
Awesome - videos seem to give that confidence to get the job done
      09-02-2012, 11:32 AM   #11
xerox445
Damenslip-Tropfer
14
Drives: 2008 SGM 135i
Nice chrome on your impact. Nice socks also.
      09-02-2012, 01:48 PM   #12
pixelblue
pixelblue's Avatar
80
Drives: the silver bullet
2010 135i  [4.37]
Joeooooooo nice DIY video but I can't believe you don't torque your caliper bolts come on man you need better tools brother
      09-02-2012, 03:49 PM   #13
sonicbimmer19
Drives: E88 and F32
great DIY. This will help me do my pad changes.. 128i should be the same, right?
I'm surprised resetting pads only give go up to 4000 mls? Mine are set to like 40,000 mls...
      09-02-2012, 11:44 PM   #14
lastMleft
lastMleft's Avatar
Drives: e92 M3
Thanks Joe
      09-03-2012, 05:08 PM   #15
joeo
I make them 'good-N-tight'. Do you know the torque spec? If so - please share.
This depends on how the car was driven previously and how long the pads lasted. Tracking the car tends to reduce pad life.
      09-03-2012, 08:48 PM   #16
GaryS
Drives: 2009 135i 6MT
2009 135i  [3.25]
It's around 70.
      09-03-2012, 09:01 PM   #17
pixelblue
pixelblue's Avatar
80
2010 135i  [4.37]
it's suppose to be 68 but I set it to 70 like Gary
      09-16-2012, 08:21 PM   #18
TheBurro
TheBurro's Avatar
Drives: 2009 135i
Thanks for the video. Just did my front pads and watched this vid as a starting point. Very helpful especially with resetting the light!
      09-17-2012, 09:54 PM   #19
Hops128i
Hops128i's Avatar
35
Drives: 2010 128i, manual, sport pkg
great video! Thank you! I too am wondering how the 128i is different.
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZII square on et 40 with rolled rear fenders.
      10-26-2012, 12:45 AM   #20
Boosted_N54
Boosted_N54's Avatar
102
Drives: 135i N54
Thanks JOE for the DIY video brake pads. thanks to your helpfull video i installed my new Portfield r4s pads and new stop tech slotted rotors
1) be strong
2) quality strong tools
3) be patient
i started off with the passenger side first and i got to say the two 10mm bolts that hold the caliper are very tight but i manage to get them out even with out a break bar once i finished installing the pads and rotor on the passenger side i moved to the driver side i unscrewed the top 10mm bolt and then as i try to unscrew the bottom bolt it woudnt budge at all i mean AT ALL i was trying for an hour just for that last freaking bolt but nothing so i re installed my rim back on and drove off to a car shop which had a break bar and even with the break bar wouldnt budge but luckily we manage to get that fukn bolt out . like i said
1) be strong
3) be patient
      10-26-2012, 09:05 PM   #21
joeo
Glad you got the bolt off! If they didn't use a breaker bar - what did they use? Impact?
In general I try to buy all the tools I need for a project - I love buying tools. Buying tools is great....I feel more manly when I buy tools.
      10-27-2012, 01:51 AM   #22
Boosted_N54
102
Drives: 135i N54
true i love tools and defiantly need a breaker bar
