      07-24-2012, 08:31 PM   #1
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
106
Drives: E92 M3 2012 Edition 500
135 Brakes how good are they
Today is brake day at Advan
After a track day we see all sorts of things some good some bad,
this one is bad see if you can see the cracks in the piston inserts
Before you do a track day check your brake pads and change your fluid.
the pads need to have at least 50% for a days racing with the trip home.
OR $$$$$$$$$$$$$$$$$$$$
      07-24-2012, 08:38 PM   #2
RaihaX
RaihaX's Avatar
Drives: 08' 135i
scary!
      07-24-2012, 08:42 PM   #3
cooler2442
Drives: '11 135 Sport DCT
Send a message via AIM to cooler2442 Send a message via Skype™ to cooler2442
Don't run stock pads on track days either. Here is how mine looked after 2 track days and 6k miles. Cracks all over them.
url=http://www.flickr.com/photos/38941112@N05/6867104683/][/url]
IMG_0618 by baldadar, on Flickr
IMG_0615 by baldadar, on Flickr
      07-24-2012, 08:54 PM   #4
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
423
Drives: a black car
Are the calipers still good?
      07-24-2012, 09:16 PM   #5
Nugget
Nugget's Avatar
Drives: 2017 M140i, 1994 E36 M3
2011 BMW 135i  [5.00]
So what's a good compromise for someone who doesn't want to change pads for track days? And how much fluid do I need to buy?
I was going to order cool carbons and Castrol SRF fluid.
      07-24-2012, 09:21 PM   #6
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
106
image hosting
caliper requires overhaul or replacement, cracked pistons and burnt out piston seals,
maybe the above picture is your answer stu?
      07-24-2012, 09:27 PM   #7
cooler2442
After those cracked pads I switched to the Hybrid Ferodo DS2500's with Castrol SRF fluid and ran it in 2 more track days + another 6k miles with no problems. Great for daily as well, little to no noise.
      07-24-2012, 09:43 PM   #8
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
106
Yep good set up and works well price is good to.
      07-24-2012, 09:56 PM   #9
Nugget
Nugget's Avatar
I had DS2500s on my Audi and they worked well (nearly set them on fire on the track but they didn't fade), but they were pretty noisy day to day.
      07-24-2012, 10:13 PM   #10
cooler2442
I find that they are only noisy if they aren't bedded in properly. At first the shop put them on and bedded them in really well so they made 0 noise for a few months then they started getting noisy and then the noisiness went away after I'm assuming they got rebedded in.
      07-24-2012, 10:23 PM   #11
Drawn05
Drives: Yes
I am waiting for my titanium backing plates to arrive. I was worried about the possibility of caliper piston damage on track days so I thought I would give these a go. Matched with some ventilated rotors, fresh performance grade fluid, HPS pads and F20 front brake shields I should be OK.
      07-24-2012, 10:23 PM   #12
JB4-335
Drives: E92 BSM & E70 AW
Wow!! What did you do to your brakes Stu?
      07-24-2012, 10:34 PM   #13
pavo335
pavo335's Avatar
46
Drives: 3.5 wheeler
would a pile of dirt/gravel getting there have cause this
      07-24-2012, 10:38 PM   #14
JB4-335
Post a vid of it pav. I wanna see it.
      07-24-2012, 11:03 PM   #15
pavo335
pavo335's Avatar
46
Drives: 3.5 wheeler
a vid of what?
I was simply asking IF you got a pile of dirt and rocks, you know like a house sized dust cloud pile of dirt and gravel in the passenger front wheel would that have an effect on the brakes
      07-24-2012, 11:50 PM   #16
423
Drives: a black car
Unfortunately the brakes were sacrificed in quest of blistering lap times
He's taking the piss as I was man enough to drive all nannies off and lost the rear end on a downhill right hander - sliding off the track completely sideways leaving 4 beautiful tyre track marks leading to the car's resting position in a largeish dust cloud.
      07-25-2012, 12:02 AM   #17
pavo335
pavo335's Avatar
46
Drives: 3.5 wheeler
Stu, i wasn't referring to you, it was a general question
so when are the nashin's going in
      07-25-2012, 12:12 AM   #18
423
Drives: a black car
Sure you were old man.
In a pickle with them, would like to upgrade to something aftermarket but after spending heaps on the car atm I can't justify a brake upgrade... Pete said they are fine to use for street so that's how they'll stay... for now.
      07-25-2012, 12:42 AM   #19
pavo335
pavo335's Avatar
46
Drives: 3.5 wheeler
Any footage of this 'blistering' lap?
      07-25-2012, 12:43 AM   #20
423
Drives: a black car
I didn't have the GoPro setup for that lap ... missed some good footage as well including moe coming off the track as well
      07-25-2012, 01:09 AM   #21
510135
Drives: f32
Hi guys sorry to thread jack.
Can somebody confirm the OEM rear 135 2008 brake pad part number, I have conflicting numbers. Is it 34216791421 ? The other number I have seen is 34216784808 (has this been discontinued)
Cheers
Nik
      07-25-2012, 01:09 AM   #22
pavo335
pavo335's Avatar
46
Drives: 3.5 wheeler
I think everyone has that footage
