      07-25-2012, 01:17 AM   #23
1q2w3e4r
Breakfast at Tiffany's
1q2w3e4r's Avatar
19
Drives: BMW
Send a message via MSN to 1q2w3e4r
Originally Posted by nik0123 View Post
Hi guys sorry to thread jack.
Can somebody confirm the OEM rear 135 2008 brake pad part number, I have conflicting numbers. Is it 34216791421 ? The other number I have seen is 34216784808 (has this been discontinued)
Cheers
Nik
Not sure where you got that from.
There are two part numbers listed for rear brakes on an 08 135.
34216778649- classified as 'not suitable for performance parts'
34216795754- classified as 'alternative part BMW accessory'.
I'm guessing there was a BMW Performance brake package offered on them. Sorry those are the rotors.
Pads are as you detailed 34216784808 and 34216791421 is the update.
I'd run aftermarket with better fluid if you are replacing the stock pads though and do any track work etc.
      07-25-2012, 01:30 AM   #24
510135
Drives: f32
Thanks for the reply. So I am right ?
      07-25-2012, 02:33 AM   #25
Nugget
Nugget's Avatar
Drives: 2017 M140i, 1994 E36 M3
2011 BMW 135i  [5.00]
Originally Posted by cooler2442 View Post
I find that they are only noisy if they aren't bedded in properly. At first the shop put them on and bedded them in really well so they made 0 noise for a few months then they started getting noisy and then the noisiness went away after I'm assuming they got rebedded in.
You are probably right. I think the problem was I didn't drive the Audi hard enough often enough, not having that problem with this car
      07-25-2012, 05:10 PM   #26
ECSTuning
ECSTuning's Avatar
Drives: Independent Tuning Specialists
Send a message via AIM to ECSTuning
Cheers
Nik
34216784808 has been superseded by BMW to 34216791421. Below is a photo of what you'd get if you ordered 34216791421.
      07-25-2012, 06:51 PM   #27
510135
Drives: f32
Cheers
Nik
Thanks for the reply , coincidence that you replied, you will see my large order of parts in the next few days
      07-26-2012, 12:11 AM   #28
pavo335
pavo335's Avatar
-34
Drives: 3.5 wheeler
Stu, so what did you do for your brakes?
      07-26-2012, 12:36 AM   #29
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
527
Drives: a black car
They're ok for street use so going to use them as is for now with oem pads...
will look into a caliper upgrade before the next track day.
      07-26-2012, 12:42 AM   #30
pavo335
pavo335's Avatar
-34
Drives: 3.5 wheeler
i assume you mean with new pads
lucky that the rotor is ok I guess, i'd have thought with the drive home you might have rooted the rotor as well.
      07-26-2012, 01:05 AM   #31
527
Drives: a black car
yeh the rotor is pretty rooted, this is just a temporary street solution for a week or two till I get some Hawk pads in for myself to use with the ECS 2 Piece rotors... would be good for track, except I still need to address the cracked piston issue.
      07-26-2012, 02:14 AM   #32
John_01
John_01's Avatar
Drives: E90 325i, E82 135i
I'm wondering if the ECS 2 piece rotors will help reduce the brake temps. Any ideas?
      07-26-2012, 02:36 AM   #33
527
Drives: a black car
Probably yes (I have some ECS 2 Piece rotors to go on)
But then you'd need to upgrade the pads to a harder compound...
and then there are still plenty of people reporting cracked pistons/piston seals with firmer pads.
      07-26-2012, 04:49 AM   #34
davo135i
Drives: 2014 BMW M235i
Pav it might have happened when he and mo were mowing the lawn.
      07-26-2012, 04:42 PM   #35
pavo335
pavo335's Avatar
-34
Drives: 3.5 wheeler
I hadn't considered that, mmmmmm, you know what you could be onto something there. Hehehehehe
      07-27-2012, 01:55 AM   #36
Nugget
Nugget's Avatar
Be interested to see how the ECS rotors go. They certainly look good
I'm ordering some Ferodos and Castrol SRF.
Hopefully that makes a big difference because I'm not that impressed with the 135i brakes.
      07-27-2012, 03:45 AM   #37
John_01
John_01's Avatar
The lower the brake temps, the lower the chance of cracked pistons, melted pads etc. Another idea might be custom brake cooling ducts for track use. I'm just thinking out loud here.
      07-30-2012, 12:00 PM   #38
ECSTuning
ECSTuning's Avatar
I've had a few guys making custom backing plates for the pads to help protect the pistons. Just another idea to ponder over.
      08-02-2012, 06:56 AM   #39
TimMc
TimMc's Avatar
Drives: 135i SCT N54
Yeah, I'm using HardBrakes Titanium backing plates.
Driving - Man 135 (LeMans/Black). BMW Perf SW, Quaife LSD, KW V2s, Ground Control camber plates, M3 front Control Arms & SB, Helix IC, AR DPs, PROcede V5, ER CP, Forge DVs, BMS OCC, Setrab OC, P3 Gauge, Alcon 6 Piston Calipers, DBA 365mm 2 piece rotors.
Riding - BMW R1200RS Sport, Merida Scultura 7000E, Avanti Aggressor, Malvern Star Equipe, Mini Mal.
Proudly from the Shire.
      08-14-2012, 11:08 AM   #40
annalisa_ferri
Netherlands
Drives: E82 135i
Be careful.
While the Ti backing plate may be beneficial for the pistons issue, it may go in the opposite direction for the pads - which can run hotter since less heat is flowing to the caliper.
The problem is somewhere else: the OEM pads are street pads. Period.
Their optimal temperature cannot met the range given by a serious track use; otherwise they would not provide optimal brake coefficient when cold-braking (that is, normal road use).
Switch to real track stuff is mandatory for all uses other than road/light/fun.
Cheers
      08-17-2012, 01:14 AM   #41
TimMc
TimMc's Avatar
Originally Posted by annalisa_ferri View Post
Be careful.
Cheers
Bedankt. I'm changing fluid tomorrow and better pads are on the list!
      08-17-2012, 08:04 AM   #42
WAY
Drives: Fast ones
I posted my cracked pistons/piston seals with pictures back in 2008. Can't believe BMW has not done anything to fix this issue! My car had only done 2000km or so at that stage with a few track days. I changed to massive AP Racing brakes and it was the best think for my car. Until today, I still have those 135i brakes with the cracked pistons. Question is, are the pistons ans seals replaceable?
      08-17-2012, 08:12 AM   #43
Alpine*
Alpine*'s Avatar
Drives: Changes pretty often
What are you doing here stranger?
      08-17-2012, 08:57 AM   #44
WAY
Drives: Fast ones
Looking for you. . Where's pic of the 1M?
