      07-30-2012, 01:45 PM   #1
Venom
Venom's Avatar
Drives: BRZ
2008 BMW 135i  [4.25]
Send a message via AIM to Venom
Clutch = gone
My clutch has just died at 33k miles WTF!!!
Is this normal for a bimmer? This is my 4th major item to fail on the car in the past 3 months. How long are they supposed to last?
I am debating extending the warranty as it expires soon. Any advice or tips on what I should get to cover the car?
Venom Build Log
Prius is latin for impotence.
      07-30-2012, 01:53 PM   #2
Red Bread
Drives: My wife's car
My original clutch was still going strong on my M Coupe at 144k miles. How many miles have you gotten out of previous clutches?
      07-30-2012, 01:57 PM   #3
Venom
Venom's Avatar
Drives: BRZ
130k on my previous integra.
Venom Build Log
      07-30-2012, 01:59 PM   #4
sluflyer06
Drives: 2008 135i MT
I've got 35K of hard driving on mine and still fine. Put 70,000 on a E46 330i zhp and never had clutch issues on that either.
Either a premature failure or driving style. Only car I ever had a clutch wear out on me was a 01' Jetta 1.8T.
08' 135i MT || Cobb Stage 1 'Aggressive' 4.01 Map | BMS DCI | Berk Mid Pipes | Maddad Eurosport Axleback | E93 FSB | M-Sport Black on Black | CDV Delete ||
      07-30-2012, 02:06 PM   #5
Colt
Spoolin' & droolin'
Colt's Avatar
Drives: 08 135i 6MT
what power mods do you have done to the car? I'm at 31k and it still grabs great...
Originally Posted by Nate4641 View Post
looks like unicorn vomit.
      07-30-2012, 02:06 PM   #6
Venon - You might want to ask your service manager about this. There have been a number of early (2008) 135i's that have had sudden clutch failure at low miles(20 to 30K miles). Also even current 135i's and 1M's have been known to have a bad rear main seal that either leaks oil or that makes a funny cricket type sound.
So... your dealer might be able to get BMW to pay for the parts IF you pay for the labor. I would hit them up for some "good will". Also... a tune will dramatically shorten the clutch's life span.
Dackel
      07-30-2012, 02:09 PM   #7
JimD
JimD's Avatar
117
Drives: 128i convertible
It seems like you know how to drive with a clutch and BMW clutches are not unusual in their life, at least under normal circumstances. That leads to questions like:
Is there a leak from the engine through the rear main seal? Were you adding oil?
Did pieces of the old clutch come off or did it just wear down (i.e. ask them to show you the old clutch)
Is the pressure plate good - and broken springs? Other signs of something unusual?
I routinely go over 100K on clutches despite towing things with my manual transmission SUVs (I'm on my second, non BMW). My late wife's Mazda 626 went through a couple, however, apparently due to inadequate pressure from the pressure plate. My son inherited that vehicle and changed the pressure plate which seems to have made a significant difference. This 626 is a NA 2 liter 4 - not a powerful car.
Jim
      07-30-2012, 02:16 PM   #8
int2str
int2str's Avatar
Drives: 2008 135i
Is there any more detail on this?
My clutch hasn't failed yet, but it's chattering pretty badly. Holds strong, just chattering badly. I'm thinking it's somehow going to fail soon (fail, not wear out)...
      07-30-2012, 02:39 PM   #9
I have only seen guys post some horror stories in the past here on 1addicts. One guy just bought a used 135i in California. He went for a drive, parked his car. Then could not start the car when he returned to the car. Had the car towed to a dealer. Turned out he needed a new clutch/flywheel/pressure plate/rear main seal/and throw out bearing. COD price was like $3.5K! He had BMW pick up most of it. But I think he ended up paying over a grand for the repairs.
Most other clutch posts have had COD prices around $1.5 to $2K at the dealers. BMW has paid for some, and not for others. It all just depends on the mood of the people at BMW HQ in the states.
I think if this happened over here... we would be SOL. I am not sure IF a German dealer would cover this. I would think not.
But to answer your question... no I don't have any hard evidence about the clutch life span. I have only seen what members have posted here on 1addicts. Just do a search... and you will find the threads.
I also remember two 1M's when they first started hitting the streets - that had bad rear main seals, that leaked a lot of oil onto the pavement!
Dack
      07-30-2012, 02:58 PM   #10
Venom
Venom's Avatar
Drives: BRZ
Dackel
I HAD THAT CRICKET SOUND! I thought that was normal!
Apparently, my dealer is going to check if it's blue before they do anything
And I may up having to eat the cost quoted at 1850... (1200 labor, 650 parts).
There was definitely quite a bit of that chatter sound... since I picked up the car.
I only had stage 1 on the car for a short time because it has been in and out of the service shop so much (20-40 extra hp, so not much more than PPK1). So the car should be able to handle that...
Venom Build Log
      07-30-2012, 03:03 PM   #11
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
Drives: 2012 128i Coupe 6MT Sport
112K on my E36 clutch.
      07-30-2012, 03:08 PM   #12
Venom
Venom's Avatar
Drives: BRZ
Jim
I have barely had my car since its been in the shop so much but I have had quite a bit of chattering. I have not added oil but I have had coolant leak a rather large pool in my garage. I have noticed that quite a few times the car wouldn't grab 3rd from an upshift in 2nd. (That was the first noticeable sign.) Then I had weeks of clutch slippage, but the dealership couldn't replicate it "through normal driving conditions". And then today it burned out completely and my whole street now reeks of burnt clutch. (I was testing it before work, so I wouldn't end up stranded.)
Now I am debating extending the warranty because this is my another major repair in a month. 2 new turbos, 1 new Headlight + assembly + control module, DSC control module, coolant leak and container replacement, break fade/ resurfaced, etc...
Venom Build Log
      07-30-2012, 04:37 PM   #13
KingOfJericho
KingOfJericho's Avatar
Drives: Yes
2010 135i Coupe  [2.63]
Extending the warranty? I would be selling that thing ASAP with those types of issues! I have 2 months left on my lease and I think I'll have to throw them back the keys after reading this. My clutch also feels less than amazing but I always figured it was from air possibly getting in the line when I yanked my CDV.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2014 Jeep Grand Cherokee Overland Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
      07-30-2012, 05:05 PM   #14
tuco44
tuco44's Avatar
Drives: 2016 340i xDrive MPerf EB
From the OPs past posts, looks like he got the car in about July or 2011. Since it is an '08 MY, it obviously had a previous owner.
Does the OP know the past history of the car prior to his ownership? And could the clutch have been abused before he got it?
I often wonder how BMW deals with some of these cars where there has been some form of abuse??
Just wondering.....
2016 340i xDrive MPerf. EBII
Previous BMWs - 18 others since 1971.
      07-30-2012, 05:16 PM   #15
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
Serious bucks fora clutch replacement. It must be in five figures to get a DCT repaired out of warranty.
      07-30-2012, 05:19 PM   #16
Or the "lifetime" fluid changed!
      07-30-2012, 05:57 PM   #17
tuco44
tuco44's Avatar
True, but the OPs car is MT.
      07-30-2012, 06:22 PM   #18
b00st
Drives: 2009 AW 135i
Seems like an early failure. I've got about 45k miles on my car, with about 15k of those at FBO + JB3/4 power levels, and then another 5k or so with meth, occasional race gas, and for the past couple months an E85 blend + meth. My tires are destroyed, but the clutch is holding like a champ still.
'09 AW 135i 6MT - JB4 + E85 + meth - Sold
'12 Black Diamond CTS-V Sedan - Stock for now
      07-30-2012, 06:30 PM   #19
doublevanosrc
Back in a 1er!!!
doublevanosrc's Avatar
Drives: 2013 135i
2013 BMW  [0.00]
Bummer
Try to have BMW covered assuming you weren't riding it. The clutch on my E46 330 had 50k miles when i let her go and it still grabbed great.
Now: 2013 135i manual Black on coral, all options except HK.
Past-2011 135i
"I know it can be expensive but man I just love the darn thing."
      07-30-2012, 07:31 PM   #20
KingOfJericho
Drives: Yes
I thought I remembered seeing somewhere that BMW covers one clutch in the 4yr/50k coverage. Am I delusional?
      07-30-2012, 09:07 PM   #21
Venom
Venom's Avatar
Drives: BRZ
According to my SA, it's a wear and tear item so it's up to the discretion of bmwna.
And I have had the car since last August. The previous owner babied the car, he preferred his motorcycle. So it's not on him either. Either way this is way too early for it to
give out.
Venom Build Log
      07-30-2012, 10:26 PM   #22
MM135
Drives: 2012 E92 M3
2012 E92 M3 ZCP - Gloss Lemon Sting - DCT - Currently need a new name for the car
Dinan Racing Exhaust - BPM STG II - BPM DCT Flash - BPM Servotronics - Arkym CF Hood - Arkym CF Diffuser - Forcewerkz CF Side Skirts - ModeCarbon GTS Wing - BMWP CF Splitters - BMWP CF Mirror Caps - 19" HRE P43SC - KW Sleeve Kit - OSS Designs Headlights
