Reply
      12-07-2012, 08:09 AM   #23
jackkk
Drives: VO 1///M
If we compare Evolve exhaust with stock mids vs Evolve exhaust with n55 mids, the variance with n55 mids louder?
I got the SS sport whitch it the same like Evolve, and don't want to have it louder, but interesting in n55 mids power gain
jackkk is offline   Reply With Quote
      12-07-2012, 08:17 AM   #24
ozinaldo
ozinaldo's Avatar
Drives: 1M
Was my exact idea to go with N55 mids. I added the N55 mids for extra benefits like hp/tq, response and drone and I think the combination works beautifully. Since I installed them at the same time I can't tell for sure though. The sound characteristic of SS or Evolve is un-altered in my case just a tad better, deeper and growling, this is my best guess. I wouldn't call it much louder than just the SS rear exhaust. Have a friend, fellow member Morgan here, he has just the Evolve rear with OE mids and we will meet soon to check how they sound in comparison, can report you back.
2011 BMW 1M: Euro spec, w/out Nav, manual seats. Evolve Race+N55 mid, Michelin PSS, ER charge pipe, aFe ProDryS drop-in filter, CDVx, BMW-IND trunk spoiler matt cf/VO stripe, BMW blacklines, BMW black grills, IND side gills&rear M logo, silver turn indicator bulbs, anthrazit overlays on side creases and on air curtains, MPerformance steering wheel w/VO ring, BMW steel pedals, custom mats, color matched MPower e-brake.
ozinaldo is offline   Chile
      12-07-2012, 08:23 AM   #25
jackkk
Drives: VO 1///M
Tnx, it would be perfect
I like the caracteristics of the n55 mids, so I just don't want to have a vary loud exhaust to destroy my ears) I have this car for a DD... Hope the n55 mids get just deeper voice)
Do you have a bad smell from the exhaust or some other issues?
      12-07-2012, 08:29 AM   #26
ozinaldo
ozinaldo's Avatar
Drives: 1M
No, zero issues.
      01-08-2013, 10:38 AM   #27
jhonson3141
Drives: 1M
this post is very helpful!!!! i am living a country where youtube is restricted so detail description is REALLY helpful!! glade you enjoy this setup
jhonson3141 is online now   Reply With Quote
      01-09-2013, 02:02 AM   #28
saurabh_turingMS
saurabh_turingMS's Avatar
Drives: 1M AW;F10 520D MSport;
I'm running Evolve race rear section with stock mids. I love the sound, it's de deeper but not much louder than stock. It has a very smooth euro-exotic wail under load from 3.5K to 5K. It's a hard sound to capture on camera but I will keep trying and will post it up.
I find myself gently revving out to 5K just for that sound
saurabh_turingMS is offline   Australia
      01-09-2013, 08:07 AM   #29
ozinaldo
ozinaldo's Avatar
Drives: 1M
Exactly, I keep on thinking how I can capture that Mine may be a bit louder in general than your set up due to N55 mids, I feel at full throttle the difference with stock is night and day; even cold start is clearly louder. Plus there is the burbles, especially when you let the throttle off.
      01-10-2013, 11:35 PM   #30
Munit
Drives: m3
Wow low numbers. A bolt on m3 puts down nearly 100 more wheel horsepower. Most bolt ons are in the 380-390 range wheels. This is with an exhaust. Obviously a tuned 1m would be different but really shows the spread in power between the two
Munit is offline   Reply With Quote
      01-11-2013, 08:12 AM   #31
ozinaldo
ozinaldo's Avatar
Drives: 1M
No, you got it wrong. A bolt on 1M can also put 100 hp more, even more than that in some cases. Actually this here doesn't show anything like you say. It effectively shows the opposite data, that E92 M3 and 1M has merely 30 whp difference each stock. My car with just the exhaust (stock down pipes) is only 23 whp shy of a E92 M3 on the same dyno, before exhaust it was 30 hp. Charts and info are posted somewhere in this thread and actually confirms the same findings of other people. This is a very low reading Mustang dyno if that matters.
Another data is stock to stock difference in torque, at the wheel is more than 100 lb.ft, which makes 1M tq 60% higher than the M3. It peaks around 2500 rpm and stays close to peak till around 6000 rpm. M3 has one of the flatest tq curves I've seen despite lower peak tq, lovely as well.
To put it in a nutshell, 1M has 90% of M3's hp and 160% of its tq. Weight difference vary from market to market according to standard equipment but I heard it is around 250-300 pounds in US, I know it is 80-100 kg. in Europe.
Reply
Forum Jump
