Reply
      02-04-2013, 05:07 PM   #23
drinkcoke3
drinkcoke3's Avatar
Drives: 135i + Subaru Legacy (DD)
2011 BMW 135i  [0.00]
Send a message via AIM to drinkcoke3
I have resolved this issue.
I put on 225/245 Goodyear Eagle F1 Assymetric All Seasons and used the VB3 as my winter rims.
turns out that the wheels are a more aggressive offset (as noted by many people here), and that with a narrower tire, ive rubbed once in about 600 miles so far.
2013 135i Coupe / LMB on Oyster / 6 Speed / BMW Performance Front Bumper, Side Skirts, Front & Rear Rotors, Suspension, Electonic Steering Wheel V2, and CF Rear Spoiler / Dinan Stage 2 / VMR VB3 HyperBlack / Michellin PSS / BMS Intake / Hardwire V1 / ActiveAutowerke Axelback, Intercooler, Strut Bar / BMS CDV Mod / F30 Performance Shift Knob + Bimmian Alcentara Boots / SWS8x Subs + Amp
drinkcoke3 is online now   United_States
      03-31-2013, 06:22 PM   #24
livingboosted
Drives: 2008 bmw 135i
Have any of you guys used an 18x9.5 et33 offset in the rear with vmr vb3's? I'm going to be picking some up and that's the offset I want to go with. I saw a picture of another 1 using that offset but no idea if he had any rubbing issues.
livingboosted is offline   Reply With Quote
      04-01-2013, 05:56 PM   #25
PeteA
PeteA's Avatar
Interesting problem you have here as the offsets are not THAT far off what is usually recommended for a 255 rear tyre. If I'm not mistaken, the higher the offset, the more inwards the wheel comes to the vehicle.
I'll be running a 19x8 ET48 225/35 and 19x9 ET50 255/30 front and rear on Michelin PSS. Hopefully I won't get any rubbing on stock suspension....though I am looking at the BMW PS as well after the wheel change. Hopefully I'll be ok too?
PeteA is offline   Australia
      04-01-2013, 06:07 PM   #26
drinkcoke3
drinkcoke3's Avatar
I doubt you'll have issues since those offsets are closer to OEM offsets on m sport wheels.
Not sure though since you'll be on 19s.
      04-01-2013, 06:15 PM   #27
PeteA
PeteA's Avatar
I'm unsure also, but it's all about rolling diameter and width if i am not mistaken. I calculated the differences using this tool (I recommend anyone else who changes wheels/tyres does the same):
http://www.rimsntires.com/specs.jsp
VS. OEM:
Fronts
4mm closer to suspension/brakes
6mm father sticking out in fenders
6mm additional wheelwell fill
1.8% faster on speedometer
Rears
3mm closer to suspension/brakes
7mm father sticking out in fenders
4mm additional wheelwell fill
1.3% faster on speedometer
An 18" wheel package saw almost identical variances as the tyre width was upped from 215 to 225 and 245 to 255 respectively. The 19's only saw a step down in tyre wall height from 40 to 35 and 35 to 30 respectively.
      04-02-2013, 11:43 AM   #28
Zombie1
Drives: BMW 135i 2010
This sounds good to me
Originally Posted by Nugget View Post
Just do a few donuts to wear down the outside shoulders of the tyres
Mods: rieger rear black performance grills Lci blacklines Berk exhaust alpina B3 flash and plenty more to follow
Zombie1 is offline   United_States
Reply
Forum Jump
