Reply
      10-03-2012, 02:46 PM   #1
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Dinan Exhaust Installation Solutions
The Dinan exhaust release is now public and so is the installation issue with having to cut the stock exhaust pipe. Can anyone with an aftermarket exhaust system that utilizes a connection pipe confirm if their connection pipe follows the OEM stock exhaust routing? I'm hoping to use someone else's connection pipe to install the Dinan, so I can make it a 100% bolt on system.
_______________________
2011 1 Series M Coupe/VO/Convenience Pkg/Premium Pkg/Harman Kardon/AFE Scoops/Berk Midpipes/P3 V2/BMS Catch Can/CF Rear Deck Spoiler/3M Clear Bra/3M Crystalline/Homelink/M Performance Steering Wheel
bdaddylo is offline   United_States
      10-03-2012, 03:10 PM   #2
ozinaldo
ozinaldo's Avatar
Drives: 1M
Mine from Evolve was almost identical, the same shape of the stock muffler. Send a PM to Imran from Evolve to see if their rear exhaust and Dinan's are similar enough in terms of where they connect with the extra pipe. I need to check but I think Vorsteiner exhaust was also "cut" short so they should be using a similar connecting pipe as well.
Also you may check the photo of the Evolve connecting pipe in my relevant thread, here:
http://www.1addicts.com/forums/showthread.php?t=745649
2011 BMW 1M: Euro spec, w/out Nav, manual seats. Evolve Race+N55 mid, Michelin PSS, ER charge pipe, aFe ProDryS drop-in filter, CDVx, BMW-IND trunk spoiler matt cf/VO stripe, BMW blacklines, BMW black grills, IND side gills&rear M logo, silver turn indicator bulbs, anthrazit overlays on side creases and on air curtains, MPerformance steering wheel w/VO ring, BMW steel pedals, custom mats, color matched MPower e-brake.
ozinaldo is offline   Chile
      10-11-2012, 02:09 PM   #3
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Teaser. Couldn't confirm if other after market exhausts utilize the BMW muffler replacement cutoff point, so I'm hoping that a shop can fabricate something for me.
      10-12-2012, 01:02 PM   #4
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Pics and Videos
So, I couldn't find a reasonable price for just a connecting pipe from the other brands. I received quotes ranging from $290-$600 not including shipping. I found a local shop in Houston called Afordable Muffler who built a custom connecting pipe. Thankfully, they had an old flange that was basically the same size, but needed some tweeking. Here are some pics and videos.
Now for my review. The Dinan sounds great. It's louder, but not abnoxious. You can hear it across the full RPM range unlike the OEM which was my biggest complaint. Drone appears to be well controlled. I haven't driven on smooth asphalt yet, so I can't say for sure how well controlled it is. The only dislikes so far is that it hangs a little low and is quite visible. Thanks to BMW of North Houston for handling my Dinan order.
      10-12-2012, 02:08 PM   #5
MrRoboto
Drives: VO 1M
Sounds great but the whole way this thing connects is ridiculous, especially coming from a company like Dinan. Last thing I want to see on my 1M, having just shelled out 2k for a muffler is some half assed welded piece of pipe (I would't be happy with that weld job at all, a proper clamped pipe would have been much better)
Also, I agre with you that it does seems to sit low.
I guess I can cross this one off my list.
MrRoboto is offline   Canada
      10-12-2012, 02:48 PM   #6
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
To get the alignment correct, they welded it in place. Not the best looking welds, but it's doing its job and it's not visible unless you're crawling under the car and I don't plan on spending much time underneath the rear of my car. The connecting pipe has a slip on connection, so the weld can be easily cut with minimal effects to the Dinan portion. All in all, my OEM exhaust is still intact and I can easily remove the Dinan if needed. For a $85 job that took less than an hour, I'm quite pleased.
      10-12-2012, 07:22 PM   #7
ozinaldo
ozinaldo's Avatar
Drives: 1M
Now I am thinking that if anything goes wrong with the Dinan exhaust, quality wise etc., since they are very serious about not approving any other tuner's products mated with theirs, they may deny responsibility just because the client prefered not to cut his/her stock muffler and used a custom one to be able to use it. At least on paper they may just say that the issue has something to do with an unapproved connecting pipe because that pipe is not a Dinan or BMW product
      10-12-2012, 08:04 PM   #8
Tuned1M
Tuned1M's Avatar
Drives: ANAW1M
Sorry but this is ridiculous. Would it have really effected their bottom line to extend the piping a bit further to properly connect to the mid pipe?
Tuned1M is offline   No_Country
      10-12-2012, 08:22 PM   #9
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Originally Posted by Tuned1M View Post
Sorry but this is ridiculous. Would it have really effected their bottom line to extend the piping a bit further to properly connect to the mid pipe.
A big miss on their part by not doing market research on their target consumer. They unofficially said a connecting pipe would have added $600 to the cost which is like a 500% markup.
Besides this issue, I'm very satisfied with the sound and performance.
      10-12-2012, 08:29 PM   #10
providence
Drives: 2011 328xi M sport,2012 X5, 1M
I know they say out of sight out of mind... But this WOULD bother me...
No thanks Dinan...
I guess I'm back to the damn Akrapovic...
providence is offline   United_States
      10-12-2012, 08:49 PM   #11
Bdh821
Drives: 08 Montego 135i, 06 330xi
Send a message via AIM to Bdh821
HOLY FAWK those are some ugly ass welds!!! It amazes me how people can lay down a bead, or lack there of, and be happy with their craftsmanship. Sorry to rip on your exhaust. $600 would be like a 1000x markup of cost also
Bdh821 is offline   Reply With Quote
      10-13-2012, 04:11 AM   #12
JimPastell
Powered by ///M
JimPastell's Avatar
Drives: Matte white 1M
OMFG!!! I have always thought that Dinan is delivering overpriced parts with bad finish but this is just ridiculous! My Akrapovic Slip-On is a true beauty and worth every penny!
JimPastell is offline   Sweden
      10-13-2012, 04:46 AM   #13
FairfaxM3
Drives:
After paying the price they are asking for the exhaust and then coming up with a custom solution--which in this case is not a really clean solution--I really question if it is really worth it.
I'm sure a cleaner installation can be done--but, again, I would then question the value of it, given the other options available.
FairfaxM3 is offline   Reply With Quote
      10-13-2012, 11:33 AM   #14
///M1
///M1's Avatar
Drives: Many
No thanks Dinan...
OP: congrats on your new exhaust and thx for posting the pics and video. Glad you like the rumble and that drone is gone.
I have to say I am shocked at how Dinan has delivered such a hack job solution. Kept pricing at their 'standard' levels, yet install ends up looking like from Meineke. WTF?! Last company to release an exhaust for the 1M, and they deliver THIS? Couldn't have cost them all that much to just make the connecting pipe longer and be a true bolt-on and PnP. Wow, speechless.
2011 BMW E82 1///M: AW, ZPP, ZCV, HK, Sirius, Apps; Akra CF+Valve control, MadDad mids, K&N, Forge FMIC, P3gauge, EuroTails, Tint, CF Mirrors+Spoiler+Roof Wrap, 10mm H&Rs, IND grills+gills, xCDV, LUX AE
2008 Audi B7 RS 4: Sprint Blue, Exclusive Euro Recaro Interior, Premium+Titanium Package, EPL Tune, Stasis Ohlins MS coilovers, Milltek valved exhaust+DownPipes, Stoptech SS lines, Tint, ADR V1, Lidatek, Lamin-X, Rotiform SNA 19x10" wheels, 275/30/19 PSSs, Euro flat-bottom steering wheel, JHM SSK
///M1 is offline   United_States
      10-14-2012, 06:52 PM   #15
Ian///M
Ian///M's Avatar
Drives: 1M E82
Poor form on Dinan not having a connecting pipe
BMW 1M VO - Cobb, Remus muffler, MadDads midpipes, ETS 5" FMIC, ER CP, CDV, OCC, Michelin PSS
Ian///M is online now   Australia
      10-15-2012, 01:12 PM   #16
Mr.Metak2you
Mr.Metak2you's Avatar
Drives: LEXUS LS(DailyDriver)
I think it sounds great!
Mr.Metak2you is offline   Reply With Quote
      10-15-2012, 05:06 PM   #17
firechicken99
Drives: Black '07 335i
+1. Boggles my mind
firechicken99 is offline   Reply With Quote
      10-15-2012, 09:39 PM   #18
CarJunkie
Drives: Valencia Orange 1-Series M
Sounds nice, but Maddad with stock rear section sounds better, adds more power and costs less than 1/3rd. Easy decision.
CarJunkie is offline   Reply With Quote
      10-15-2012, 10:07 PM   #19
Marc@schnell
Marc@schnell's Avatar
Drives: BMW 1M
SOrry guys i couldnt see doing this to a one off car.
Hence why many people go with the bolt ups
MEISTERSCHAFT, EVOLVE, AKRAPOVIC, BORLA to name a few
2011 1M VALENCYA
- Clean OEM Performance Mods
CF Spoiler w/the IND Touch.Elec Perf Wheel V2.6K Angel.Meisterschaft GT Gloss Black.AR DP.SLEK CF Front Spoiler.N55 Mid.Cust Mirror Caps.12mm Spacers.20%3M Tint.Clear Bra.IND Side Markers.OEM Perf Grills
@SchnellWerkes - Insta - FB - Twitter
Marc@schnell is offline   United_States
      10-15-2012, 10:08 PM   #20
bdaddylo
bdaddylo's Avatar
Drives: 2011 E82 1M
Sorry, but you don't have a clue. Stock rear sucks compared to any aftermarket no matter what midpipes you're running. I believe the stock rear is more restrictive than the stock midpipes.
      10-16-2012, 01:39 AM   #21
Ian///M
Ian///M's Avatar
Drives: 1M E82
I disagree. I added Maddads and sound increase was awesome. Adding Remus muffler a few months later got rid of the drone though.
      10-16-2012, 06:23 AM   #22
theinfamousdrew
Big Member
theinfamousdrew's Avatar
Drives: 911 Turbo / E70
I have NEVER liked any Dinan products and this seals the deal.
They also state this on their site...
"+ Bolt-on installation using high quality BMW OEM clamps"
theinfamousdrew is offline   Reply With Quote
Reply
Forum Jump
