Reply
      11-13-2012, 01:48 AM   #23
Da _Grk_Tuner
YEAR ONE OF THE ONE
Drives: 135i tii
I would use clay bar bought from an online detailer like "Detailer's Domain" or "Detailed Image".
I once used some Meguiar's clay kit on a dark green bmw and it was pure hell trying to fix all the spots where the clay bar stuck to the paint. I told myself never again would I buy a clay bar, "off the shelf" so to speak. I've used DD's (blue)uber clay bar and liked it. Also be sure to buy a clay bar lube too.
Dack
how about
http://www.chemicalguys.com/Clay_Bar..._p/cly_109.htm
Da _Grk_Tuner is offline   Reply With Quote
      11-13-2012, 01:04 PM   #24
Moderator
Drives: 135i Silber mit/Rot 6MT N54
Originally Posted by Da _Grk_Tuner View Post
I've never used their clay bar. But I have used other products from Chemical Guys, and I am really impressed by their stuff. Like their JetSeal109.
Dackelone is offline   Germany
      11-13-2012, 03:41 PM   #25
JimD
JimD's Avatar
Drives: 128i convertible
This is what I use:
http://www.autogeek.net/motcalgolcla...FetDMgodlnoAyA
It is the mothers clay bar kit that I buy locally. It is the only clay I've seen locally which is why I tried it. the first kit worked well so I bought another. I think you can do a 1 series with half a bar but you have to mash it out flat and get the car clean first. They give you a spray bottle of their detailing spray to use as lubrication and I didn't use near all of it. It is handy to have around for when a bird or bug leaves you a "present".
I don't have any doubt there are better sources of clay but I find the mothers kit works fine and is readily available at a decent price.
Jim
JimD is offline   Reply With Quote
      02-22-2013, 11:34 PM   #26
PerryTM
Local Celebrity
PerryTM's Avatar
Drives: 2010 E82 135i M-Sport
Might be a dumb question, but can you still clay our type of headlights since their not glass or will it just mess up the plastic housing?
e82 10' 135i MSport - Zak
PerryTM is offline   United_States
      02-22-2013, 11:48 PM   #27
crystaweizen
crystaweizen's Avatar
Drives: Alpine White '08 135i
2008 BMW 135i  [5.00]
Dack
Yea if the clay bar is sticking its either because its worn or because its not lubricated enough. I would think I clay bar would be better at removing contaminants then a pad with some magic sauce on it. If anything I would do it after a clay but in my opinion nothing can replace a clay in doing what it does. I've used clay on my white 135 and had beautiful wet paint after wax. 50 to 75 percent of finish quality is in prep work
crystaweizen is offline   United_States
      02-22-2013, 11:50 PM   #28
crystaweizen
It couldn't hurt but you're not trying to get a reflective finish from them either. You can hand apply polish or lens cleaner then hand remove it or buff off using a finish pad on sloooow speed. The plastic won't forgive you for heat
      02-22-2013, 11:52 PM   #29
PerryTM
Local Celebrity
PerryTM's Avatar
Thanks for the help.
      02-22-2013, 11:52 PM   #30
crystaweizen
Talking
Originally Posted by JimD View Post
This is what I use:
Jim
Griotts gives you a very large chunk of quality clay for the same price as the major companies
      02-22-2013, 11:53 PM   #31
crystaweizen
No problem if you want to avoid any problems best to do lenses by hand.
      02-22-2013, 11:56 PM   #32
crystaweizen
Originally Posted by bmw1racer View Post
^ If done right, I'd think you'd be buffing out the surface contaminants, not the clear coat.
Clay removes surface contamination. When you cut or polish you are actually taking microns of clear coat off making the scratches and swirls disappear
      02-23-2013, 01:29 PM   #33
Joeyb7
Drives: 2011 135i M Sport - AW
Exactly....you're just rounding down the edges of any defects on a micro level.
Joeyb7 is offline   Reply With Quote
      02-23-2013, 08:50 PM   #34
crystaweizen
Yep yep bringing down the clear coat to the same level as the bottom of the scratch. So theoretically the more you buff/polish your car the more clear coat you are taking away. But realistically unless you are using an aggressive pad and/or compound you will do little to no harm to your finish
      03-11-2013, 02:15 AM   #35
cat-like
cat-like's Avatar
Drives: 2013 AW 135i
My car is on order and I intend to have it run over with a clay bar and polished within a week of picking it up.
I did this with the my last new car (Golf R) and the difference was amazing.
cat-like is offline   Australia
      03-12-2013, 06:14 AM   #36
Rahulsinghrura
Drives: Bmw E81 116i Sport 3-door
Where can I get a clay bar?
Rahulsinghrura is offline   Reply With Quote
Reply
Forum Jump
