Reply
      11-22-2012, 02:04 AM   #1
txgrown
Drives: 2000 323i sedan
How much power can a 135i N55 transmission handle?l
I have been searching for a while now and have come up empty. Does anyone know what the 135i N55 trans càn handle in terms of pôwer? Thañks.
txgrown is offline   United_States
      11-22-2012, 02:09 AM   #2
Ian///M
Ian///M's Avatar
Drives: 1M E82
501.2974 HP
BMW 1M VO - Cobb, Remus muffler, MadDads midpipes, ETS 5" FMIC, ER CP, CDV, OCC, Michelin PSS
Ian///M is offline   Australia
      11-22-2012, 02:21 AM   #3
Rowdy
Drives: 2012 135i
501.2974 HP
How did you come up with that one? Some mathematical formula? Or is that what yours was making before it came apart?
Rowdy is offline   Reply With Quote
      11-22-2012, 02:23 AM   #4
cooler2442
Drives: '11 135 Sport DCT
Send a message via AIM to cooler2442 Send a message via Skype™ to cooler2442
The DCT can only handle a max of about 410whp and 470wtq. Manual can handle more.
cooler2442 is offline   Reply With Quote
      11-22-2012, 02:24 AM   #5
txgrown
Where are you guys finding these numbers?
      11-22-2012, 02:44 AM   #6
cooler2442
Experience. DCT starts slipping at around 410whp and 470wtq.
      11-26-2012, 03:09 PM   #7
bogart
bogart's Avatar
Drives: E82 N55 DCT
2011 BMW 135i  [3.53]
I agree with those numbers.
bogart is online now   United_States
      11-26-2012, 03:30 PM   #8
GeeRam
GeeRam's Avatar
Drives: 135i Coupe
Really......
Info I've read says the DCT is rated at 600Nm whereas the 6MT is only rated at 430Nm.
I know of a 135i in the UK where the gearbox gave up after 50k miles behind a remapped N55.
It's the reason BMW don't offer the manual trans bolted to the back of the 335d.
2011 135i M-Sport Coupe DCT ~ Bluewater:Coral Red | BMWP CF spoiler & BMWPE | Birds B1 suspension | Forge FMIC | Hartge footrest | Alufelgen CS7 & Pirelli P Zero
2012 Harley Davidson Softail Slim ~ lots of mods
GeeRam is offline   United Kingdom
      11-26-2012, 03:44 PM   #9
cooler2442
Originally Posted by GeeRam View Post
Really......
Yes really. The people pushing those numbers have the DCT slipping while the manual has no problems. BMW's ratings have never really been truly accurate.
      11-26-2012, 03:57 PM   #10
Freon
Drives: 2009 135i
You don't hear many stories of people breaking either transmission, so it would seem the answer is, "more than anyone has bothered to put in their 135i."
A lot of this has to do with drivetrain slop (dual mass flywheel, driveshaft isolator, bushings, etc), tires, and abuse. I wouldn't worry too much until you are running on slicks with a solid flywheel, unsprung clutch, and beating the hell out of it.
2009 BMW 135i, 6 MT, M Sport, DIY DCI, Cobb AP, Apex 18x8.5+9.5, 235/265 Starspecs
Freon is offline   United_States
      11-26-2012, 05:49 PM   #11
alexmtl_135i
Drives: N55 135i M Sport DCT
Really......
600Nm = 440lb/ft torque, which seem to be inline with what cooler said.
Not sure about the manual rating, 430Nm seems very close to the base engine spec of 400Nm torque.
alexmtl_135i is offline   Reply With Quote
      11-26-2012, 06:27 PM   #12
geared
Drives: No car
no way an auto coming out of factory BMW cars handle more power than a 6spd....not happening with today's tech/price ratio.
geared is offline   Reply With Quote
      11-27-2012, 12:48 AM   #13
hyper1
Drives: 2013, Z4/28
how many hp
maybe you should ask the question to a profession mechanical engineer at BMW.
if not possible.....a good shop that built performance transmission.
just my opinion
hyper1 is offline   Canada
      11-27-2012, 01:50 AM   #14
Pete_vB
Drives: '69 GT3, R32, 1M, 912
This is probably the wrong question. As others have noted, transmissions are rated in torque, not power, as torque is the limiting factor (assuming proper cooling). Regardless of the rating on the 6MT, we know the factory delivered it in cars with up to ~370 ft/lbs (500 Nm) wheel torque in the 1M. We also know based on experience that this is conservative, and the transmission will take significantly more than 450 wtq (with reduced durability).
Your question asked about power, however, and power at a given torque is a function of RPM, and hence how the motor is built/ tuned. If the motor is built and tuned for high rpm power but limited peak torque, then 450 ft/lbs at 7000 rpm would give you 600 whp and be perfectly safe for the transmission. Of course most N54/ N55 motors are tuned exactly opposite this, with more torque than HP, but this illustrates how high power can be made with limited peak torque.
The logical conclusion of this philosophy was shown in F1 V8s before the 18,000 rpm limit, where engines were making well north of 750 hp at almost 20k rpm, but peak torque was only a little more than 200 ft/lbs, allowing tiny and light weight 7 speed gearboxes that weigh well under 100 lbs.
1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
Pete_vB is online now   United_States
      11-27-2012, 01:54 PM   #15
Guardian
Guardian's Avatar
Drives: 2013 135is, AW and Coral Red
Excellent explanation.
Guardian is offline   United_States
      11-27-2012, 02:53 PM   #16
ian.j
ian.j's Avatar
Drives: 135i N55 DCT
2011 135i  [0.00]
i might be wrong but people talking about slippage, this would not be gearbox failure, more clutch. in my experience of gearbox failure it goes bang and you lose some teeth which rattle around and before you know what hit you the box is scrap.
i am well aware it is easy to up-rate a clutch in a manual and not so easy on the dct
ian.j is offline   United Kingdom
      11-28-2012, 12:43 AM   #17
hyper1
Drives: 2013, Z4/28
hp versus tq
well done
thanks
      11-28-2012, 02:02 PM   #18
GeeRam
GeeRam's Avatar
Drives: 135i Coupe
Reply
Forum Jump
