      11-24-2012, 12:00 PM   #1
1MSPEEDY
Can't wait for spring!
1MSPEEDY's Avatar
Drives: 1M, 135 M-Sport
Question 1M / 135 Wheel and Tire Puzzle
OK... I am looking for some help determining if there is a reasonable solution to the following puzzle.
I currently have a 1M and a 135 M-Sport. I do track the M and I purchased the 135 to run at Targa Newfoundland. I would like to purchase an 18" square set-up (wheels and tires) for the 1M track days that I could also use on the 135 at Targa Newfoundland. Obviously I do not want to give up on performance when they are on the 1M but they can not rub during sharp cornering or full compression of the suspension on the 135.
So..does anyone have a suggestion that may work for me? I belive that the off-sets will be extremely important if there is indeed a solution.
I would appreciate all feedback...that would include telling me that "I can't get there from here".
Thanx.
      11-27-2012, 11:27 AM   #2
Eyeman
Eyeman's Avatar
43
I assume it would work, but not work properly. Most running square setups on 135s are running something like 18x8.5et40 with 235/35 tires. Much wider and you rub. You could put that on a 1M but you'd be giving up an inch or two in tire width.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, Nitto 555 225/35fr PSS 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, rearseat removal, iCarbon diffuser and front lip, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod.
      11-27-2012, 02:14 PM   #3
Blue55
Blue55's Avatar
27
Drives: 1M
OP, you're going to give up a significant amount of grip by using wheels that fit the 135 fenders. IMHO, the stock wheel/tire setup on the 1M is already offers insufficient grip and those wheels won't fit on the 135. Anything less than a 245F on the 1M is asking for massive understeer.
Others may know of a compromise solution, but I'd be wary of a setup that sacrifices grip for convenience.
      11-27-2012, 02:47 PM   #4
1MSPEEDY
1MSPEEDY's Avatar
Thanx. for your responses. I was pretty sure that I have no options but it is alway better to ask and get it over with.
Now I need to find more money and more space in the garage for the additional two sets of wheels and tires.
      12-01-2012, 03:05 AM   #5
HP Autosport
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, Stoptech, Vorshlag
The best solution is two sets of wheels and tires.
      12-01-2012, 01:30 PM   #6
Artemis
Artemis's Avatar
Belgium
3430
Drives: BMW M2 (MG 6MT)
+1
Also because the other way around (1M wheels on a 135i) is a no go if you want to spare yourself the hassle of fender rolling:
http://www.1addicts.com/forums/showthread.php?t=718876
“For ’tis the mind that makes the body rich” (W. Shakespeare, The Taming of the Shrew, Act 4, Scene 3)
