FORUMS
- 5
| 12-04-2012, 12:43 PM | #1 |
Alexis
Drives: 135i convertible Join Date: Nov 2009
Does anyone know if there is some kind of seal I can have sprayed on my undercarriage to protect against salt? It's my first winter out here and I'm told they use salt and sand here in CO.
I wondered if there is an easier way to protect it from rust other then constantly spraying off with water? Thanks guys!!! |
| 12-04-2012, 12:52 PM | #2 |
Gooby Pls.
Very interested to see what people say...DC isn't exatly snow central, but the powers that be are VERY quick to throw down the salt, people around here freak out when the snow accumulates.
E88 FBO N54 Alpinweiss/Coral Red/Meisterschaft Race/Berk Resonated/Macht Schnell 3"/ER CP/Synapse/VRSF FMIC/BMS DCI/BMS Thermostat Delete/Rob Beck PCV/BMS OCC/Cobb 4.02/Alpina TCU Flash/Icarbon/3D Design/BMW Performance/Cyba
| 12-04-2012, 01:00 PM | #3 |
Rust needs 3 things, air, water, and steel. When you add salt you increase the flow of electrons that increase the speed of the deterioration of the metal. So how do you prevent that. Wash the salt off regularly, dry the bottom of your car, because you cant remove air
, and then inspect monthly that none of your undercoating has been scratched off or chipped. As long as the under coating is intact and 99% of the time that's the issue. You wont have to worry about rust.
| 12-04-2012, 01:04 PM | #4 |
![]() Drives: Yes Join Date: Aug 2007
Yeah but I'm sayin' that TrueCoat, you don't get it - you get oxidation problems. It'll cost ya a heck of alot more than $500...
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2010 S4 Current | 2010 BMW 135i GONE | 2008 VW GTI SOLD | 2006 Lotus Exige SOLD |
| 12-04-2012, 01:15 PM | #5 |
huh?
| 12-04-2012, 02:22 PM | #7 |
![]() ![]() ![]() ![]() Drives: AW 135i Join Date: Aug 2012
Colorado doesn't use salt. They use liquid deicer. Its blue, very similar to windshield washer fluid. Doesn't rust cars nearly as bad as salt.
| 12-04-2012, 03:11 PM | #8 |
![]() Drives: Polo Tdi 1.9 Join Date: Aug 2012
Wishlist...
Bmw 135i Convertable White... |
| 12-04-2012, 03:50 PM | #9 |
In the 1980s and earlier, cars were made of materials that were pretty susceptible to rusting. I lived in Pittsburgh, PA then and it was a real problem. Since that time, materials have improved (different steel alloys) as has weatherproofing. I still get back to PA occasionally and the difference in the appearance of older vehicles is pretty striking. I bought my first new car in 1988. I got stuck paying for a rust preventitive treatment. It was already on the car and was the only car they had at the rock bottom price they advertised. So I reluctantly paid. Even then I was convinced it was a rip-off and the salesman pretty much agreed with me. You can hardly find these third parties that do this any more.
On the subject of my bimmer, I noticed waxy goo coming out of the doors shortly after delivery. My understanding is that this is BMW's rust proofing. If you have the option of garaging your ride or washing the salt off periodically those are good practices but the expectation you should have is that your car not rust itself to death regardless. Jim
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 ![]() |
| 12-04-2012, 03:54 PM | #10 |
How long are you planning on keeping the car?
I thought BMW gave us a 12 year / unlimited mile rust and corrosion warranty. If you keep the car 12 years, it's gonna need a lot more than a de-rusting. Also, some of the rust-proofing crap they spray under there tends to degrade rubber.. so if they spray your bushings a bit too much... eh. I'm not worried about rust. I live in NJ, and just give the car a semi regular bath in the winter. My coilovers aren't rust proof (and neither are most springs and shocks) and they are very exposed, so I would just check on those every once in a while to see if there's any surface rust.
![]() Year 1 of the 1 |
| 12-04-2012, 05:11 PM | #11 |
Alexis
I plan on keeping it long term. I think you're absolutely right about the warranty about the rust. I do keep it in a garage at all times so hopefully that will help. I'll wash it off regularly this winter after it snows. Seems like global warming is really getting us this year. Had the top down this weekend here in CO cause the temp was 65*!! Thanks for the advice!
| 12-04-2012, 05:14 PM | #12 | |
is a Texan
Cars don't rot in southern wet climates like they do in snow/salty ones. That proves that water alone isn't something to worry about...though we all know a dry climate (Cali/Arizona) will see even less rust than Texas/Louisiana/etc. Either get an undercoating (line-x, or others suggested here) to prevent bare metal exposure of the cars undercarriage or wash the car regularly to rid it of the salt. Even when you wash it, salt/water/grime/dirt/sand/etc collect in those tough to reach nooks and will cause problems, so the undercoating is really going to be your best bet if you're worried. That said, cars corrosion resistant coatings these days goes pretty far. Unless you're planning on keeping the car a dozen years then it's not going to have problems while you own it, unless the car has had damage and the corrosion protection coating wasn't properly reapplied. Also, I saw a post about BMWs 12 year corrosion warranty; that for full on perforation only. For it to be honored, BMW requires you to participate in an every 2 year corrosion inspection at the dealership (which you pay for)...so that usually don't help anyone. Jake Corrosion Engineer
- Jake ![]() |
| 12-04-2012, 05:25 PM | #13 |
| 12-04-2012, 05:35 PM | #14 |
is a Texan
Haha, no; the water is only a conductive path for ions to flow. The 'materials' in water can accelerate or slow down the process. Same situation with soil/grime. The salt accelerates the process.
I have a degree in Corrosion Technology so we'll assume I'm correct. I don't mean that in a 'cocky' way, it's just there is so much misinformation about corrosion/rust out there because few people specialize in the field so I try to help clear some of it up. ![]()
- Jake ![]() |
| 12-05-2012, 01:31 AM | #15 |
![]() ![]() ![]() Drives: '13 128 M-Spt. LeMans/Oyster Join Date: Mar 2008
I sometimes read a blog written by a gentleman named J.E. Robison, who specializes in servicing and restoring high-line vehicles (Rolls, Bentley, and such). His recent blog entry is basically an ad for a product named Waxoyl, which he applies in his shop.
The guy seems like he knows is way around high-end cars, so I thought it was worth mentioning. His comments about rodents chewing on wires are making me think about keeping comprehensive insurance on my 1, which is stored until 3/1 |
| 12-05-2012, 02:39 AM | #16 |
| 12-05-2012, 09:00 AM | #17 |
Alexis
Thanks! That's good to know!
Thanks everyone for all the advice! I'm a FL native and have never had to deal with snow like what I'm told Colorado gets. I'm just trying to keep my 1 looking and working great! Love this car! ![]() |
| 12-05-2012, 09:58 AM | #18 | |
My i asked my father about electronic corrosion prevention as he used to also be a corrosion engineer. Thanks for the correction.
| 12-05-2012, 01:19 PM | #19 |
The parts that are most suseptible to rust are the underneath chassis components- frame, A Arms, suspension parts, painted steel brackets and drive shafts. I used to undercoat the painted steel components when I lived up north. I used only a high quality undercoating spray from 3M. The only time I did not use undercoating, I used a high quality black paint- like Rustoleum- for drive shafts. I would always primer bare steel parts as well. The fenders are all very well protected since they are galvanized on the inside and protected with paint and primer on the outside. With the undercoating and frequent undercarriage washes, my cars and trucks stayed rust free- no rust at all on the undercarriage. I also used to touch up any bare, chipped or rusted spots underneath every fall while the weather was still warm. I never once had any issue with rust through on a fender and I always kept my cars well waxed to protect the outside. The undercoating was a really messy job and I am glad at least for the time being that I live in FL and don't have to worry about road salt and undercoating.
| 12-16-2012, 04:44 PM | #20 | |
Consider a "touchless" carwash
One other thing to note is that regardless of the snow we get in the Metro area, the humidity level is still pretty darn low. Corrosion, with respect to automobiles, is not a significant issue in this region. Welcome to Colorado and good luck!
2013 135i Convertible Cashmere Grey, Savanna Beige
Premium Cold & Tech Package, DCT, Dinan S2 2013 335i Mojave Luxury, Dakota Venetian Beige Cold/Premium Package, NAV, Driver Assist |
| Bookmarks |
