      01-16-2013, 05:33 PM   #23
ShocknAwe
ShocknAwe's Avatar
Drives: E82 N54
Originally Posted by JimD View Post
In case I haven't made it clear already, I think it is worth the one time effort to put metal, hard rubber, or wood blocks into the plastic lifting pockets. I carry some in the shallow side of the tray under the trunk floor. The cost is low regardless of how you do it and I don't see another good alternative unless you want to spend $100 for 4 of the cast aluminum pieces. They seem like the best option but I didn't want to spend $100 on them. They would also be harder to carry in the car.
Ah F it I'll just go to home depot with the measurements and pick up some wood. It'll give me an excuse to start looking at wood for a new table anyways.
Do you know the dimensions of your inserts? If not its time to bust out the tape measure.
2010 135i M-Sport 6MT Jet Black
N54 | BUILD THREAD
      01-16-2013, 05:42 PM   #24
135IS
Drives: 09 LMB 135I / AW 1M
2009 135i  [3.50]
i jack up my car from those plastic jack points all the time works fine no issues but i only do things like wheels and brake pads. i never felt comfortable putting my car on jack stands so i just go to the local shop and use the lift. Its way easier and i odnt have to worry about jack stands
LMB 135i: Gone
AW 1M: Current #211 of 220
      01-25-2013, 04:10 AM   #25
KIYO
Austria
Drives: 1er M Coupé
I found this jack has the right size for our plastic jack point so I am using this.
If you are living in Europe, it will be easy to purchase.
http://www1.westfalia-versand.at/sho...ydraulisch.htm
Also I carry this block in the trunk. I cut aluminum block in 30mm x 30mm x 55mm to use with other jacks or lifts.
      02-14-2013, 08:31 PM   #26
JHZR2
Drives: 91 E30, 11 135i cv
so is 30x30x55 the correct dimension for those square points? How much free space is there inside of that rectangular lift point?
