Reply
      02-12-2013, 06:05 AM   #23
eeghie
Kind of a Big Deal
Originally Posted by marconi118 View Post
I had the occasion to compare 1M, E90EDC E92EDC and E93EDC E92 front dampers.
here my findings (dampers tested by hand without EDC signal I=0A)
From softer to harder:
1M E92 E92EDC E90EDC E93EDC
The E90EDC + E92EDC and non EDC have the same length
In the 1M front dampers the body is exactly the same as E92 but the shaft goes 8mm less out.
I don't know if the shaft is shorter or if simply the internal higher bump stop is thicker in the 1M dampers???????? maybe someone could fin this out???
The same for the rear, body the same but shaft going out 6mm less
I found that the E93EDC front left damper has the shaft as short as the 1M damper, but the right damper has the same as the E92 damper!!!!!
This is completely crazy, I thought the E93 damper was defective, I bought another 2 E93EDC dampers and exactly the same, one is like the E92 the other is shorter like the 1M.
Is intentionally by BMW to make different length dampers L/R???? I could not get my hands on rear E93EDC dampers to compare....
Interesting, what testing did you do, or for what purpose? Any graphs? R u also considering EDC retrofit?
Dackel, which versions did our current EDC god end up installing on his 1M?
eeghie is offline   Reply With Quote
      02-12-2013, 10:45 AM   #24
marconi118
Drives: 06/07 e93 335i
For the moment I plan to put E93EDC shocks with H&R springs, E36 bump stops, front shaved mounts on my 335i
and then control the EDC simply by varying the current to have "static" settings like soft and sport
I already have complete M3 rear axle + M3 LSD + front carriers with E92M3 dampers! and front + rear M3 brakes
Yes I am doing what BMW did to the 135i to become an 1M
I am doing a 335iM
marconi118 is offline   Reply With Quote
Reply
Forum Jump
