FORUMS
- 5
| 01-23-2013, 07:34 PM | #23 | |
![]() ![]() ![]() Drives: 2011 135i SGM DCT Join Date: Oct 2009
I tried to complain of "long cranks" as others have suggested but they replaced my HPFP instead ![]() In the end I had to pay $350-$400 for an update. The JB4 has been running fine though so not complaining! |
| 01-23-2013, 07:37 PM | #24 |
Lately I seen to be getting allot of missfire issues that turn out to be coil packs. Maybe the heat of summer, and the age of the coils is causing them to degrade. Replace the coil and all is good. I have had a run of this in customers cars over the last 2 months.
I assume this is N54. If N55, as scoobs said, the later DME code is allot more tolerant than the earlier. |
| 01-23-2013, 07:40 PM | #25 | |
BMW 1M VO - Cobb, Remus muffler, MadDads midpipes, ETS 5" FMIC, ER CP, CDV, OCC, Michelin PSS |
| 01-23-2013, 08:20 PM | #26 | |
B |
| 01-23-2013, 08:22 PM | #27 | |
Cheers |
| 01-23-2013, 08:52 PM | #28 |
Call/message Stu@BMR and order 6 coil packs. True, you could just replace the one(s) that have the misfire code(s), if indeed you have misfire issue. I think its best to replace them all and start afresh rather than risk having another coil go in the near future.
| 01-23-2013, 09:06 PM | #30 |
^ My N55 DCT had an issue where it was stalling randomly when pulling up at a set of lights. BMW Sydney diagnosed it as a HPFP - and swapped it out. For good measure they updated the DME whilst it was in.
| 01-23-2013, 09:38 PM | #31 | |
![]() Drives: '11 BMW 135i M Sport Join Date: Mar 2011
Maybe I could get a DME update based on that? ![]()
![]() AW3 135i | BMW Performance: 313 Rims, Exhaust, Diffuser, Spoiler, Grills & Pedals | DCT | BMS CAI | Eibach Pro Kit | M3 Swaybar | P3 Vent Gauge | M3 Steering Wheel ///M Mirrors | Kerscher Splitter | LUX V3 | Blackline LCI Tails | Octane Tint | Alpine Hi-Fi | JL Audio 10W6v2 | Pioneer Amp | Black Roof |
| 01-23-2013, 09:52 PM | #32 | |
Lord Captain Commander
Funny how they actually just gave you a new pump when you complained about long cranks lol
![]() E82 135i M-sport: SGM/6MT/Black PROcede V5 | BMS DCI | AR Catless DPs | BMW PE | ER CP | HKS BOV | BMW SSK | KW V1 coilovers | Dunlop Direzza Star Specs | GTC-CX Matte Black 18" | GP Thunder 7500K | Kerscher CF Lip |
| 01-23-2013, 11:33 PM | #33 |
ONly have JB3 experience, but used to get similar CELs (on lowest map)...solved by always adding 10-20mls of octane booster to every tank. Found I just needed to increase the octane a tad, as when the DSC kicks in, it seems to cause knock if just running 98 PULP
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
| 01-23-2013, 11:45 PM | #34 |
^ I have also noticed SOMETIMES that when DTC kicks in when giving it a bootfull a LIMP is not too far around the corner! I have a theory that DTC somehow causes misfires
| 01-24-2013, 12:05 AM | #35 |
The DTC closing the throttle when the turbos are at full noise can cause issues. I have seen that before. It causes a boost spike pre throttle which is picked up the map sensor, and in a high boosted car it can cause a large spike that the DME can interpret as a sensor problem and cause a limp.
DTC is meant to be a safety feature... not a launch control feature, so we generally recommend turning it off when going for a launch if you are satisfied your driving ability is up to it. |
| 01-24-2013, 06:48 AM | #36 | |
| 01-24-2013, 07:52 PM | #37 |
A test drive home with TCS off revealed no issues. Even a proper test when an old guy in a range rover sport tried to fill the car with diesel smoke when he nailed it, and I was forced to get into clean air :-) revealed no problems.
I'll get it checked properly when it either reoccurs or the cars in for its oil change. Thanks for all the forum help. B |
| 01-24-2013, 09:01 PM | #38 | |
As per 510135, I can confirm that DTC alone has casued limp and misfires as you describe for me. Regaurdless of tune / no tune. If you stay up it with the DTC flashing long enough the car always limps for me (the time period is not that long ~2 sec). With a tune it is easier to inspire wheel spin - hence this is more problematic with a tune - but the standard car (no tune) will do it in the wet too. When this has happen to me there were no engine codes detectable with the BT tool, even thou it went into limp and needed to be restarted to clear. If it was my car I would not start changing coils / plugs / fuel pump / what ever else - until there are further symptoms.
135i Sport | Black Saphire Metalic | Boston Black | 6speed | 10 Speaker Hifi | Sunroof
| Bookmarks |
