Reply
      01-25-2013, 02:36 AM   #23
pavo335
pavo335's Avatar
Drives: 3.5 wheeler
I've had a complaint about the BO comment and he says he is now using deodorant :
So I'll retract that comment
pavo335 is offline   Reply With Quote
      01-25-2013, 03:11 AM   #24
JB4135
JB4135's Avatar
Drives: E92 BSM & E91 BSM
Do tell?
I told you it will cost you $250 but I've decided that comment was a $400 hit.
JB4 G5
JB4135 is offline   Australia
      01-25-2013, 03:46 AM   #25
pavo335
pavo335's Avatar
Drives: 3.5 wheeler
Do tell?
LMFAO shouldn't you be on a plane?
      01-25-2013, 06:23 AM   #26
froop
froop's Avatar
Drives: 08 AW 6MT E82
Hmmm funny that I should make this thread and almost immediately something goes wrong haha.
I installed the 'new' maps 7-29 yesterday and today it's been driving really well until tonight on the way back from the city. I tried to accelerate to overtake and I noticed a huge delay in acceleration if I went from no throttle to full throttle (without kick down). It seemed as if it would try to accelerate for a millisecond and then there would be about a half second delay of nothing before it kicked in normally as it should. I put it on the stock map 0 and it was fine.
Anyone have any clues as to why?
Either way, I'm installing the 9-10 aggressive maps now as I type.
froop is online now   Australia
      01-28-2013, 06:04 PM   #27
froop
froop's Avatar
I installed the 9-10 maps and the car's been running perfectly. If anything it seems much smoother which is really nice.
The only thing is that I've noticed that the exhaust is much deeper and louder with more drone. I'm also noticing a lot more heat emanating from underneath the car whenever I get out on the driver's side. I'm assuming that at least the exhaust note change is due to the wastegate position being set to 50% in the new maps rather than 90%. The heat issue too?
Does anyone knowledgeable know the reasoning behind setting the wastegate position to 50% instead of 90% and is there any effect on the performance of the car other than the sound and reduction in wastegate rattle? (I don't have any rattling yet)
Thanks!
      01-28-2013, 11:39 PM   #28
drjekl
Drives: E92 335i
Great to hear its running better with the new maps dude.
Can anyone chime in on my issue (I'm not entirely sure it is an issue though!)
I had a procede with the latest maps installed by adrian in oct 2012, then a few months later i had a ams fmic (with custom advan 3" piping up to the active autowerke cp) and ar dp's installed. The car really hauled a lot harder from any revs after this, but lately I don't feel as though it has as much oomph in 2nd gear 3krpm +. The car is running fine, with no codes etc could this just be a placebo effect that I'm used to the extra power and its no longer quite as pronounced, or could it be that the ecu has had more time to adjust and learn with detrimental affects on power?
I'm a total noob with the procede so i haven't done any logs whatsoever...
Hopefully Pete gets that advan dyno day happening shortly so i can chuck it up and see what gains the fmic & DP's have had (it ran about 224kw with the procede only)
drjekl is offline   Reply With Quote
      01-29-2013, 03:33 AM   #29
Drawn05
Drives: Yes
I also had the Rev 3 installed at that time of year, was trapping 114mph at the drags with it (was doing similar with the rev 2 previously). Now I am lucky to get 112mph. But having also run Cobb with equivalent maps I can still only hit 111/12mph so I dont think it is a procede issue. It is more than likely a combination of being used to the boost delivery and the overall temperatures of summer. Get meth to reduce intake air temps.
That said, I encourage you to go out to WSID on a Wednesday (or Sunday) and do some 3rd/4th gear logs. It will be of of at least equal use to you as a dyno plot, but is way more fun.
Drawn05 is offline   Australia
      01-29-2013, 03:40 AM   #30
MrBlonde
Welcome! To the House of Batiatus!
MrBlonde's Avatar
Drives: 368 M Coupe, E82 135i, E70 X5
Send a message via MSN to MrBlonde
Sounds like the usual experience where you just get used to the performance level. It no longer gives you a kick. Solution: need more power!
Traps will nose over at this time of year simply because it's hot and humid. Car makes less power.
Doesn't matter; ET is King!
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
MrBlonde is offline   Reply With Quote
      01-29-2013, 05:30 AM   #31
drjekl
Drives: E92 335i
The ambient air temp today was only 23 Deg (albeit humidity is around 80%) but I think you're correct in that the butt dyno has become accustomed to the extra power gained from the fmic and DP's.
I would definately love to head out to WSID sometime, how often do you guys get out there?
      01-29-2013, 05:33 AM   #32
drjekl
Drives: E92 335i
Hmm yup I think that's the case...
If I still have this car in 12 months time I might sell the bike and get some RB's (once I have the lsd in and sorted out the rear end bushes links etc)
      01-30-2013, 07:18 AM   #33
Drawn05
Drives: Yes
Too often and not enough. You are in Newcastle yeah? I am planning on heading down at least once a month. I might go sometime in the next 2 weeks before I have to move.
      01-30-2013, 07:00 PM   #34
drjekl
Drives: E92 335i
Yes correct I'm in Newcastle, it would be great to catch up when you're settled in. I'm heading to Thailand for a few weeks I would be keen in late feb to head down for a run.
Reply
Forum Jump
