      02-28-2013, 05:21 AM   #67
RoadRunner///M
RoadRunner///M's Avatar
Drives: 1M (Sold), M3 F80
Originally Posted by pavo335 View Post
Engine bay temps will have a BIG impact on iat's
How is an A2W intercooler going to reduce engine bay temps though?
As far as I know A2W is just more efficient at lowering IATs
BMW F80 M3 DCT - Silverstone II - AA Mids, BM3 tune
      02-28-2013, 05:26 AM   #68
JB4-335
Drives: E92 BSM & E70 AW
Originally Posted by Zuzu
All jokes aside, I think all N54's need hood venting for heat dissipation.
Agree. Vented hoods will help the heat escape. Every bit helps.
I see slightly higher temps with the cowl and HVAC in place. Once they are removed and your car is already warm you can see the amount of hot air escaping out the top of the bonnet. I drove the 135i without any HVAC or cowl for over 2 years.
      02-28-2013, 05:37 AM   #69
RoadRunner///M
I recall that gaffa tape
Is there no way to retro fit M3 style vents?
      02-28-2013, 05:38 AM   #70
pavo335
pavo335's Avatar
-34
Drives: 3.5 wheeler
You might want to read joes post and the context again
      02-28-2013, 05:41 AM   #71
RoadRunner///M
Don't get what you on about Pav
      02-28-2013, 06:24 PM   #72
BMW86
Drives: CLA45 AMG Macan S
That's how I roll Edwin
      02-28-2013, 08:19 PM   #73
froop
froop's Avatar
Drives: 08 AW 6MT E82
Isn't the HVAC filter there to filter the air coming into the AC? Does it make any difference to the smell etc with it off?
I guess it would be possible to run with the cowl off and HVAC on right?
      02-28-2013, 08:20 PM   #74
froop
froop's Avatar
But yeah, I might look at doing this mod along with getting some other stuff from BMS. Anyone want to share shipping once they have the thermostat back in stock?
      02-28-2013, 10:07 PM   #75
eriktufa
3r1k
eriktufa's Avatar
Drives: 2008 MY08 BMW E92 335i
I'm in Perth but I don't mind
12.836 @ 109.75mph (Cobb - Accessport & VRSF DP)
      02-28-2013, 10:21 PM   #76
sharkatron
Drives: `09 135i
I've always wondered with good vents for our cars - how do you stop water getting into the engine bay? Or just don't drive when raining? :
I know e9x m3 has special covers/drains for their vents.
      02-28-2013, 11:17 PM   #77
froop
froop's Avatar
I don't think it really matters if water gets into the engine bay unless you have open intakes. Obviously you wouldn't want water getting into the ECU compartment but as long as it's properly closed/sealed it should be fine.
Right? =
      03-01-2013, 01:03 AM   #78
DR-JEKL
Drives: Space Grey E92 335i 6MT
Its most likely bullshit, but I read somewhere a while ago that bmw designed the direct injection engines to run on the hotter side to minimise carbon buildup.
Sounds like typical internet forum BS heresay.....
I have been monitoring my car for over a week now, highest oil temp I have seen is 115 Deg C in some traffic light GP style driving. Typically it sits at 105-110 when warmed up and doesn't budge from 110.
      03-01-2013, 02:29 AM   #79
RoadRunner///M
I think that messing with the thermostat is a bad idea. Car will take longer to warm up and cold engines get damaged! There seems to be this obsession that 120C is too hot, which it isn't. 120c is optimal for these cars as per BMW engineering.
      03-01-2013, 02:51 AM   #80
DR-JEKL
I would have thought so also, yet Terry from BMS is no fool it would be nice to get a few comments from him though.
      03-01-2013, 02:55 AM   #81
RoadRunner///M
I want my oil to heat ASAP
      03-01-2013, 02:59 AM   #82
1911A145
1911A145's Avatar
26
"run flats" are also "optimal" by BMW as well.... what's your point? Just because something is "engineered by BMW", does not mean it is the end all be all. Many things have room for improvement.
      03-01-2013, 03:07 AM   #83
DR-JEKL
I would have thought the oil temp would still reach operating temp at the same rate from ambient, but the bms thermo would cause it to run slightly cooler once it reaches operating temp?
      03-01-2013, 03:11 AM   #84
Nugget
Nugget's Avatar
Drives: 2017 M140i, 1994 E36 M3
2011 BMW 135i  [5.00]
This is my thinking as well.
      03-01-2013, 03:16 AM   #85
TimMc
TimMc's Avatar
Drives: 135i SCT N54
I would have thought the oil temp would still reach operating temp at the same rate from ambient...?
No. It will take longer to warm up as the oil is pumped through the cooler all the time the engine is running, instead of when the OEM thermostat opens at ~109 degrees. Similar theory for thermostat in the water cooling system. Radiator is only used when water reaches operating temp.
Driving - Man 135 (LeMans/Black). BMW Perf SW, Quaife LSD, KW V2s, Ground Control camber plates, M3 front Control Arms & SB, Helix IC, AR DPs, PROcede V5, ER CP, Forge DVs, BMS OCC, Setrab OC, P3 Gauge, Alcon 6 Piston Calipers, DBA 365mm 2 piece rotors.
Riding - BMW R1200RS Sport, Merida Scultura 7000E, Avanti Aggressor, Malvern Star Equipe, Mini Mal.
Proudly from the Shire.
      03-01-2013, 03:42 AM   #86
RoadRunner///M
Well go for it then! Run cold oil
      03-01-2013, 04:17 AM   #87
1911A145
1911A145's Avatar
26
I will! In fact... now that you mention it... I do every day. About 3-4 times a day. For about 10 minutes each time when the car is warming up!
I live in Florida. The only "cold oil" is on cold starts. As long as there is little to no load on an engine during warm up, there is an extremely, if not nearly 0% chance, of engine damage due to lack of lubrication from the viscosity of "cold oil".
I seriously doubt the fact that the oil taking an extra minute, or two, would have any adverse side effects on the engines longevity, or the performance. In fact, there is a reason oil has varying viscosity from cold start to full engine temp.
Oil has come a long way... and the fact that BMW "engineered" their cars, and oil, to last 15k miles between oil changes shows just how much variance and abuse the oil and motor can handle.
      03-01-2013, 04:48 AM   #88
RoadRunner///M
Good for you
Not to sure what oil changes has to do with thermostats though
That's why BMW limit boost until 70c
