Reply
      02-27-2013, 08:32 AM   #1
hatepotholez
Drives: 128i
Ridiculously horrible gas mileage 128i
Hello everyone, as the title states I am getting some ridiculous gas mileage. From full to approx. empty(12.956 gallons) my mileage driven was only 191. My commute is a mix of city and highway, with barely any stop and go's.
Dealer states the car is normal, also there are no check engine lights.
Probable things to do/check:
1)Tire pressure, I set them all to factory specs but I can check it again.
2) Air filter(Dealer states it doesn't need to be changed, Indy states air filter is probably not the cause).
3) Clean the MAF.
4) Some fuel sysem or intake cleaner?
5) Ask dealer to check o2 sensors if the voltages are correct.
Any tips or opinions would be greatly appreciated.
hatepotholez is offline
      02-27-2013, 09:42 AM   #2
Obioban
Drives: 2005 M3, 1995 M3 racecar
Any fuel smell?
Obioban is offline   Reply With Quote
      02-27-2013, 10:05 AM   #3
Evice
Evice's Avatar
Drives: BSM 128i M-sport and '98 M3
3) Clean the MAF.
Your foot is heavy and you are sitting in traffic too long. lol
-- '09 BSM 128i - MSport trim, 6MT, Heated Seats, Xenons, Premium Sound.
-- '98 E36 M3 - BMWCR IS #718
BMWCCA Instructor and Club Racer.
http://www.youtube.com/alisalih
Evice is offline   Reply With Quote
      02-27-2013, 11:43 AM   #4
andnkuhn
andnkuhn's Avatar
Drives: 135i.N55.6SPD.M-SPORT
2011 BMW 135i  [0.00]
3) Clean the MAF.
I put 1 bottle of TECHRON in a full tank every 3000 miles or so. It cleans out my injectors and seems to help my fuel mileage marginally. Maybe for you it will clean out your injectors and give you a much needed improvement. I buy mine at my local AutoZone but here is what it looks like.
http://www.amazon.com/Chevron-65740-...ywords=TECHRON
TauK-n Tky 1. at a time///
andnkuhn is offline   Reply With Quote
      02-27-2013, 12:26 PM   #5
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [0.00]
what type of gas do you use?
128i Sport 6MT converted to Euro 130i spec, tuned by EVOLVE
In-progress: Evolve tune configuration!!; my ssk idea , custom e36 lip fitment - PITA
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is Review
andrey_gta is online now   Canada
      02-27-2013, 12:31 PM   #6
ulrichd
ulrichd's Avatar
Drives: 128i M-Sport
3) Clean the MAF.
Actually that's about what I get with a heavy right foot and mostly city driving. I don't get past 200 miles per tank until I do some freeway driving.
ulrichd is offline   United_States
      02-27-2013, 01:54 PM   #7
631twentyeighteye
631twentyeighteye's Avatar
Drives: 2010 128i MT
just about all highway i get 25mpg no issues, and that's not going slow by any means. Thats also with some playing around town. I get 250+each tank easily. i have an MT also.
Injen intake, Custom 135i Active Autowerke exhaust fitted to 128 mids, blackline tails, Depo headlights w/ 8000k LED angel eyes and xenons, 8000k xenon fogs, Lowered on eibach springs, 264's in anthracite with a red lip wrapped in hankook v12's in 135i sizes.
631twentyeighteye is offline   United_States
      02-27-2013, 03:10 PM   #8
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
Drives: 2012 128i Coupe 6MT Sport
You can get a six-pack of Techron Pro-Gard at Costco for about $20, if I recall.
bmw1racer is offline   United_States
      02-27-2013, 03:30 PM   #9
andnkuhn
andnkuhn's Avatar
The pro-gard is different than the concentrate-plus i believe. The pro-gard is cheaper. so im assuming the concentrate-plus is better? I have never used the pro-gard.
      02-27-2013, 11:41 PM   #10
hatepotholez
Drives: 128i
No gas smell.
I can try the chevron additive and try using tier 1 gas stations.
I always put 93 octane.
No driving with a lead foot here, that's for sure!
Can a partially dirty fuel filter be an issue?
What about a dirty maf?
I should ask the dealer to check the o2 sensor readings just in case.
She recommended to try a fuel injection service, because the previous owner might have used 87.
The commute is 60% highway and 40% local. Barely any stopping.
hatepotholez is offline   Reply With Quote
      02-27-2013, 11:55 PM   #11
HeelToe
HeelToe's Avatar
Drives: Rapidly from A to B
2006 330i  [5.00]
2013 BMW 135is  [0.00]
2000 323Ci  [0.00]
Mileage on the car? I replaced plugs on my 330i (same engine but different intake) and got almost 2 mpg. I had 70k miles and replacement was not recommended until 100k. That wouldn't explain all of your problem but you may have more than one item causing the issue.
HeelToe is offline   United_States
      02-28-2013, 01:03 PM   #12
hatepotholez
Drives: 128i
Currently it has 39k on it. Was it quite a task changing out the plugs? If the previous owner used 87, and now using 93 would that have something to do with the bad mileage?
      02-28-2013, 03:17 PM   #13
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 130is 6MT, E39 M5, E36 M3
If you are getting 14-15mpg you have a serious problem.
I drive like a complete ass whenever I can(~80% of the time) and I get 20.4mpg. The only time I was getting 14-15 MPG is when on the highway at a constant 130mph. We lose mpg dramatically going past 80mph in this car.
2010 130is Alpine White 6MT / M-Sport / SuperSprint Headers and Swain Tech Race Coating / 330i Intake Manifold / EVOLVE Software / BMW v1 Performance Wheel / BBS RGRs with PSS / F30 Brake Dust Shield / BMW CF Spoiler / Blackline LCI Tail Lights / Rear Fogs Enabled / Front Fogs Delete / CDV Delete / BMW Black Kidneys / Hardwire V1
TheSt|G is offline   United_States
      02-28-2013, 03:31 PM   #14
Moderator
Drives: 135i Silber mit/Rot 6MT N54
No gas smell.
^^That would be the first thing to check. And check for any stored codes. your lambda value should be near 1.00 +/- 0.02% with the engine running.
What kind of tires do you have? OE sizes? And what pressures? I would also take out your air filter and see how dirty it is. The fuel filter is part of the fuel pump... and it should not need to be replaced yet. Probably around 80K or 100K miles.
You might even want to check the trans fluid and level. Also the diff fluid. It won't hurt to change those out. Changing spark plugs wouldn't hurt either.
Also what kind of oil are you using? Maybe the previous owner put something really thick in the engine?
^^^These are the things I would look into.
Dack
Dackelone is online now   Germany
      03-01-2013, 10:08 AM   #15
hatepotholez
Drives: 128i
Dack
The car is at the dealer now, and I told the SA to check the O2 readings and MAF readings. They said they would run a fuel efficiency test(?). Either way I am going to clean the MAF as it looks like a common thing to do and change the air filter.
Running stock size tires, front RF tire is brand new, LF has pretty good thread on it. The tire pressure readings i'm not to sure of but I will definitely check them over. I bought a tire gauge just for this lol!
The car was maintained at the dealer, and don't see any history of ATF fluid change or rear Diff, but do see engine oil changes done at the dealer. One Indy I spoke to stated don't touch the ATF until 50k.
I might consider putting an exhaust and intake if it would help.
      03-01-2013, 10:11 AM   #16
Moderator
^^You should check/change your air filter. No telling what it looks like. BMW dealer service means nothing but oil changes and wiper blades and maybe a pollen filter and brake fluid flush at two years. Nothing more.
Plugs and air filter would be my best bet before doing any mods.
      03-01-2013, 10:24 AM   #17
MightyMouseTech
MightyMouseTech's Avatar
Also, I see you are in NYC. Freezing temps, short trips and stop and go driving combined will give horrific fuel economy. Although, you mentioned no stop and go driving. Do you let the car idle for more than a minute or so?!?!?
MightyMouseTech is offline   Reply With Quote
      03-01-2013, 07:07 PM   #18
hatepotholez
Drives: 128i
I think your right, I haven't even checked the air filter. Might as well order one and put it in.
      03-01-2013, 07:09 PM   #19
hatepotholez
Drives: 128i
Yea it sits for over a minute, sometimes though not often. If I sit for over a minute will it make a difference? If so ill do it more often lol!
      03-01-2013, 07:40 PM   #20
631twentyeighteye
idling=zero mpg. minimal idling=best mileage. with that being said, i let mine sit in the mornings for 5-10 mins before i leave for school. I dont care what BMW says, letting oil circulate on a cold motor is better then just starting it and taking off.
      03-01-2013, 07:47 PM   #21
Iron Man
Iron Man's Avatar
Drives: Alpinweiß 128i ordered
I read somewhere, can't remember the source, but it stated that it is better to warm up most modern engines by driving them lightly the first few miles, rather than idling.
Iron Man is offline   United_States
      03-01-2013, 07:51 PM   #22
631twentyeighteye
the issue with that is that i drive .25 of a mile before i have to merge onto a highway, i'd rather let it idle for a few minutes before having to merge on a cold motor.
Reply
Forum Jump
