      03-23-2013, 01:27 PM   #1
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Finally installed my SSK
Wasn't too bad a job. My only "OH, duh!" moment was realizing that the "special tool and bearing mount in the CCW direction" was from UNDER the car. CW from above in the cockpit FTW.
Love it, love it, love it. The factory SSK lever is essentially the same length as stock (actually slightly longer), it's the length under the fulcrum that gets substantially longer to create an over all shorter throw.
Kit was P/N 25 11 0 444 655
I also installed the BMS clutch stop which I love also but I'm going to remove one shim as my car doesn't think I have the clutch all the way in unless I step on it really hard. (I had a minor panic attack when my new car wouldn't respond when I pressed the start button...)
FWIW, and I realize this is the wrong place, but I will be selling the SSK knob and boot. I re-used the M-Sport knob and boot that came with the car.
      03-23-2013, 03:13 PM   #2
r0nd3L
Congrats on the shifter! And LOL at the car not starting, I had the same issue on my car haha. With full stack clutch end point was perfect, but not deep enough to engage the clutch switch, unfortunately.
      03-23-2013, 03:17 PM   #3
631twentyeighteye
631twentyeighteye's Avatar
Drives: 08 335i
I also had that issue. Took one washer out and it's perfect. How much shorter is the throw with the SSK? Compared to 135i/335i's the throw is already really short on n52's. I was debating getting one but decided against it as i don't want it too short.
08 e93 335i MT
      03-23-2013, 03:46 PM   #4
Sweet! So you installed the 128i SSK P/N 25 11 0 444 655 in your 128i.
Why didn't you just order the SS lever and plastic bushing and some extra C-Clips? Since you did not need/use the Perf knob and boot. ?
(1) SSK lever p/n 25117542200
(1) plastic bushing p/n 25111220600
(4) C-clips p/n 25111220379
http://realoem.com/bmw/showparts.do?...=25&fg=95&hl=2
      03-23-2013, 04:07 PM   #5
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I didn't actually measure it, and the BMW blurb says "up to 25%, but I'd guess in the 18 to 20 percent range. It feels great and definitely not too short.
      03-23-2013, 04:11 PM   #6
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Easy, because I hadn't decided not to use them yet. I may change my mind still. I kind of like the heft/mass of the performance knob. It's smaller, but feels beefier in its own way. Hell, they take 30 seconds to change. I may keep them both and swap them out on a whim.
      03-27-2013, 12:23 PM   #7
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I analyzed my picture and based on what I could measure BMW's "up to 25%" is spot on in this application.
      03-27-2013, 12:44 PM   #8
BMW shifter throws...
N54 = 80 mm's
N54 Perf SSK = 55 mm's
N55 = 70 mm's.
      03-27-2013, 02:32 PM   #9
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
N54 = 80 mm's
N55 = 70 mm's.
Didn't measure the actual throw but the ratio difference. Numbers are accurate enough for this analysis, 20 degree angle is random and irrelevant to the result.
      03-27-2013, 02:57 PM   #10
^^You just lost me. I can understand throws better than angles.
      03-27-2013, 03:28 PM   #11
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I guess it boils down to: Whatever your 128i's shift lever throw is, if you put on this kit it will be about 25% less. I didn't do a throw measurement before and after and don't know the travel of the shift rod, so I can't calculate the actual throw, just the percentage difference.
      03-30-2013, 07:03 AM   #12
Fireflyer239
Drives: BMW, Jeep, Ducati & Harley
You won't be thinking about angles and millimeters when you drive (I hope), just about how good it feels!
      03-30-2013, 07:17 AM   #13
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I haven't even turned on my radio in three weeks.
      05-13-2013, 05:29 PM   #14
Apiasto
Drives: Black 128i
LOL Solid Works?
      05-13-2013, 06:54 PM   #15
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Sweet. I would like to to this for the n54 lever. Will check back here soon
@Suprgnat if i give you measurements of the n54 lever can you add it to this picture?
      05-13-2013, 08:41 PM   #16
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Sure, easy enough.
      05-13-2013, 09:01 PM   #17
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Originally Posted by Apiasto View Post
LOL Solid Works?
Autodesk Inventor Professional
      05-14-2013, 08:09 AM   #18
Apiasto
Drives: Black 128i
LOL Solid Works?
I thought it was a newer version of SW that I haven't seen yet... Then again I haven't used it in 3 years... Pro-E is my new home
      06-10-2013, 06:41 PM   #19
exPat
exPat's Avatar
Drives: 128i 6MT
Thanks, Dack. I found P/N 25111220379 is also known as P/N 25117571899. Shifter C-Clips.
      08-16-2017, 10:22 PM   #20
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Updated BMWP SSK +AKG
I've collected all the parts. New BMWP SSK shift lever, new shift lever bearing/retainer, AKG DTM Selector Rod, and AKG Shifter Housing Bushings ready for a drop-in install to replace my existing BMWP SSK. Now, like always, I seek time to do the install.
Inertia is the enemy!
      08-17-2017, 09:25 AM   #21
asbrr
Drives: 2014 335ix M-Sport
Excellent, you're gonna love the extra precision of the AKG DSSR...
      10-03-2017, 10:03 AM   #22
VA08
VA08's Avatar
Puerto Rico
Drives: 2008 BMW 328i 6MT MSport Sedan
Suprgnat have you been able to install the AKG selector rod and shifter arm bushings? I would love to get your impressions on them as I'll be doing a shifter refresh soon as well
