      06-03-2014, 08:47 PM   #23
BaNaNaBoy69
BaNaNaBoy69's Avatar
Drives: E88
Originally Posted by Wakka View Post
Havent seen this before but now im interested... I had my car coded by a member here a few years ago. He did it out of the bronx and didnt charge anything.
Really nice guy and everything came out great. When i moved down to florida my local dealership cleared all the coding off. This seems like a nice alternative to paying a shop several hundred dollars to code it.
I wish I had someone nice locally to do that for me!
2005 BMW X3 30i [E83] Retired
2009 BMW X6 xDrive35i [E71] Retired
2009 BMW 128i Cabriolet [E88] Alpine White / Coral Red Boston Leather / Moonlight Black Softtop / High-Gloss Black Trim / 18" W Spoke Wheels / Navigation / Premium / Premium Sound / Sport / PDC
      06-04-2014, 07:33 AM   #24
spinnakerflying
Drives: 2016 328i, 2010 135i
Originally Posted by BaNaNaBoy69 View Post
You should download the free BMWhat Lite version to test if your adapter can work with the app.
I did this last night... the Lite app connected and worked well with the ELM 327 Wifi OBDII device, so I purchased the full app. 10 minutes total and I now have my windows closing via key fob. $50 might seem expensive, but I would have probably spent a couple hours tinkering with the NCExpert/BMWTools to get that far. Thanks, OP!
This page lists what coding options are available for our cars:
http://www.ivini-apps.com/coding.html
      06-04-2014, 02:59 PM   #25
halfhalo
Drives: 08 E88 135i
2017 BMW F83  [0.00]
2008 135i  [0.00]
NCS Expert/INPA and the cable/adapter are definitely a cheaper option and I did consider it. But how much is your time worth, especially since your need to re-setup everything you lost? The learning curve, setup time and coding are definitely more time consuming. I want quick and dirty coding without having to manually code like a computer programmer. If you had BMWhat, you would just have to connect the smartphone app to your car and press a couple of buttons and, your coding is back.
True, the BMWhat is cheaper, but it also doesn't let you do things like the Alpina Flash and retrofitting the alarm, both of which I have done.
      06-04-2014, 03:18 PM   #26
Andrewcoja
Drives: 2011 135i MSport
With BMWhat, I can change the voltage of the angel eyes when the xenons are on?
      06-04-2014, 04:24 PM   #27
BaNaNaBoy69
Drives: E88
That's awesome! I'm glad I could help and I don't even have the app yet!
      06-04-2014, 04:26 PM   #28
BaNaNaBoy69
Drives: E88
Hopefully, the developer keeps updating the app and one day it can code a whole bunch of cool options. Fingers crossed!
      06-04-2014, 04:38 PM   #29
BaNaNaBoy69
Drives: E88
BMWhat can change the voltage of the angel eyes up to 13.8v max, but I'm unsure whether this applies to if the xenons are on or off. Typically, the angel eyes are at full power when the xenons are off and dim down when the xenons are on. It would be cool if the angel eyes were always at full power regardless.
Check this link out for a full list of coding options.
      06-04-2014, 04:43 PM   #30
darkrom
darkrom's Avatar
Yes you can set the angel eyes to 13.8v. I've had them that way with lights on and off since I got the car. Done through BMWhat.
Does anyone here have some patience and want to show an IT guy how to use NCE? Or have any guide with a sample coding done etc? I have all the stuff I need, including a VM that has all the tools installed/configured at least. I just don't really know where to start reading to make sure I don't screw anything up. I'm usually really good with this stuff, just nervous to try it on my expensive car haha.
Honestly the only thing I want to do at this point that I haven't been able to do is disable the i-drive start up warning. Can anyone confirm that is even possible on a 2010? I'd really love to learn how to do that.
      06-04-2014, 04:55 PM   #31
BaNaNaBoy69
Drives: E88
You should check out 'b m w coding .com'. I've also found many resources just searching for coding on the forums (e90post, etc) and Google.
According to this, you should be able to use software to manually code disabling the iDrive startup disclaimer. I'd love to get rid of that too!
See Row 11 on the spreadsheet.
https://spreadsheets.google.com/spre...owsperpage=250
      06-04-2014, 05:42 PM   #32
Andrewcoja
Sweet, I'll have to download this and buy a bluetooth OBD port and check it out.
      06-05-2014, 10:45 AM   #33
JimD
JimD's Avatar
369
Drives: 128i convertible
Maybe a minor clarification is appropriate for NCSExpert. I haven't used it in awhile but it is not real time consuming to use. I would say it is cumbersome. I ran INPA to be sure I was connected and then NCSExpert to make changes. For each change, you download the portion of the cars software that the item you want to change is in, make the change (in a wordprocessor or notepad), and then load the modified script. The whole process is a few minutes. But the commands you need to use are not obvious so I used a tutorial that had step by step instructions each time I made a change.
If this phone tool is just a function of issuing a command or something, it would be a useful simplification of the process. If I knew it did battery coding I might get it for my wifes phone (mine is a work phone). I have a bluetooth that might work (I use it for Torque sometimes). Or maybe I could put this on a tablet, I have an Android tablet.
Anybody try this software on a tablet? I looked for battery registration and didn't see it in the list of features.
      06-05-2014, 11:42 AM   #34
darkrom
darkrom's Avatar
Works fine on tablets. You really don't want to use any BT adapter. Its worth it to get theirs. My results were up and down constantly with one that works fine for torque.
Once I got the BT adapter they sold it was smooth sailing and much faster as well.
      06-05-2014, 12:34 PM   #35
Dilmorecg
Dilmorecg's Avatar
115
Drives: 2014 X5 50i
Just ordered an ELM 327 wifi (iPhone). This looks like a good option for the cost.
      06-05-2014, 01:50 PM   #36
Mortify
Drives: 2008 135i m sport
I just did my coding today, I already had a USB cable for my alpina flash. Also I took the cheap ass way and just googled "BMWhat v12 apk" so I didn't have to pay. Oh well sue me.
      06-05-2014, 02:11 PM   #37
darkrom
darkrom's Avatar
I'm down with pirating movies or whatever, but this is pretty shitty. There are so few people interested in BMW coding apps that they need to sell this for a higher price in order to justify the time spent developing such a niche app. Seriously, this is why no one cares to spend the tons of time it takes to do things like this.
Drives a BMW yet is too cheap to pay for the app that saves you money compared to getting the car coded by a vendor or someone. Classy.
      06-05-2014, 03:45 PM   #38
Andrewcoja
I agree. I'll pirate most anything. But for something like this, just pay the money
      06-05-2014, 04:04 PM   #39
darkrom
darkrom's Avatar
Yep. The movie industry doesn't care about joe smith when 1 million other people go see the movie. When one person doesn't buy an app like this, that is probably closer to 1% of their target market. That really hurts them. I pirated the same app to see if it worked, then I bought it because this is the kind of thing that only exists with support.
      06-05-2014, 05:12 PM   #40
Mortify
I paid for jb4 mobile, but this app caters to every BMW. And 60 bucks?? Jb4 mobile was 30. Gimme a break!
      06-05-2014, 06:08 PM   #41
BaNaNaBoy69
Drives: E88
The good thing about paying for this app is for the updates since coding options are constantly being added. I like BitTorrent as much as the next guy but you would have to constantly search for the latest pirated update, which wouldn't be easy and you don't usually have to do with software or entertainment.
I figure the app would pay for itself once I've coded or check/cleared fault codes even once. Just like my $300 radar detector has paid for itself many times over by saving me from $200 speeding tickets several times over the years. Except you can't pirate a radar detector.
      06-05-2014, 06:19 PM   #42
darkrom
darkrom's Avatar
Are you sure you didn't just pay for JB4 mobile because they have better protection and its much harder to pirate? I tried to pirate it to test it like I do all expensive apps. I couldn't find a copy and bought it based on the good reviews, luckily it works great.
Like I said I pirated BMWhat, tried it out to make sure it worked and once I was able to code my key settings, I bought it immediately. Even though I could do the same for free. You just need to know when something is worthy of paying for. Projects like BMWhat definitely are.
      06-08-2014, 06:17 PM   #43
JimD
JimD's Avatar
369
darkrom,
If you want to run INPA or NCSExpert I highly recommend going to b M
w c o d I n g . c o m and finding the long tutorial I use. It is on the order of 75 steps but works. Once you've successfully done something, I think initializing the digital speedometer is their example in the tutorial, you can start at about step 50. The initial steps are to be sure you are plugged up correctly and have things in the right directory. Making a backup copy of your cars settings is also one of the early steps of the tutorial. If you have the backup, you should always be able to go back.
One mistake some people have made is to let their battery run down while coding. That can create a mess but I would never spend that long at it. If you think you might, hooking up a battery charger may be worthwhile.
Good Luck!
Jim
      06-09-2014, 07:24 AM   #44
darkrom
darkrom's Avatar
Originally Posted by JimD View Post
darkrom,
Good Luck!
Jim
Thanks. I'll have to just fight the ADD and get through it haha.
That'll actually be really good to do since I skipped the digital speedo mod while coding with BMWhat, even though it offers it.
Could I be a huge pain in the ass and ask you to PM me a link? I'll be looking around, but once I have the right guide I'll be good to go I'm sure.
Thanks.
bmwhat, code, coding, e82, e88
