| 11-02-2013, 11:14 AM | #12 |
Joint Chiefs of Staff
33142
Rep 207,716
Nice!!!
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() |
| 11-02-2013, 02:50 PM | #14 |
![]() ![]() ![]() ![]() 1154
Rep 849
I hope you enjoy the E30 M3. I've had several including a perfect one with 46,000 miles on it and between worrying about it and the power/fun of 1M. I sold them all. NO 25+ year old car can stand toe to toe with a current car like 1M.
I know this will bring me tons of hate but I am a driver, not a collector. But you certainly have two of the best! Enjoy!
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
| 11-02-2013, 07:34 PM | #15 |
Rep 1,417
How about the details on that sweet E30 M3? Where did you find it, mileage, is it bone stock? etc.
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
| 11-02-2013, 09:53 PM | #16 |
Rep 3,450
Both car's so clean. damn.
jelly here.
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
| 11-03-2013, 11:16 AM | #17 |
![]() 7
Rep 48
1990 BMW E30 M3
Zinnoberrot red/black interior 82,000 miles Miscellaneous Notes: Panels on the car are original. Photos show the VIN tags on the fenders and doors. VIN tags not verified on rear quarter panels, as not easily accessed. No rust Original paint Dry undercarriage Original carpet mats with M3 logo (NLA) 17-inch Konig 5-spoke wheels (215/40/17 Front and 235/40/17 Rear) Note: OEM 15†basket-weave wheels convey with car; Goodyear Eagle P205 55R15 tires (OE tire) ********** Modifications & upgrades: Turner Motor Sport chip Evo II adjustable cam gears Timing chain tensioner upgrade (E36 tensioner) K&N air filter Short shifter kit One piece illuminated leather shifter Oil baffle Polyurethane alternator bushings H&R Sport springs Bilstein Sport shocks Racing Dynamics front strut bar Racing Dynamics rear strut bar Ireland Engineering front sway bar with reinforcements Ireland Engineering rear sway bar with reinforcements and adjustable end links Zimmer cross drilled rotors, front and rear 17-inch Konig 5-spoke wheels ********** Improvements and service while in my possession (77,000-80,000 miles): Install BMW CD43, BMW Business CD Car Radio, complete with Security Radio Code, installation instructions, operating instructions, programming instructions, 17-PIN connector & wiring harness and DIN-ISO antenna adapter. The CD43 head unit is mated to MobileSpec MS-6CH 6-Channel Line-Output Converter, BMW Sound System speakers, Q-Logic subwoofer, Zapco 360W 4-channel amp, Zapco 500W 1-channel amp. Replace tires and wheel alignment [77,618 miles]: Bridgestone Potenza-S (215/40/17 Front and 235/40/17 Rear) Replace entire exhaust system [77,676 miles]. Turner Motorsport double pipes & cats and BMW OEM muffler. Vehicle passed state Emission Inspection (certificate of proof is available) Install M-Coupe differential cover modification [77,676 miles] Replace rubber front control arm bushings [77,676 miles] (BMW Motorsport- upgraded rubber bushings) Replace rubber rear subframe bushings and rear trailing arm bushings [77,676 miles] Replace thermostat and coolant flush [77,676 miles] (OEM theremostat, BMW OEM coolant) Transmission and differential flushes [77,676 miles] (Motul Gear 300) Replace rear soft brake lines/hard lines/flush brakes [77,676 miles] (Motul RBF600 Brake Fluid) Evacuate and refill AC system [77,676 miles] Repair driver's door lock cylinder [77,676 miles] (repair kit- keyed to match passenger door, trunk and ignition) Repair central lock [77,676 miles] Repair cruise control [77,676 miles] Repair fog lamps [77,676 miles] Replace battery [77,676 miles] (Interstate Battery for E30 M3- MTP91) Replace Behr E30 M3 radiator and radiator hoses, BMW OEM coolant [78,255 miles] Replace E30 M3 water pump [78,465 miles] Replace engine belts [78,465 miles] Replace OEM spark plugs [79,267 miles] Set CO and base idle [79,267 miles] Synchronized throttle bodies [79,267 miles] Checked valve leash at dead cold (everything within spec) [79,267 miles] |
| 11-03-2013, 12:08 PM | #18 |
Rep 1,417
^ Very nice car indeed
| 11-04-2013, 08:50 AM | #20 |
Rep 469
Drives: 2008 Bmw 130i E81
Wicked man! Thats a sweet collection!
Wishlist...
Bmw 135i Convertable White... |
| 11-04-2013, 10:06 AM | #21 |
MINI Member
139
Rep 135
Welcome to the club! I have the same combo having owned the M3 since '06. This past summer after racing our e30 325i in chumpcar I realized how bad the seating position was in my car so I made two mods to rectify it. 1) Lowered the rake of the steering wheel by 1" and 2) Replaced my evo steering wheel with a OMP Corsica wheel. I'm 6'2" with go-go gadget legs so always push the seat to it's furthest back position. This made the wheel feel so far away and too high like I was driving a bus. With the mods it's now a similar feel to the 1M but with a lower seat (better).
The e30 M3 is one of those unicorn cars that people don't realize how good they are until they have had the opportunity to drive it on some twisties in anger. More enjoyable than the 1M in said situation. Anyone that comes away unimpressed probably doesn't understand what "feel" is supposed to feel like ![]() Congrats and enjoy, I just put both away for the winter. Going to be another long winter cheers Amit
1M | e30 M3 | e30 Touring (M52 swap) | e36 328i Racecar | Porsche 911 3.2 | e91 328xi (N54 swap)
| Bookmarks |
| Thread Tools | |
