| 05-09-2016, 01:44 PM | #221 | |
Rep 7,248
http://www.1addicts.com/forums/showthread.php?t=1222564 |
snarleyow8.50 |
| 05-10-2016, 01:45 PM | #222 | |
![]() 60
Rep 70
Drives: 2021 HS 6sp
This is what my car is doing also. It sounds like we have the same set up and mileage. I'm going to the dealer on Thursday and hopefully this will get better. It has definitely degraded over the last couple thousand miles. |
| 05-20-2016, 12:03 PM | #223 |
Rep 4
I had this problem as well, and it was such a PITA. I got a quote from the dealer for about $300 to install the DME software. I actually ended up getting a PPK flash for $80 which I believe includes the DME software. It fixed my issues so far, about 1 week in. Life is so much better now that I can turn on my A/C
| 05-20-2016, 12:59 PM | #225 | |
![]() 53
Rep 208
| 05-20-2016, 01:21 PM | #226 | |
![]() 56
Rep 265
| 05-20-2016, 01:23 PM | #227 | |
Rep 4
It was honestly an easy (and a loooooot cheaper) process. He sends you the cables, and all you need is wi-fi, battery charger (I grabed a 20AMP one from wal-mart, then returned it right after), and about 30 minutes. |
| 05-20-2016, 02:14 PM | #229 | |
Rep 7,248
http://www.shopbmwusa.com/PRODUCT/35...ANCE-POWER-KIT You could get it here ---->> http://www.1addicts.com/forums/showthread.php?t=1250118 Check your build date here since your car is a 2012 ---->> http://bimmer.work |
| 05-20-2016, 03:29 PM | #230 | |
![]() 56
Rep 265
Genuine BMW Performance Power Kit for N55 Engines, Version 2 (135i/335i - from 3/10 and on) OEM BMW Performance Power Kit for N55 Engines - for 135i and 335i vehicles produced from March 2010 with the N55 engine! This Power Kit includes a software upgrade to increase power output, an auxiliary water cooler and a more powerful radiator fan to increase engine cooling capacity. |
| 05-20-2016, 04:11 PM | #231 |
Rep 7,248
Yeah, no need to buy PPK2 unless you track your car IMO. I had PPK1 from 2011 to 2016 and never had an overheating issue and I drive very spiritedly at times. Some people disagree with this but this is what I think based on my experience.
You might want that extra cooling if you plan on adding some more power later. Don't know how much it would help. |
| 05-30-2016, 12:34 PM | #232 |
N55 Pure Stage 2 w/ DCT
24
Rep 51
Hi everyone!
I've been having the same problem with my car almost since I bought it. Car: 2013 135i N55 with DCT (no PPK) Symptoms: - Engine Stuttering - Jerkiness Stalling with A/C - Car jumps forward when coming to a stop... it kinda feels like when doing a "heel-toe" downshift from 2nd gear to 1st gear including a knock noise from the engine fighting to keep it running on very low RPMs. - The car started to have these issues since stock at around 8000 miles. Current mods on my car: - JB4 with ISO mod and JB4 connect kit - BMS Intake - Helix FMIC - Megan Racing Downpipe - Mid resonator deleted - COBB Chargepipe Actions already taken to attempt to fix the issue: - Took the car to the dealer for a software update (Mentioned the SIB 12 15 14)...... Didn't fix it - Did a DCT adaptations reset via Tool32 on a K+DCAN cable.... Didn't fix it - Did a Throttle Adaptations reset (regular pedal procedure)...... Didn't fix it - Updated my JB4 firmware to the latest version and switched to Map 5.... Didn't fix it - Regular oil change on the N55 engine.... Didn't fix it - Scanned the car for old codes... No codes saved I'm lost now guys, Every single thread on any forum suggest to bring the car to the dealership and mention the SIB 12 15 14... but this DID NOT fix my issue. Summer is coming and hot weather is increasing... A/C must be turned on almost all the time. The car feels awful when coming to a stop and jumps forward like it's about to launch hard... One notorius symptoms is that the car does this only when the DCT and N55 engine achieve the regular temperature conditions. It does not do it on cold transmission temps. PLEASE HELP! |
| 05-30-2016, 06:44 PM | #233 | ||
Rep 1,944
| 05-31-2016, 11:59 AM | #234 |
![]() 769
Rep 1,111
From what I've learned the PPK should fix it, and can work with a JB4. I plan on doing the PPK soon |
| 05-31-2016, 02:03 PM | #235 | |
Rep 193
I am happy to say that SIB 12 15 14 fixed the problem. Before the fix my car was all but completely undriveable. If anyone would like to see the letter I wrote, I am happy to post it. |
| 11-13-2016, 09:45 AM | #237 |
![]() 18
Rep 100
for me, latest factory software flash, and fixing a leak at an intercooler connection fixed all idle and lag issues. this latest factory software a couple of months ago. they did a nitrogen leak test to find the leak.
2011 135i DCT
Space Gray Metallic | TR Motorsports 17x8 ET40 Wheels | Koni Yellows | FMIC | Charge Pipe | MHD Stage 1 | Riken Raptor 245/40ZR Tires |
| 11-14-2016, 07:31 PM | #238 |
![]() 275
Rep 1,173
More than likely your DME needs to be updated to a version that corrected this issue. If you want to avoid a trip to the dealer, let me know.
| Bookmarks |
| Thread Tools | |
