11-13-2017, 03:42 PM | #23 | |
Rep 674
I wanted a fun car, 2 doors, 3000-ish pounds and good power. The 135i is way more fun to drive at the limit. 10000000% satisfied with my decision.
11-13-2017, 04:47 PM | #24 | ||
Boost
1355
Rep 3,697
Drives: 135i M-Sport
11-14-2017, 09:08 AM | #25 |
Rep 2,450
Are you planning on posting more details about how you did your oil cooler setup? I refuse to pay the mark up on what’s available so I plan to install one myself at some point. The main thing holding me back is the lack of free time to come up with a mounting solution. Would be awesome to see how you did yours.
11-14-2017, 09:52 AM | #27 | |
Boost
1355
Rep 3,697
You're in the bay area right?
11-14-2017, 12:14 PM | #28 | |
Rep 674
I don't think 1 core is enough. These cars need two cores, and they only real way I've seen them perform well over time is to run in sequence rather than in parallel. I will say, however, the stock oil cooler, radiator, and intercooler worked fine for me in time attack fashion, where I'd do 2-3 hot laps, 1 cool down, and repeat. Temps were mild at 74* at Buttonwillow. But can't believe how solid and consistent the car was with an OTS MHD Stage 2 91 tune, few gallons of race gas, exhaust, inlets, charge pipe.
Bimmer TV125.00 |
11-14-2017, 12:15 PM | #29 |
Rep 674
Haha, thanks dude!! I know, I know. But I'm so happy with this thing. Nice to be in a small car.
11-14-2017, 01:59 PM | #30 | |
Rep 2,450
You lucked out with the 74* temperature! I went there last year and it was about 90 degrees, stock ppk flash, stock oil cooler and radiator, and I could barely finish one lap without oil temps starting to go into the 280 range! And I can tell you I was not going nearly as fast as you haha. My car is DCT though so a little more strain on coolant which may have impacted oil temps. Looking forward to your updates and progress.
11-14-2017, 09:02 PM | #31 |
Rep 1,004
nice build and nice driving. how do you like the clubsports? you like them better than say MCS,AST, or JRZ?
i need to do an oil cooler as well to go along with the csf radiator. i might start with a single just to replace the stock with either a setrab, mocal, or might cheap out and do CX racing. also how do you like those tires? thanks |
11-14-2017, 11:24 PM | #32 | |
Rep 674
This is over 8 laps at Laguna Seca, pushing it every lap, not like Time Attack. Thanks for the good words and I'll do my best to keep it up!
11-14-2017, 11:35 PM | #33 | |
Rep 674
I have had a long relationship with KW and have run Clubsports on many of my last cars. Saab 92x-Aero, E46 M3, Evo IX MR... I may send in my front struts for a rebuild and take the car to its limit with this suspension setup. I don't have any direct experience with AST, Moton, MCS, but in the future I might try a full true coilover AST / Moton kit. We'll see. Saw this today. Looks like incredible value if it works. I've heard good things. Someone should try it out. I'm tempted to, since it's like 1/3 the cost of what I spent on my home brew kit. https://fasterbypinnacle.com/product...il-cooler-kit/ Tires are pretty good so far. Tons of grip. They do get a little slippery once they're hot, so not good if you like to overdrive. They seem to wear really nicely, way better than my old RE71R's, but those had more grip for sure.
Bimmer TV125.00 |
11-15-2017, 07:33 AM | #34 |
Rep 318
Berns,
When you install the CSF radiator; you plan on keeping the stock electronic fan or going with a different setup? Advan makes some nice oil cooler kits as well: https://www.advanperformanceeuro.com.au/products |
11-15-2017, 09:34 AM | #35 | |
Rep 674
11-15-2017, 02:26 PM | #36 |
Rep 1,004
i saw the pinacle oil cooler, was wondering who he uses for cores. for his fmic i think he uses csf cores. and i never really liked the idea of blocking the radiator. even the guys i spoke to who race and build cars for nasa and scca didn't like the idea of blocking the radiator, even if i am running the csf radiator. for the inlets i read somewhere that the 335is or 1m radiator fan is 850w and slimmer. i have stock location inlets and the csf radiaor that ben sittingin the box since may and i an a little worried about real estate. i mean a 19 row setrab is 175$ and would fit nicely in the stock location. thinking of running that or like i said a mocal, earls or cx.
so you have a good hookup with kw hence the loyalty. i know some guys love them but most of the serious track guys go jrz, mcs, or penske. i have AST and they look at them as lower teir. they serve me well though. i can see you needing dual coolers though, you drive hard, even my buddy has a 135 race car with a single 25 row mocal and he had to dial back the tune a lot one race day because he was running too hot and limping. |
11-15-2017, 04:58 PM | #37 | |
Rep 674
Agreed on most of the serious track guys liking the big dollar remote resevoir stuff -- I'm sure it's for good reason. I have a lot to learn about suspension tuning, and driving too, so I think if I can master this setup and learn enough about making the right changes, I'll better utilize and appreciate something better in the future. Running 2:00 without aero off the bat at Buttonwillow has me thinking they're at least doing an OK job for now. I'm going to swap in some 8k springs up front, I think the 6k's are too soft. And I'm on the lookout for an e92 M3 rear sway bar, because having just the M3 front feels wrong. Thanks for the info on the 1M fan. I'll see if I can pick one up. PS -- as for the radiator. I think good cores will flow enough not to impede airflow too much, but only testing can tell. If I hadn't already bought everything, I'd try out the Pinacle unit.
Bimmer TV125.00 |
11-15-2017, 06:29 PM | #38 |
Loves me some MHD!
1866
Rep 1,726
While ya'll are on about oil coolers and racing, can I ask about the oil pan, and if any additional baffles are considered a good thing, or even required?
Google doesn't seem to offer much about stock configuration, and as always aftermarket says that anything but aftermarket will be starvation central if you even think about high g anything....
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
11-15-2017, 07:20 PM | #39 | |
Boost
1355
Rep 3,697
On the suspension topic I'm thinking about being different and going with Bilsteins Revalved by PSI or their clubsport setup. They're bulletproof monotubes and are often overlooked.
1and11865.50 |
11-15-2017, 07:31 PM | #40 | |
Rep 674
1and11865.50 |
11-15-2017, 09:02 PM | #41 |
Rep 1,004
berns- the clubsports are doing a great job, you are obviously a good driver, i just seen a few on the forums coming up lately for sale from guys stepping up to mcs or jrz. for me i dont know enough about suspension and at my driver level a good single adjustable setup is good enough. i will say one thing i had koni yellows and bmw perf springs and the ast4100 with 7k/12k were much more comfortable. i had 7k up front and dropped down to 6k and i think they are a tad soft and will probably go back to 7k or 8k. i had an e93 m3 front sway and replaced it with a set of eibach front and rear which are 27mm and 16 mm solid but also swapped out my whole suspension and did rsfb at the same time so its hard to tell and really haven't had enough time to play around.
spxx i know one shop that revalves the bilsteins here in NY, Anze suspension for some of the porsche guys but i would assume you are looking at whatever the bilsteins cost $150? and then add at least 200 possibly 300 or more for the revalve, i mean just a rebuild with changing oil is 200, adding shims and revalving and dynoing and readjusting has to be expensive. at that point your close to 500 a corner, might as well just buy a nice set. i think at the track one of the guys was saying 575 or so a corner for penskes he was having developed for his new M2. |
11-15-2017, 09:33 PM | #42 | |
Boost
1355
Rep 3,697
11-15-2017, 09:58 PM | #43 |
Boost
1355
Rep 3,697
How is the M3 steering rack vs stock? I do find myself being annoyed with the longer ratio + understeer on sharp turns and having to reposition hands occasionally
11-15-2017, 10:18 PM | #44 |
Rep 674
I mean, watch the in-car vid for an example of why the M3 rack is fucking worth every penny. Steering is definitely heavier, but response is perfect to me. Not a fun swap to do yourself but not too bad. Need to make sure the rack is centered, that's the hard part.
Bimmer TV125.00 |
