12-08-2015, 12:25 AM | #45 |
Rep 117
Redline uses ester as well so decided to give Motul a go coz I had fantastic results with its engine & diff oil.
Results: slightly smoother & silkier that Redline D6 Last edited by OneM; 12-08-2015 at 12:56 AM.. |
02-29-2016, 05:38 PM | #46 |
Rep 284
Hello,
Reading up online about this, ffl-3 (mft-lt 5) appears to be a fully synthetic based fluid. I found this stated here on their website. pentosin.net › CRP-116_Pento_FFL3 And it would seem the closest replacements would be redline dctf. (Pdk) Last edited by tommyb13662; 02-29-2016 at 06:47 PM.. |
02-29-2016, 06:06 PM | #47 |
Rep 22,992
Errr umm... so what are you saying ???
03-05-2016, 07:38 AM | #49 |
Rep 363
I replaced my fluid over the summer with D4 and I was initially impressed with the shifting feel however over the winter the gearbox was definitely less willing to shift. I had 2 mornings which were around 0F where I had to double clutch the box for the first couple of miles. Needless to say if my 1 is around for next winter I think I'm going to try something else.
03-14-2016, 08:58 AM | #50 |
Rep 99
Just put D6 in mine 2 weeks ago, its so much smoother now. Well worth the 30$ in fluid.
M3 Adjuster7909.00 Dackelone10638.50 |
08-04-2017, 07:34 PM | #51 | |
Rep 11,785
thanks for the link and info.. MTL is still available as MTL75W80 however the DCTF may be the way to go as it does indicate it is the direct replacement for BMW MTF-LT-5 |
Dackelone10638.50 |
08-06-2017, 12:56 AM | #52 |
Rep 309
Just put in DCTF with new 550i clutch change and differential upgrade. All is meshing very well together.
Dackelone10638.50 M3 Adjuster7909.00 |
08-10-2017, 02:49 PM | #53 | |
Rep 11,785
D6 ATF is recommended for non M 1 series now. DCTF is the recommended fluid from redline now for all M diffs from 2002- current. It has the proper friction modifiers and is also GL-5 rated. gonna pull the trigger on this one Last edited by M3 Adjuster; 08-10-2017 at 03:05 PM.. |
